Question about Compaq Computers & Internet
Puting in new hardrrive in a Compqa Presario 7599 do not know were to plug the cable into black or white on momtherbord
  • wsteinm1776 Oct 04, 2008
    250 GB PATA/100
  • evelasco
    evelasco May 11, 2010
    What kind of hardrive are pluging?
    Scholar:
  • 155 Answers
You can try to check the manual here.
Posted on Oct 03, 2008
Why does my new 55 inch Polaroid LED TV display a
bad cable or cable not plugged in properly. Black and white will come out if you have a composite (yellow cable) plugged into a green on the RGB. If you are going composite then you need to plug into the yellow video input.
Sep 22, 2014 | Televison & Video
Need to know how to connect to tv it comes on but in black and white
If you're using composite video cables (red/white/yellow) but your TV doesn't have a yellow jack to plug into, plug the yellow cable into the green "Y" plug instead. If there is more than one set of video jacks on your TV, make sure you're using the first set, usually labeled "Video 1" or "Component 1". If it still comes up in black and white after all that, you may need to look in your TV's settings menu to see if there's an option to change the settings for that port from Component to Composite.
If you're using component video cables (red/white & red/blue/green) make sure the cables are all plugged in to the proper color-coded ports on the TV. Mixing up the video cables can cause the image to show up in black and white
May 12, 2012 | Video Game Consoles & Games
110 line in to light switch. How do you continue 110 line out to other oulets or switches?
Add another line to 120V switch.
To begin, inside your switch box, there must be at least two cables.
Each cable has a black-wire and white-wire and bare ground wire.
If your box has only one cable, then you cannot use that for your junction.
OK, your box has 2 cables.
One cable comes from circuit breaker box. These are called Line wires. There is a Black Hot and White Neutral.
The other cable goes to light. These are called Load wires.
You are going to add a new cable with a black-wire and white-wire
In back of box, the white wires are twisted together and covered with wire nut.
These white wires are called Neutrals.
Add your new white wire to these other white wires.
The switch has 2 black wires. One black wire is the Hot line wire.
Add your new black wire to the switch screw that has the Hot.
Of course the switch has 2 black wires, so how do you know which is the Hot.
Turn light switch off, turn power ON, and test each black wire to bare ground wire.
Tester lights up on the Hot.
Review:
New white wire connects to other white wires that are twisted together and covered with wire nut.
New black wire connects to Hot wire.
Ground wires are connected together.
On your new receptacle, the black wire connects to brass screw, and white wire connects to silver screw.
Screws are color-coded to tell electrician how to wire.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Mar 08, 2011 | Leviton 5634 Dual 1 Pole Switch Decora...
I took apart my Compaq Presario V2630US and I don't know where to plug the cable coming from the screen to the motherboard. The cable contains 2 wires one black the other white each has a female plug that...
Not a problem benpanel.
The cable you're describing is the Wireless Antenna cable.
One Black wire, one White wire.
1) ALL power removed from the laptop. AC adapter (Charger) and Battery
2) Observe Anti-Static Precautions
3) Laptop closed, turn it over, open Battery Compartment facing Away from you.
Open the Mini-PCI Compartment Cover.
(Bottom edge of laptop facing you, in the middle)
The Black and White Wireless Antenna cable leads, plug into the Mini-PCI Communications Module.
(Wireless module)
The connectors are designed so they will only plug in one way, and only to the respective connections.
If you would like the Service Manual (Free) let me know in a Comment.
Regards,
joecoolvette
Dec 12, 2010 | Compaq Presario V2630US Notebook
I want to fit a light and switch into my new workshop. I have a garage type consummer unit fitted and am not sure how to wire in the light.
I answer questions for free.
I know electric wiring.
However I might not understand your problem.
If I do not understand your problem, add a comment with more information and I will respond.
If I understand correctly you want to add a new switch and a new light in your garage.
And you are starting from scratch with no knowledge.
You are starting with a blank wall.
I do not know what a consummer unit is.
Is that a type of light?
Here's a sketch of the project:
We need an electrical receptacle or wall-plug so we can get electricity.
We need to run a cable from the electrical wall-plug to the switch.
This will bring electricity to your switch.
And then we need to run a cable to the light.
Let's talk about how you get electricity from the wall-plug.
The wall plug has a black and white wire connected to each side.
Your cable has a black and white wire.
You connect your black wire with the black side.
Connect white to the white side.
Now run the cable to your switch.
The cable arrives at the switch.
The cable has a black and white wire.
The switch is wired differently than the wall-plug.
On the switch you connect one black wire.
But the white is not connected to switch.
Now we're ready for the cable going to the light.
The cable to the light has a black and white wire.
Connect the black to the switch.
So now you have 2 black wires connected to the switch.
The black wires are on different screws.
And then connect the two white wires together.
So the switch is wired.
Run the cable to your light.
The cable arrives at the light.
The cable still has a black and a white wire.
Your light will have wires -or- it will have screws.
If light has black and white wires, then connect black to black and white to white.
If your switch has screws, then connect black to brass-screw and white to silver-screw.
Oct 30, 2010 | Electrical Supplies
I have a plug outlet that's powered by a three
Red wire is the live wire, black wire is the dead wire, white wire is the earth wire.
Now its the black and the red wire we are to play with. take a two wire cable, let the wires be red and black in the new cable, connect the red and the black cables of the new cable to the corresponding red and black wires of the old cable i.e. the new cable is to be connected parallel to the old cable(the connections can be made by ripping the old cable from any point) now connect a switch to the other end of the red wire. attach the terminal of the bulb to:
1) the the other terminal of the switch
2) the other end of the black wire
Sep 02, 2009 | Christmas Lights Etc Santa's Toy Truck
We have a pair of AKG K270 and I'm puting a new 1/4'' jack the wire colors are black,red and white what wires are the left and right?
I think Red is right and White is left. Black should be ground. The jack is left to tip and right to the next band up the shaft and finally ground on the jack base or body. Hope this helps.
Aug 10, 2009 | Audio Players & Recorders
I had new film put on back window of my 1997 Toyota Camry and I now have a black line going up through the middle and a black line on the side, What is this? I don't feel safe driving. Altha Breininger
your puted the new film your sef or by another man?
if is the second , you must know that the film that is puted isn,t one piece all,
and the man that puted the film have joint together in the midle of your window and in the side the film(films beter, and from your prescription i think you have 3 pieces) so isnt problem, only may obstruct you to beter see from the center mirror that you have in your up right.
Mar 29, 2009 | 1997 Toyota Camry
Monitor plug not working?
Initially, pls check the Master/Slave jumpers. Additionally, pls check that the IDE flat cable is connected right.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 21, 2008 | IBM ThinkPad G40 2388 Notebook
How to use steam iron
Fill the iron with equal parts white vinegar and distilled water. Place an oven rack over your sink and position the iron on top, with the steam vents facing down. Plug in the iron and turn it to the steam setting. Run it until the steam stops.
Feb 23, 2008 | Micro Pro 7599 Iron
Computers & Internet Logo
23 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
