Question about Toshiba 57H81 57" Rear Projection Television
Green Picture I have a 57H81, the picture turned green. Where can I find a green tube, and would I be able to change this myself? Thanks for the help
  • 3 Answers
You can, but it's a hard fix. I'm a repairman, and I don't even like to do this one!
Posted on Oct 09, 2008
My tv looks weird red and green. The people are bright red/orangish and backgrounds are green. The picture is perfect. I already reset. I believe the colors are out. I want to change myself. Can you help.
If the convergence appear to be correct, the next step is replace the fluid in one of the projection TV tubes. You will have to very carefully remove the screen and see into the mirror which picture tube is not clear. All the instructions will be found to fix this, by searching the this website....TvRepairKits.com. Have your TV model number and chassis number near by. Thanks for asking and show a few hands of support.
Jan 16, 2011 | Philips 60PP9202 60" Rear Projection...
Tv comes on for 10 seconds then fades to a green tint then turns completely green for a few seconds than turns off
Symptom shows tv got problem with green picture tube that need to be replaced.
Rear projection tv has 3 picture tubes, red-green-blue to make color picture.
Since its an old model so spare parts would hardly be available and local tv repair shop will help you to arrange required part, if they can.
Thanks.
Apr 16, 2010 | Sony KP-57HW40 57" Rear Projection...
I have two lamps out in my Toshiba 57h81. How do I know what the part number is for the lamps and where can I get them?
Hi, the lamp you talking about ,they are your picture
tube [in projection tv you have tree separate tube 1 red 1 blue 1 green ///if you have one still working
you must have a blue or red or green picture
so you probly have some thing in the electronic circuit ,for your tube heater are defective / and that can be fixed because the
price of these tube are arround 300_ box/each
hope that will help you///verify first the soldering of connector where the wire are connect to the tube to the main board or some resistor blow the heater voltage is 6.3 volt ////good luck ask some one you now he know electronic
Apr 02, 2010 | Toshiba 57H81 57" Rear Projection...
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
The picture is green
your picture tube is wearing out . there is a way around it it will work for a while .you need to lower the drive for the green . on the board on the neck of the picture tube there are three adjustments marked red , blue, green on the front of the tv turn down the color all the way down . normally you would have a black in white picture but now you have a green and white find the screw adjustment marked green and carefully turn it down untill the picture is black in white and your fixed . adjust color back up .... dont do this repair unless you are confortable working around high voltages a wrong move inside a tv can kill you , this adjusment must be made with power on so you can see the picture as your going ... so this may not be for you . use your own judgement ........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 26, 2009 | RCA Televison & Video
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
Picture turned green
It sound like a bad tube there are three tubes red green and blue.
i suspect the blue tube is bad. tubes cost 160.00 plus labor 450.total . sometimes the tubes
can be fixed or the tv tech can adjust the screen voltage on the tube.
good luck thanks jay leadingedgeelectronics.com
Apr 29, 2008 | Philips 60PP9202 60" Rear Projection...
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
