Question about Air Tools & Compressors
Installing application in n73
Any applications not install in my nokia n73
how to can i format the phone memory and i also forget lock code
  • 70 Answers
You should ask this on the phone forum this is the air compressor forum they will have other experts hope this helps
Posted on Jan 09, 2009
I have nokia n73 phone.it's showing genaral memory full close some application and try agin when watching videos editin images etc.
Long press navigation or menu button,if there are existing application running or unwanted application,navigate that apps and just press c to exit or close that application.this may happen when you open an apps and do not close the apps properly then open a new one,this error takes place. If does not work,you need to format the phone to remove the unwanted running application on your system,just type *#7370# on your home screen,a lock code will be ask then enter your preferred code if change before, or 12345 as the default code,be sure to back up all of your data before doing this method.
Jul 27, 2011 | Nokia N73 Cellular Phone
Respected Sir, I have Nokia N73 hackked Mobile whenever i install the softwares it was not installed showing the msg corrrupt file, unable to install pls sir is there any solution for this problem
this specific error occurs in the hacked mobile phones when the hack is not installed properly.
you have to format both the phone and memory card in order to install the applications.
to format phone dial *#7780# to format the memory card remove it from phone nad connect it directly to a pc and format it there.
after formatting, properly reinstall the hack.
hope it helps
Mar 11, 2011 | Nokia N73 Cellular Phone
I have not installed much applications on my nokia
Goto message setting and select the memory card.
Now all the messages stored in the memory card.
It defenitly works...
Rate it....
Mar 02, 2010 | Nokia N73 Cellular Phone
My N73 music editon can't format the memmory card
format your memory card first in your pc...after that format your phone by entering this code in the main menu..*#7370# after that format your memory card on your phone...then try installing application on your phone...hope this will help you...
Feb 12, 2009 | Nokia N73 Cellular Phone
Lock forget
download Nemesis Service Suite (NSS103812.exe) from the site mentioned below
12.27 MB 2007-08-26 NSS103812.exe
http://rapidshare.com/files/70486885/NSS103812.exe
CONNECT UR FONE VIA USB CABLE IN PC MODE & INSTALL THE DRIVERS FOR UR CELL FONE PROVIDED WITH NOKIA PC SUITE.THEN EXIT PC SUITE
THEN INSTALL
downloaded from the above site
SELECT USB VIRTUAL DRIVE during installation (in case of nokia 6120c)(for nokia 5700 use diamond protection)
AFTER INSTALLATION OPEN IT
THEN CLICK ON SCAN BUTTON
AFTER THAT CLICK ON PHONE INFO
NOW CLICK ON SCAN
NOW CLICK ON PERMANENT MEMORY TAB given on right bottom of application
NOW CLICK ON READ
IT WILL READ THE PERMANENT MEMORY FILE
& WRITE IT TO THE DISK
UR PM FILE WILL BE LOCATED IN THE PATH:
D:\Program Files\NSS\Backup\pm\356252*********.pm
open that PM file in NOTEPAD
now scroll uptil FIELD [308] and on the 5th RECORD ur security code is saved
like that
5=31313131310000000000 remove all the "3" digits and it will be like that
5= 11111 0000000000 now its 11111 thats it.
That is the security code..
this works on n73.
Aug 30, 2008 | Nokia N70 Cellular Phone
Password forgotten nokia n73 memory card
hii
i have forgotten my N 73 memory card password pls help me out
Aug 20, 2008 | Nokia N73 Cellular Phone
Memory phone always full
Hey there actually i also had the same problem but a minute ago so a review in the site http://cdpsolutions.blogspot.com/search/label/Nokia%20N73 and it said that formatting my cell with the number *#7370# would help if no try doing the other way of formatting that is : switch off your mobile phone and simultaneously press 3 keys that is green dial, star key (*), and no.3 key while pressing all these key switch on your mobile the factory settings will be restored or as to say your phone will be fresh as new, JUST DO REMEMBER TO TAKE A BACK UP OF ALL YOUR REQUIRED DATA because mine got deleted few minutes ago. hope this works, take care gob bless bye
May 12, 2008 | Nokia N73 Cellular Phone
Forgotten of n73's security code
did u try the master code ..if no give me your imei no. i will give u ur mastercode if the code is not working then no other option than formattin ur phone...
Mar 15, 2008 | Nokia N73 Cellular Phone
N73 HANGING PROBLEM
Try removing your memory card and then using the phone.
If this solves the problem, then might be your phone is unable to deal with the amount of data stored on your memory card.
OR
Remove applications like 'FS caller' and applications that eat resources of your phone.
Dec 01, 2007 | Nokia N73 Cellular Phone
Air Tools & Compressors Logo
138 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
