Question about Linksys Wireless-G WRP200 Router
WRP 400 Inbound call issue
Hey.. I have setup my linksys WRP400 router with Dlink 502GT modem+router in normal mode. The firewall in both the devices has been turned off. Now the problem is i can mae outbound calls but when it comes to inbound i can hear the ring but when i pick up the line then nothing happens. I cant hear anything and the other party hears an engage tone.
Had a word with linksys support they opened up a few ports and brought about a few changes in the system but no luck. Still the same issue. Please Help
  • ur17 Dec 10, 2008
    Exactly the same problem: I have a Linksys (WRP400 Router + ATAintegrated in one machine). No other routers in my network.
  • 29 Answers
This could be due to the fact the when using multiple routers you need to let the main router know the routes into the second router.
I do have a question as to why you would use the second router and not the dlink?
I would suggest dropping the dlink router/modem and get your ISP to send you just a modem and then use the linksys. Or of course don't use the linksys and just use the dlink.
Posted on Oct 04, 2008
D-link DI 524 Router (Quick Router Setup - error: 103
103 most popular error on DLink Modems and Routers.Error occurs when your computer or router is not able to find the internet connection. Reason behind settings of the modem or router.
Try to use :
  • "https" instead of "http" in the URLs.
  • Check Firewall is not blocking your internet connections.
  • Reset your modem or router.
For setting up and configure your router http://support.dlink.com/index.asp and D-Link Router Support for technical help.
Jan 27, 2014 | D-Link Computers & Internet
How to set up? and start workin with it
>I believe you need to hook this up to a modem
>first of all make sure that the modem is on bridged mode to enable the wireless capability of your linksys router
>It's just a plug and play device so it means that you just have to plug it to your modem which is on Bridged mode and open a browser to access 192.168.1.1 to setup linksys
>comments suggestions ratings and violent reactions were greatly appreciated
Sep 23, 2010 | Linksys WRT110 Wireless Router
I have a Linksys 5-port switch connected to a cox cable modem and I'm trying to use it to connect two computers at the same time. Only one works at a time and I have to reset the switch and modem to get...
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
Aug 27, 2010 | Linksys EZXS55W EtherFast 10/100 5-Port...
I have a dlink dir628 router and can not get internet access but can find the access point i got throught the config. but can not get internet through the router wired or wireless but hooked up my old...
if you have one dsl modem & one router means you have to cofig dsl modem in bridge mode and router in dynamic mode.if you have any dout call me 9740575949
Feb 25, 2010 | Computers & Internet
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
When I try to connect my router to my laptop, the 321 error screen appears after about a minute. It says my ethernet cable is not plugged in properly, but it definitely is. Even the connection lights on...
This is a well documented problem with linksys routers. Go to google and type in "error 321 linksys". You will have to manually configure the router as stated on the linksys forum posts.
Jun 05, 2009 | Linksys WRT54G2 Wireless Router
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Linksys router
What kind of internet service do you have, what company?
Sometimes it is important the order that you reset the devices in,
First unplug the "power" only from both the modem and Router, then first plug in the modem, wait for the internet/online light to go solid, depending on the device may take 30-60 seconds, then plug in the router to power, wait 30 seconds try the internet, and make sure to try a different page then just the home page.
Dec 09, 2008 | Linksys Wireless-G WRT54G Router
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Westell 6100, to smart for job!
you have to activate DHCP in order to make the westell a modem "dummy" (it will just act as a bridge to the internet from your Linksys.
on the modem, go to a setting that is similar to "Public Routed Subinterface". dont choose anything that says "proxy" or "NAT".
find out the Linksys's IP adress by looking at the devices or computers list on the Modem's home page.
Now, put that IP adress on the setting "Public Routed Subinterface" (or similar). If it has a "Subnet Mask" option, type in "255.255.255.0". Also, If it has a "open firewall" or "bypass firewall" option, enable it.
If it does not have a firewall option, disable the firewall on the MODEM, not the linksys. This is also called DMZPlus mode.
If the above does not work, go here on the entire instrucitons for setting up the linksys with your modem.
Aug 20, 2008 | Westell Wirespeed LiteLine 6100...
Linksys Wireless-G WRP200 Router Logo
107 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
