Question about Dryers
Kenmore dryer won't heat up.
We changed igniter and still no heat. We hear the click. Help!
  • 4 more comments
  • normaljb Oct 06, 2008
    It is a Kenmore 90 series, model # 110.72912100 Thank you.
  • normaljb Oct 07, 2008
    Thank you for your help. We have ordered the parts and will let you know if it works. Thanks!
  • normaljb Oct 15, 2008
    Our Kenmore 90 series dryer model # 110.72912100 still does not heat up. We have replaced the burner ignitor and both coils. The ignitor does not glow. What now??
    The problem is not fixed. We have replaced the ignitor, and both coils. I notice the ignitor does not glow, but we do hear the click when the dryer starts.
  • normaljb Oct 16, 2008
    Our Kenmore 90 series model 110.72912100 will not heat. We checked the lint and vacuumed, air flow is great. We replaced the ignitior (but it does not glow). We also replaced both coils. Now what?
  • normaljb Oct 17, 2008
    We have looked at all of the available parts list and diagrams and can not find a thermocouple. Where is it and do you have a part number? Is there another name for it?
    Sergeant:
    Champion:
  • 331 Answers
The ignitor wont lite up ..........
maybe the board has blows......... why don't u get technician to check the fault
Posted on Oct 16, 2008
  • Dryers Master
  • 19,396 Answers
There should be a thermocouple, that regulates the heat, test it , when that is faulty, the dryer does not heat.
    Genius:
  • 1,847 Answers
Can you describe the issue isn detailed or is the issue aiready resolved.
Posted on Oct 15, 2008
  • Legin Varghese
    Legin Varghese Oct 15, 2008
    Did you clean the lint screen and replace? Also - all lint should be
    cleaned from back of dryer and the duct...many dryer manufacturer have
    safety sensors that will not light dryer due to there being too much
    lint, not enough air flow...(safety feature) ...
Dryer only works on 1 setting and is not heating
If your dryer is not heating assuming is a gas dryer. It could be due to The electrical fuse igniter is not working or no gas is going in. Need to remove the front bottom cover and check that the fuse is igniting when you turn on the dryer. You should hear a clicking noise just before the igniter turns red ( glowing) to receive the gas and create the flame to then produce the heat. If you are not able to see the fuse/igniter conduct this process, you might need to replace it.
Nov 16, 2013 | Kenmore Dryers
Mod 417.94052500 won't heat
Have you tried to watch or listen to see if you hear it ignite and then it goes out or does it not try to ignite at all?
If it doesn't try to ignite at all, replace the igniter with this part.
If it ignites and goes out after a few seconds, replace the flame sensor with this part.
Oct 19, 2012 | Kenmore 77632 Gas Dryer
I have a Kenmore gas dryer Model 74812200. It is no longer heating up. When I turn it on, I hear a clicking sound for about 30 seconds then it goes off. Then about a minute later I hear the clicking sound...
You would not hear the click if the ignitor was bad. It won't click until the flame sensor get heated up by the ignitor. So that tells me the thermal fuse ain't melted. I would say them coils on the gas valve are the problem. themobilian_2943.jpg
Aug 30, 2011 | Kenmore 74812 Gas Dryer
My kenmore 80 series dryer wont heat up how do i fix it
could be the igniter or thermal fuse if you hear the gas valve click open and there is no glow inspect the igniter for a hot spot or white spot where the brek occured,some dryer will spin but not heat up if the thermal fuse is blown
Mar 20, 2010 | Dryers
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Gas dryer not heating.
Commontly thermal fuse is damage need check and change if necessary.
Oct 02, 2009 | Dryers
I replced ingnitor in my kemore gas dryer but not flame
Hello Friend, If the igniter is glowing continally and not clicking off, then your therm-disc is definately bad. It's attached to the burner shroud right across from the igniter. It reads the heat off the igniter through a little rectangular hole in the shroud. Replace and problem should be solved.
If igniter is glowing and then cools down and then begins to glow again in a repeating manner then I would say that the thermo-disc is good and you need to replace the gas valve coils. coils are easy to change, they are located on top of gas valve, two screws hold them in place. An easy fix.
Happy to help, Tim.
Jun 30, 2009 | Kenmore 75944 Gas Dryer
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Kenmore 70 gas dryer will heat for 7 minutes then nothing
Change these:3d37aa7.jpgthey get hot and quit, then cool off and work some more.
Dec 31, 2008 | Kenmore 73952 Gas Dryer
Kenmore Dryer
Marco, looks like you covered a venting problem and with the fact that you changed all the thermostats, leads me to believe that your primary and boosting coils are not functioning as they should. This are located on the gas valve. A sure way to tell is by observation. The ignitor will glow, you will hear a click and the flame should start. If it glows, clicks and does not start you can be assured it's probably your coils. Pretty inexpensive to repair. The part numbers are 5303307292 for the secondary coil and 5303307292 for your booster. Make sure to change both.
Apr 29, 2006 | Kenmore 94072 Gas Dryer
Dryers Logo
Top Dryers Experts
