Question about Kenmore 63012 Electric Dryer
Kenmore Electric Dryer 110.62922100/Runs but no heat
Hi, I figure the heating element is probably bad, but I am trying to get the back cover off and after removing the screws it seems like the thing is spot welded on. How can I get access to the internals.
Thanks in advance
Ron
  • 1 more comment
  • ronrg04 Oct 03, 2008
    How to get the cover off of a Kenmore Electric Dryer. The model number is 110.62922100
    Trying to get to the heating element.
  • ronrg04 Oct 04, 2008
    Hi again, the dismantlement instructions got me right to the problem. All I need now is the heater part number.
    Thanks
    Thanks for the help. It is the heating element.
  • 360 Answers
Remove the lower front panel. the element is right there with all the access screws and wires. check the thermo relay also known to go bad..................
Posted on Oct 03, 2008
    Genius:
  • 3,422 Answers
egin by removing the end caps found at either end of the console. Lift them from the back, and then pull them towards you. There will be two screws holding the console in place. Remove the screws, and then slide the console towards you and flip it up. You will find an additional three screws at the back of the cabinet top. Remove these and slide the cabinet top towards you and lift it off the unit. Proceed by removing the kickplate. There are two spring catches that need to be disengaged before you can remove the kickplate. Each spring catch is found about four inches in from each side. Use a putty knife or some other thin and flat object to wedge in between the front panel and the kickplate. Push down on the clips with the putty knife to disengage.
Open the dryer door and remove the screws that are holding the hinges to the door. Tilt the door up and pull on it gently to remove it. Continue the dismantling process by removing all the screws you find that are holding the front panel to the unit. There will be door switch screws, ground wire screws, and other screws holding the front panel to the bulkhead.
Reassembling the entire unit is basically the disassembly process in reverse. Replace the front panel of your dryer. Replace the dryer door, and then replace the kickplate. Reattach the cabinet top and then push the control panel back in place and reattach the two end caps.
  • Priya darshan Oct 03, 2008
    Please don't forget to rate or accept the solution
  • Kenmore Master
  • 19,396 Answers
On some model you need to remove the back panel first.
If you post the complete model number I can get schematics and exploded view.
  • 13,433 Answers
When theres no heat check these
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Kenmore 110.82822102 Electric Dryer runs but no heat.
I think the heating element went bad. Depending on your driers layout, you might have to remove the drum assembly to gain access to the heating element. Once drier drum assembly is removed, check and see if there is 220 volts going to the heating element. If there is, heating element is bad, if no voltage detected, the switch in the control panel is faulty. If you're not comfortable trying to check this out on your next step, I don't blame you. A qualified appliance technician would be the better answer especially working around 220 volts. Hope this works out for you.
Mar 10, 2014 | Kenmore 83142 Electric Dryer
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
My dryer doesnt heat. I checked the voltage, and ran through all the diagnostic tests to try to get an error code. Everything works fine when in the test mode. Figuring that all was well i went back to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 17, 2011 | Kenmore 84072 Electric Dryer
My Kenmore 500 Series electric dryer runs, but no heat. Elements never get warm. All thermal sensors show continuity. When I checked for resistance through the elements, I got infinite ohms. Perhaps I'm...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 10, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore elite electric dryer will not heat. I
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer 65512 won't heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 14, 2010 | Kenmore 64742 Electric Dryer
Kenmore elec dryer runs but won't heat up
Can be several problems: the heat element (coil) can be burned out, one of the over-heat sensors could be bad or overheated and did not reset ( this could be caused by poor air movement through the vent ) check your venting for good air flow. Could be a wiring connection that burned and needs repair because of the hi electric current demaned by the heat element. Goodluck, Macgivor
Jan 27, 2010 | Kenmore 64902 Electric Dryer
Pye300ayw electric dryer dryer starts however it wont heat on an
Hi, unplug the dryer, there is an electric element on the back of the dryer, it should be covered with a removable metal cover, remove this cover and plug it back in turn the dryer on if the element does not heat it is probably bad, also check if there is a broken spot or if the element has shorted out, Hope this helps.
Mar 18, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore HE4t Dryer - no heat
The usual suspect for a Kenmore HE that runs, but doesn't heat is a thermal cut-out or the thermal fuse. Although they are a bit more resilient, in some cases the heating element itself could be bad. The way to check: 1. UNPLUG THE DRYER, FIRST. 2. Remove the bottom kick plate on the front of the dryer. 3. Remove the blower fan cover directly under the lint screen. There should be a couple of 1/4" screws holding it on. 4. Directly behind the blower fan cover on top of the blower fan housing are two components. One is the operating thermostat, and the white one is a thermal fuse. The fuse is a one-shot fuse that must be replaced if it is bad. 5. To the right is the heating element housing. There are two additional components mounted on the side of the element housing. The component furthest to the back is the thermal fuse. The one one closest to you is the hi-limit thermostat. 6. Check the continuity of thermal fuse and the thermal cut-out. They both should read a short. Additionally, check the resistance of the the heating element. The element should read something low (less than 20 ohms). 7. If the thermal fuse reads open, replace it. If the thermal cut-out is bad, replace the hi-limit thermostat with it. They are usually sold as a set. If the heating element is bad, you will need to disconnect all electrical leads and remove one 1/4" screw holding the element housing to the bottom casing. Pull the entire element housing from the dryer. Depending on model, sometimes the element slide out of the housing, sometimes you will need to remove a few screws to open it up. I hope this helps you.
May 24, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 63012 Electric Dryer Logo
716 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
