Question about Garmin StreetPilot C320 (010-00401-00) GPS Receiver
Dead battery- willnot charge with supplied charger
My c320 has a dead battery -- will not charge with supplied garmin charger even after 48 hrs on charge
  • Anonymous Dec 13, 2008
    My garmin street pilot c320 will not turn on also.
  • davidhirtle Jan 12, 2009
    Yes I do. I have not seen any sign of power at all when I hit the power button even after 30 hr charge attempt.I also tried the reset button to no avail.
My c320 has a dead battery-how to change?
Posted on Oct 04, 2008
اليمن
Posted on Oct 03, 2008
SOURCE:
I put a new battery in my camera charged it. Used the camera till the battery ran down. Now it won't charge . This is the second battery I've bought every time I try to charge it won't charge.
It takes over 7 hours to charge, so did you leave it charge overnight?
But while the original battery is chargable, disposable replacements are not. Here is what the manual says:
The supplied battery is a Li-ion battery. It charges while in the camera using the supplied charger. The camera can also use a Duracell CP1 disposable Li battery, which has the same form factor as the supplied Li-ion cell. HP claim the Li-ion cell will provide power for approximately 200 shots under "average" use and 100 shots with "extensive use of the LCD and flash".
Charge time for the battery using the supplied charger and in-camera charging is 5-7 hrs for a fully depleted battery. In the optional docking station, charging takes 2.5-3.5 hrs and using the optional rapid charger, charging takes 1-2 hrs. ... }
http://www.bobatkins.com/photography/digital/hp707.html
Aug 08, 2010 | HP Photosmart R707 Digital Camera
Garmin c330 won't power on even when charger plugged in
Find the wall charger - most any usb mini that has the right out power amount [ do NOT over do it or you can burn the unit up] - Anyway - try the wall unit - if after 48 hours it refuses to take a charge - get a new one from www.tigerdirect.com for well less than the price of a battery.
Good luck
Gary
May 22, 2010 | Garmin StreetPilot C330 GPS Receiver
Nuvi 200 when charging never says charging complete .
HI, I have the same NUVI. Mine does the same. I haven't had any issues with it. It still charges fully when I unplug it.
Jul 25, 2009 | Garmin nuvi 200W GPS Receiver
Charging a garmin nuvi 255w
From dead flat it takes about 9-10 hours
do not leave on charger for more than that otherwise you will overheat and burn it out.
After each use recharge for about 3-4 hours depending on whether the unit has been used for that lengthyof time
Jun 30, 2009 | Garmin nuvi 255W GPS Receiver
Battery replacement now ca't find satellite Garmin c320
More than likely when you reinstalled the gps receiver (the board with the wires connected to it) at the top of the receiver you did not position it properly. If it is not positioned properly it will not receive a satellite signal
May 06, 2009 | Garmin StreetPilot C320 (010-00401-00) GPS...
Low battery, won't charge
connect the garmin to your computer using the usb port. It will start charging then. For some reason when the battery goes dead in this unit the only way to charge it is with computer. the car adaptor will not work once the battery gets real low.
Apr 16, 2009 | Garmin StreetPilot c340 GPS Receiver
Dead unit
My Quest2 has a short in it that drains the battery even when it is turned off. But the battery lasts normal 15 to 20 hours when fully charged and unit is on. Whenever the battery is completely dead, I have to place it on the charger for a hour or two before the unit will even start even though it is plugged plugged in. The battery can be replaced by the staff at batteries plus for under $60.00
Oct 12, 2008 | Garmin Quest GPS Receiver
Battery`s dont last
Warp the batteries in few plastic bags.
Place them in the freezer for 48 hours.
After 48 hrs,it them air out for another 48 hrs,
The expand and contraction may help breaking the salt bridge.
Mar 15, 2008 | Icom IC-R10 Handheld Scanner
Dead Garmin
I had the same problem - worked great for a year and yesterday was totally dead - not a hint of powering up.
I pulled the blue front "frame" off and held the reset button for about 5 seconds. It powered back up and works like a champ!
-Johnnyx
Feb 13, 2008 | Garmin StreetPilot C320 (010-00401-00) GPS...
Garmin StreetPilot C320 (010-00401-00) GPS Receiver Logo
352 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
