Question about Microsoft Xbox 360 Console
While playing, we get a no signal on TV and xbox starts over
When we are playing the xbox 360 suddenly we get a signal on the TV
screen that says no signal and the xbox 360 starts all over. we have tried
moving the xbox to where is cooler, using different controllers but no luck.
What should I do???
  • 4 more comments
  • stu1234 Oct 15, 2008
    my xbox sends no signal to the tv, but still appears to be working. Earlier the colours on the screen changed and now nothing at all on the screen.
  • gregzy3 Oct 24, 2008
    I have exactly the same problem, the game played normally except the screen changed colour and then the dashboard colour scheme changed and now no matter what input i use to plug intomy samsung HD tv no picture is visible sais mode not supported, any ideas? was basically resigning myself to sending the beast away to be fixed :(
  • Anonymous Nov 22, 2008
    i got da same problem, first it was an error 74, then there was no picture at all, im about to beat this 360 with my hammer!
  • myost85 Apr 15, 2009
    was playing re5 when all these purple colors appeared, turned off conslole and turned back on no signal, tried two cables still no signal, xbox still syncs with controller and displays no codes but still no signal. help.
  • 7-7-7 May 03, 2009
    no red lights on the console. i have checked every wire and cable, they are in the correct places. i am still getting the same message ''no supported signal'' on tv. i have even tried plugging my xbox 360 into different inputs.
  • bysk May 11, 2010
    Are there any lights showing up on the system? Red lights?
  • 35 Answers
Check that the wire in the back in secured properly there might be a fault with the wires
Posted on May 06, 2009
    Problem Solver:
  • 14 Answers
Have you tried using a different set of cables? The problem is either your xbox or the cables, i'd recommend borrowing another cable from someone and seeing if it'll work then.
If it doesn't work, then your xbox is gone. Sorry
Posted on May 07, 2009
Had the box 360 60gb for 3 weeks. Been running it via the tv scart option with yellow wire and audio red & white. Worked for 3 weeks until during playing Assassins Creed Brotherhood the screen went...
Maybe someone stepped on your cables try getting different cables.
For example if your tv is hd get a hdmi cable or buy another set of those cables.
Maybe it will help.
Jan 04, 2011 | Microsoft Xbox 360 Console
Graphical issues
A sign of the RROD send it to repairs.
Dec 10, 2009 | Microsoft Xbox 360 Console
When I turn on xbox 360 it blures with lines down the screen
Your AV cable might be bad or you have an Hd Tv & dont have your Video setting set up right on your Xbox 360 go to http://www.xbox.com/en-AU/support/xbox360/digitalmedia/viewvideo.htm
Sep 05, 2009 | Microsoft Xbox 360 Console
My xbox is unable to read any of my games.
prolly the laser you can buy one on ebay for 15-20$ or buy a new dvd drive for 50$ if you replace the laser you will need to solder for the dvd drive all you will have to do is open the case and pull out the broken one and put in the new one
Jul 31, 2009 | Microsoft Xbox 360 Console
Xbox 360 no picture but sound, works on another HDTV
did you check to see if the av conponent was on tv/hdtv?
Nov 15, 2008 | Microsoft Xbox 360 Console
Xbox 360 will not send a picture signal to TV
sounds like you have a graphics card problem with the xbox 360. possibly loose/damaged electrical connections between the GPU and the motherboard which has caused the xbox to not display a picture. with this being a Hardware problem i would suggest calling the Xbox customer support, numbers can be found on http://www.xbox.com/support call up the support team and explain your problem.
I believe that microsoft will ask you to send the Xbox direct to them so they can fix the problem for you, it shouldnt take long to correct !
hope this helps
Oct 29, 2008 | Microsoft Xbox 360 Console
Xbox 360
it could be overheating, try puting a fan under the xbox 360 and then start it. also if you are using an hdtv try using just a regular tv.
Jun 29, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
496 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
