Sony MHC-GX250 CD Shelf System
Problem for Sony MHC-GX250 CD Shelf System
Odd scratching or grinding noise
By Kevin1228 on Oct 17, 2008
I have a sony MHC-GX250 that was skipping on songs, so i opened it to clean the laser heaad. When i put it back together, everything went well. I tried to play a cd, and it jsut keeps on reading it over and over, and makes scarthing or grinding noises. I opened the case again to see what was causing it, and it looks like there is a white plastic piece that attaches to a black part that holds the cd from above and spins with it. When it tries to spin up, that white and black piece start spinning wildly, and move the disc out of alignment. It seems i didn't put that little white piece and the black piece on correctly. if I was clear, this is all taking place about 2 inches above the laser(I.E. on the CD part of the system). We contacted sony, and they want more to repair it then what we paid. I need this CD player to be working by monday, tuesday at the latest. It is used for our school's choir practice. I have not had any other problems with it at all. If anyone wants a picture of it, I'll try and put one up on my site for everyone to see.
Comments:
Oct 04, 2008
- Again, This needs to be working by tuesday at the latest!
Oct 17, 2008
- It happens regardless of any cd or dvd.
Oct 17, 2008
- It happens with any cd or dvd. The problems with loagin the cd i think.
Oct 17, 2008
- I meant to say the problem looks like its with loading a cd.
Oct 17, 2008
- I have everything open and i am staring into the laser hear assembaly(with it off, of course.). How do i disengage that little black cover that goes over the laser? Also, there is a big black piece of plastic sticking out right over it. Any ways to get around it?
@coolguy: I think that may be the problem, i just need to get access to the laser head.
Oct 17, 2008
- Also, that picture you posted, is it of this particular cd player?
Oct 18, 2008
- There is a tiny momentary switch that looks like it slides the cover on and off when the try opens and closes. i would try that, but i don't exactly want a red laser pointing into my eyeball and blinding me.
Oct 18, 2008
- I couldn't figure out how to get to the laser head.
Oct 18, 2008
- I am going to take a video and a few pictures of what is happening, and I'll put out a link to show you. I am extremely reluctant to go and have this repaired, since I am positive that its a simple mistake somewhere.
Oct 18, 2008
- I'll tell you for sure that there are no magnets in the cd assembly except in the motors. I am uploading the photos now, i'll do a video later
Oct 18, 2008
- Hmmm....Now I see what you part you are refferring to, but I think i have a bigger problem!!! I don't see a magnet anywhere on my cd player. Is the magnet part of the black piece or the white piece?
Oct 18, 2008
- Uploading picture as we speak.
Oct 18, 2008
- ok. SOrry it took so long. My website's DNS was having a few issues. Heres a link to the pictures. sorry they aren't very good quality.
kevincroissant.com/fixyaimages
Oct 18, 2008
- i never got a reply and i am still confused!!!!
Oct 18, 2008
Oct 18, 2008
- Descirbe the magnet a bit more. is it like a rod? There was never a magnet there, or one now.
Oct 18, 2008
- huh? I never rated you yet. I didn't see where to do it this time.
Oct 18, 2008
- Found the exact poblem! a magnet that held everything together had fallen out and was making everything spin out control!
Best Solution
posted on Oct 18, 2008
Very Helpful)
electech1
Rank: Guru  Sony Home Audio  Expert
Rating: 88%, 634 votes
that white piece sounds like the magnet that goes above the black little disk that holds the cd in place by the magnet wanting to connect to the top of the cd holder and motor (the magnet presses the disk on the holder to prevent slipping )
need anymore help?
Comments:
Oct 18, 2008
- this is the piece that has a magnet in it
Oct 18, 2008
- sometimes the magnet just sets on top of this piece
Oct 18, 2008
- sometimes the magnet is glued on top
Oct 18, 2008
- can you upload a picture of the white piece?
Oct 18, 2008
- ok sorry I had to get something to eat
that piece goes on the top part that holds the cd , and there should be a little round piece of metal ( the magnet ) that fits in the center of that piece then that white piece goes thru the top and the black disk connects to it , just like my pic except your white plastic piece is on top
Oct 18, 2008
- why did you rate me like that if you want my help?
Oct 18, 2008
- well do you still want my help? you have to change it to helpful otherwise thats like saying "thanks anyway but you want other help" so I can't help you till you change it
I work on these all the time and I wiill stick with you untill you want to quit or its fixed
Oct 18, 2008
- well if I help you fix it , then you can't rate it as fixed either
ask me from my profile then I can help again
Oct 18, 2008
- examples
Oct 18, 2008
- the magnet in these pieces prevents it from jumping and slipping
Rating Locked! (?) Kevin1228 has rated this solution as Very Helpful
Solution #2
posted on Oct 17, 2008
Somewhat Helpful)
coolguy008
Rank: Wiz
Rating: 83%, 622 votes
HI,
Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.Also check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
These are the only possible home remedies if you still face the problem then you will have to get it repaired.
Comments:
Oct 18, 2008
- The best solution is to get this repaired.
Solution #3
Somewhat Helpful)
kevin000
Rank: Master
Rating: 78%, 312 votes
is that happening playing specific cd or dvd ... or happen with all of them.
did you try cleaning the lens using the lens cleaner.
Popular Solutions for Sony MHC-GX250 CD Shelf System
Questions and Unsolved Problems for Sony MHC-GX250 CD Shelf System
Do you recommend Sony MHC-GX250 CD Shelf System?
Answer
Answer
want to know how to record from a CD to an audio cassette
Answer
At low volume the Right Channel Speaker cuts in and out. When i turn the volume up it stops. Ive... (More)
Answer
how do i reset the stereo MHC-GX250
Answer
I got this system off Ebay. It is the MHC-GX250. It played fine for about an hour. I put a CD in and... (More)
Answer
I get nothing on AM...FM works fine and so does everything else. It used to work, now nothing...any... (More)
Describe your Audio Shelf Systems problem:
Related Products & Issues:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Audio Shelf... Experts
Top Audio & Video Equipment Repairmen
in Newbury, OH
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
