Question about Eureka 431A Optima Bagless Upright Vacuum
Eureka bagless uno 12 amp ( green)
Brush runs, no clogs, filters cleaned, debris no longer collects in the
" easy empty cup "
  • jnk2008 Oct 23, 2008
    vacuum runs but no suction, brushes spin.
  • 22 Answers
Buckaboo, you say the debris no longer collects in the cup? Does that mean you don't have suction as well?
The brushroll has it's own motor so the brushes spinning doesn't necessarily mean there's not a problem with the wiring, the switch, or the motor.
Assuming you haven't inadvertantly set the selector switch to floor when you wanted to use the hose or vice versa, try the following.
Start with the motor/impeller first. Take the dust canister off and turn the vacuum on. It doesn't matter if you turn on the brushroll or not as you're looking for suction.
With the vacuum on feel for exhaust out the front of the motor (by the secondary handle on the bottom. Also put your hand over the area where the dust canister sits. You should feel strong exhaust and suction respectively.
If not, then you should take it in to a technician as going any further requires disassembly.
If you feel there's enough suction, then it may be as simple as a clog. This vacuum has a particularly easy air path to check. There's a clear snap-on door on the bottom to check the brushroll and neck. Then from there it's a straight shot through the canister itself before dumping inside and going through the filter. If it's the hose, you can turn the end clockwise to remove it from the body of the vacuum and use a broomstick to clear any clogs.
If it's not a clog or filter then you may try cleaning the seals (one round at the bottom of the canister where the canister mates to the body and a rectangular one in back of that where the dust runs up and into the canister.
Good Luck!
Posted on Feb 03, 2009
My Eureka endeavor nls vacume cleaner will not suck at all. I have taken it apart to clean everything but still nothing what could be wrong with it
HI, it's Jim from Crucial Vacuum!
Vacuum maintenance is a general procedure and requirement for all units to ensure suction. Your Eureka can be easily maintained and by doing so properly you will make sure your unit performs at it's peak performance. The following tips will help your vacuums suction.
After every use, make sure to empty your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged.
It is recommended to wash and clean your unit's filter screen weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours.
Foam and cloth filters should also be washed and dried weekly, by following the same steps from cleaning the filter screen. Do not use any soap, dishwasher, dryer or washing machine to do so. Allow your filters to air dry for 24 hours before re-installing them in your Eureka.
Replace your HEPA filter and belts every 6 months. Last, make sure to clear your roller brush of any tangles hair strands or debris monthly and to replace at least every year.
You can purchase direct your Eureka replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka.html?limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Nov 05, 2014 | Vacuums
MAINTAINING A EUREKA BAGLESS VACUUM
Helo Reader,
You can purchase replacement parts directly from Govacuum with an exclusive 11% discount coupon only for Fixya.com readers, use code: FIXYA11 at checkout to avail the offer. We also offer free shipping over $35.
Eureka Style U Belt - https://www.govacuum.com/products/eureka-u-extended-life-belt-set-of-2
Eureka HF7 Filter https://www.govacuum.com/products/genuine-eureka-premium-hf-7-hepa-filter-with-arm-hammer-61850c-1-filter
Hoover parts - https://www.govacuum.com/collections/hoover
Jeethu
Govacuum Team
https://www.govacuum.com9_17_2017_3_49_04_pm.jpg
Oct 04, 2014 | Eureka Altima Upright Vacuum Model 2996AVS...
Dyson dc 40 loses suction
Hello, this is Ava with Think Crucial.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 20, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Eureka 5892 BVZ-1 vaccum has very little suction. I checked hoes and emptied cup, and made sure filter is not dusty.
There are probably three filters, one on the back of the dust collection bin, one under the dust collection bin, and one where the air exits the vacuum, check all three.
Gary
Mar 04, 2011 | Eureka 5892AVZ Bagless Upright Cyclonic...
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
I can not get the dirt cup out to empty it.
Just slide the dark gray release tab, located just below the cup, all the way to open position, and then pull the Easy Empty Cup toward you.
Jul 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
The suction on my eureka optima stopped working but the roller still works, what might i do to fix it?
Hi there. Most suction problems are due to a blockage. Start with the base and look carefully for debris that is stopping air flow. You may have to remove the base plate to get to the problem. I am including a link to the manual for your machine. look on page four so see how to remove the base and check for blocked airways. http://www.eureka.com/service/manuals/75287_eng.pdf
Aug 19, 2009 | Eureka 431A Optima Bagless Upright Vacuum
My eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Jun 06, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
No sucking
Could be that the dust cup filter is clogged, part #60958, or the inlet down by the brush roll is clogged.
Oct 01, 2007 | Eureka 402A Bagless Upright Vacuum
Eureka 431A Optima Bagless Upright Vacuum Logo
409 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
