Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
LTE 6234AN3 when the drying cycle has is at the end the dryer will not shut off
  • rich1944 Oct 13, 2008
    Tried your solution and discovered that the dryer does not produce any heat. I think the thermostat needs replacing ! Do you think the thermostat and the timer should be replaced?
  • 750 Answers
Hello Rich
Welcome to Fixya,
You said, when the drying cycle is at the end the dryer will not shut off!
This really sounds like the timer mechanism's is failing.
Try to unplug the dryer or if you can not reach the plug power off the breaker for 5 minutes.
If this resets the system then it was a glitch in the electronic system and you should be fine.
If it does not remedy the problem then it sounds like the timer mechanism's is not shutting down and needs replacing.
Let me know!
Please remember to leave a rating!
Posted on Oct 03, 2008
  • Neil Golan
    Neil Golan Oct 13, 2008
    If you have heat now then I think the timer is the problem!
    Let me know what is the result.
  • Neil Golan
    Neil Golan Oct 14, 2008
    Hello Rich,
    Here is what the repair manual says to check if under stand it yourself good, if not uou will need service.
    tell me what happened...
    Please leave me a rating on our site!
    The timer is the source
    for power to the motor and if the timer contacts are defective, there
    will be no power getting to the motor. Since the wiring is different
    between brands and models, you will need to refer to your wiring
    diagram for terminal locations. Once you have located the correct
    terminal for the motor operation, you will need to turn on the dryer
    and check for 110v from the timer terminal for motor operation and the
    chassis ground. If you have the voltage, the timer is most likely okay
    and the problem is elsewhere. If there is no voltage, the timer is
    defective and must be replaced.
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ... > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ... > Manage My Life > Questions
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from
Feb 08, 2016 | Whirlpool Dryers
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ... > Manage My Life > Questions
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ... > Manage My Life > Questions
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
My roper dryer works fine, it heats and the timer advances, it just wont shut off at the the end of a timed dry or auto dry. What do you think?
A timed drying cycle uses the timer alone to stop the drying cycle. Once it times out like an egg timer a set of contacts open up shutting off the dryer. Or a set of contacts closes to activate a relay which in turn shuts off the power.
Auto dry usually uses a moisture sensor which would do the same thing as the timer. Once it doesnt sense moisture in the load for a predetermined time it in turn triggers a relay which shuts the power off. Some auto dry cycles just use the timer alone and guess-timate the drying time by the selection.
If yours does not use a moisture sensor then most likely it is your timer/cycle switch. There may or may not be a relay involved.
Most dryers have a basic wiring diagram on the inside somewhere on one of the panels which will help.
Since yours is acting up on both cycles Im guessing you have a bad relay or connection to that relay somewhere IF it uses a moisture sensor.
Dec 17, 2014 | Roper Dryers
Electric Dryer Shuts Off
During the auto-drying cycle, the moisture sensor could be the problem.
If it also shuts off prematurely during the timed cycle, the operating thermostat could be turning the heaters off before the machine reaches operating temperature. Another possibility is that the operating thermostat does not turn off the heaters at all. When the machine heats up, it gets too hot and the high limit thermostat turns the dryer off.
Apr 20, 2010 | GE DWSR483EB Electric Dryer
try timed dry to see if it does it
Apr 19, 2010 | Kenmore 63942 Dryer
My dryer will automaticall start the auto dry
appears that timer is not timing out or shutting off at end of cycle.correct ,the timer itself appears to be the problem.
Oct 16, 2009 | Dryers
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Driyer does not shut off runs continiously
Yes this is a timer problem. The timer is easy to replace but can cost around $100. You might try a used appliance store and see if they have a used one.
Jun 13, 2008 | Dryers
Does the dryer dry fine? If your dryer is taking too long too dry you might have a venting obstruction that is not allowing the dryer too sense that the clothes are dry so the timer won't advance. Try disconnecting the vent from the back of the dryer and dry a load unvented and see if the timer advances.
Jun 11, 2008 | Maytag SDE3606A Electric Dryer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal De
