Question about Fanimation Bon Aire White Remote Control - Fan Light - C24
Mika aire remote fan
Im trying to change the direction on the remote acess on the wall, but the fan is not corporating. The fan has 5 buttons Hi, Med, Low, Off Fan Light, and Rev. Fan. The fan is going in the wrong direction. Ive tried pushing the button and then pushing the fan and done both at the same time. There is also a on off switch on the controler and a switch on the wall that controls the fan.
Not sure if this addresses your problem or not, but with my Minka Aire ceiling fans, the fan has to be moving in order to change the fan direction. Turn the fan on (any speed works), then push the reverse button. The fan will speed up to max, then you'll hear the gears switching. The fan will slow to a stop, change directions and get back up to speed in the new direction.
Posted on May 09, 2009
Casa Vieja ceiling fan w/remote; worked well. Then wall switch was turned on/off, chains pulled. Everything working: fan high, med and low, and light on/off/dim - except now fan won't turn off !
The chain pulling and switch flipping causes the simple logic in the remote receiver to become confused. Your only hope for restoring normal operation (short of replacement) is to disconnect power at the source, then remove remote battery and press all buttons to eliminate "stuck button" problem. Reconnect power and test operation using only the remote. If normal, you will have to decide whether to disable pull chains, wall switches, or both. If not normal, you will have to try an infinite number of combinations of pull chains, wall switches, and power on-off to get things back to normal.
Aug 11, 2016 | Casa Vieja Dryers
How does the lighting dimmer work on my remote
The low/med/hi buttons work the fan motor. Push and hold the light button to get the dimmer working. All the light bulbs come on at the same time.
May 25, 2015 | Hampton Bay Dryers
I recently moved my ceiling fan from room to
  • Make sure your wiring is correct. You can try switching frequencys to see if that works. Otherwise, you might need a new receiver. That's just a low-end store brand fan.
Sep 29, 2014 | Dryers
How to reverse fan?
to change the fan from counterclockwise to clockwise get the fan going on hi. Hold the hi button while switching the wall switch from OFF to ON quickly. The fan will switch direction. To go from clockwise counterclockwise just hold down the low speed button until the fan switches direction. This makes no sense but it works only took 7 years to figure out.
Aug 10, 2014 | Hunter 27185 Remote Control
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
Directions to reprogram hunter 952g
You need remote control.
Go to your circuit breaker or fuse box, and turn off the power to the fan you will be programming.
  • 2 Turn the fan's remote control over, and remove the battery compartment cover. Take out the remote's 12-volt alkaline battery, and set it aside.
  • 3 Match the DIP switches inside the remote's battery compartment with the DIP switches on the fan's receiver unit.
  • 4 Reinsert the 12-volt alkaline battery into the remote's battery compartment, and replace the battery compartment cover.
  • 5 Go back to your circuit breaker or fuse box, and turn the power to your fan back on.
  • 6 Press the "Hi," "Med" and "Lo" buttons on the remote control in quick succession. Complete this step within 20 seconds of completing Step 5. The remote is now programmed and ready to operate your fan.
  • Sep 06, 2012 | Hunter Dryers
    We bought a house with Fujitsu Air-conditioners we have no instruction manual on how to use the remote. Im trying to set it to go off after an hour or so. Model No.INDOOR UNIT is, AST12RSJCW Serial No is...
    Switch on by pressing ON/OFF. Press mode button to cool position. for cool and keep required temp by clicking
    Same procedure for Heat. For heat keep +29 and for cool 25 to 22 degree. Press fan for High, Med,Low. If you keep mode in Auto cool and the fan speed will be low and you can't change fan speed.
    Please visit Fujitsu website for further details. Hope my msg is helpful?
    Dec 09, 2010 | Fujitsu Heating & Cooling
    Dryers Logo
    664 people viewed this question
    Top Fanimation Dryers Experts
    Michael Galve
    Michael Galve
    Paul Bade
    Piyal Perera
    Piyal Perera
    Are you a Fanimation Dryer Expert? Answer questions, earn points and help others
