Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu siemens amilo laptop
When I switch it on it says Adisk read error occurred Press Ctrl+Alt+Del to restart but the name comes up but goes back to same instruction
  • Anonymous Oct 25, 2008
    Same problem here with amilo li2735. B#@% thing is only 5 weeks old!
  • 63 Answers
Do you have any cd's in the cd drive or any floppys in? it could also be a usb flash drive or external hard drive. If its none of those check the bios settings and see if your hard drive is in the boot order. If its still doing it after that I would say it could be a corrupted hard drive or corrupted os on the hard drive. If all else fails try to do a system recover using the recovery cd's. if that fails its a bad hard drive.
Posted on Oct 03, 2008
That usually means that your HDD (hard disk drive) is dead and its no longer readable. By start up pres F2 normaly thats the button normaly that will lead you to the BIOS go on overview and see if your HDD is still detected by BIOS. You can also try to see how bed things are by inserting a rescue disk on your CD/DVD drive press F12 when you do that and try to diagnose the problem. You can also try to reinstall your OS(operation system) sometimes that also helps but not in many cases. I Hope that help you a bit.
Feb 13, 2014 | Acer Aspire One D255 Laptop
Amilo pro v3515
You may try to add some more memory. Youtube and viewing video may require more memory to work with specially when some other apps are currently running
Good Luck
Tedmac
Oct 13, 2013 | Fujitsu Siemens Computers & Internet
"A disk read error occurred Press Ctrl+Alt+Del to
Most likely the hard drive is failing, run diagnostics on the hard drive if you have a resource CD. Or you can download them from support.dell.com
Jul 21, 2011 | Dell Latitude C810 Notebook
Just bought a used dell alienware m15 laptop. I7 intel core I turned it on once... and it booted extremely slow!!!! Than it would not open any apps... or reall do anything besides move the cursor around...
I would do a complete operating system reinstall.
The M15x uses a program called Dell Datasafe Local Backup for factory restores. You can access this program from launching the application from within Windows (it is on the Start Menu), or by using the F8 Windows Boot Options menu. Press F8 after the iniital POST screen (Alien Face), but before you see the Windows logo on the screen. There should be an option to repair Windows, which will launch you into a recovery mode that allows you to restore the system. This option is available even if you have uninstalled the Dell DataSafe Local Backup app from Windows (I did, as its constant polling causes stutterin in Blu-Ray playback). Good luck!
Mar 19, 2011 | Computers & Internet
MY LAPTOP WONT GO TO THE START MENU
you need to click ctrl+alt+del hit cancel and it will work :)
Jan 17, 2010 | Toshiba Satellite M55-S135 Notebook
when upower up thecomputer enter in bios setup press del or F2 or F1 to neter in bios setup when u power up.
thenr eset bios defaults settings.
then check your hardiskk is deteted or not.
if sata is enabled then disable then press F10 to save settings.
Jan 07, 2009 | Sony VAIO VGN-FS640W Notebook
Error Message Upon booting up
go to bios and load defaults. if still same thing happens after reboot. Boot from OS cd, on windows etup page, choose "R" to run recovery console. Choose OS. Run CHKDSK /R.
Feb 16, 2008 | Compaq Evo N610C Notebook
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
Fujitsu nightmare
This is because it has not written the system files yet as it has frozen on repair. assuming youv'e set the cd as the first boot device, it sounds like a complete re install is now necassary, but if you get the cd to run you will need to format the drive first then a clean re install.
Jan 16, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
272 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
