Will noy print from computer or from manual controls. Have already re-loaded software.
    Genius:
  • 1,250 Answers
Check whether your printer is detecting or not this you can check, go to control panel, open printers, if the printer icon is dark it is detecting
Posted on Oct 04, 2008
My printer will not print in black
Try to find solution in Google
Nov 23, 2014 | Canon PIXMA iP1000
Tip
Fatal error : HPZPRL01.exe while installing HP printer Software
1. Perform System restore:
If the printer software was previously installed on the computer anytime before or even if the original issue was anything else before this error, then try restoring the computer to the date on which the software was working. You can then do add a device from the installation screen. The printer would start working fine as the software would already be available after doing a system restore.
2. Uninstall the complete Software.
Perform L1, L2, and L3 uninstall. Then reinstall the s/w.
3. Insert the CD & start the install, select custom install.
Under options select only "HP Drivers (required)" in order to install only the print/scan/fax drivers. If drivers will be successfully installed, you can add one by one the HP software starting again the installation and selecting Install More Software button & install the software in this order:
• HP Solution Center
• HP Device Functions
• OCR Software
Do not install HP Participation Program or HP Customer Experience or HP Supply.
4. Grant full permission to the system
Right click on My Computer, go to properties\security\Group or user names\ select the customer’s user name & click on permissions. Click to select the Full Control check box under Allow, and then click Advanced. Check both the boxes under advanced window. Click OK & close all the windows & restart the PC. Install the software by following customer install method.
5. Make sure that you have write access rights enabled for the following registry keys:
• HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors\
• HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2\
• HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Print Processors\
• HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Prrint\Printers.
on Jul 03, 2010 | Office Equipment & Supplies
I already try to fn f9 & fn f10 noy working can i down load a software?
need more info. what's the problem you're having? what are you trying to do with Fn+F9 or Fn+F10
Sep 30, 2014 | Computers & Internet
I can not get the printer to print
I am assuming you are trying to print from a computer, not a photo memory card (SD Card).
Try the following things:
- get the manual and install CD if you have it
- use the manual or the menu on the printer to print a test page (if that works then it is probably not the printer)
- make sure the USB-B cable is connected
- Start the Print Manager software on your computer (install it from the CD if it is not installed already, download the drivers from on-line if you do not have the CD)
- Use the Print Manager to print a test page (If this works, then we know the cable works)
- in Control Panel under Printers select the Epson Stylus as the DEFAULT PRINTER
- from the application (MS Word, Photoshop, etc.) try printing and verify that the Epson is the selected printer
If this does not work please provide further details about what hardware and applications you are using and what you are trying to print.
Good luck. Bry
Jan 01, 2011 | Epson Stylus RX580 InkJet Photo Printer
The Instruction Manual for my Digital Photo
You can download and print the complete instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 26, 2010 | Coby Cameras
Error load paper?? but already have paper!!
what i might do is to remove that application using control panel, add and remove software. uninstall the printer software disconnect printer from pc, reboot/restart, go to printers in control panel remove all printers listed, then make sure you have right software for your printer. shut down this time.reconnect printer cable and boot back up. reinstall the soft ware with printer on.
Aug 20, 2009 | HP PSC 2355 All-In-One InkJet Printer
Loading HP scanjet 4800 onto vista
Hi there from Germany - English isn't the best but got the same problem solved so give it a try:
- first connect scanner to computer without having the drivers already installed
- next computer claims driver cd put in yours from XP or select downloaded XP-driver
- reboot
- try if scanner works - sometimes they do already
- if not head over to System management or system control what it's called in english
- choose add device and choose scanner
- now Windows tries to install a xerox-driver - allow this
- reboot
- and now it should work - if not sue hp! (But buttons for direct printing etc. might not be working anymore - except via the software itself - no more via the buttons
Hope I could help
Dec 20, 2008 | HP Scanjet 4400c Flatbed Scanner
How can I print labels?
An Online manual in PDF (Portable Document Format) was installed along with your software. If you already have Adobe Acrobat Reader 3.0 or higher on your computer, your manual is ready to read and print immediately after you install the program:
    1. Click Start
    2. Select Programs (or All Programs)
    3. Select the name of the program you just installed (you may have to Select Cosmi, then Select the program name)
    4. From your program's sub-menu, you should see Manual or PDF Manual.
If Acrobat Reader is not already installed on your computer, you may download the latest reader from Adobe or follow the instructions below to install the version that came with your program:
    1. Click Start
    4. From your program's sub-menu, Click on the Read Me file.
    5. Follow the instructions that are provided to you from the Read Me file on how to install the Adobe Acrobat Reader from your CD.
Dec 19, 2008 | Cosmi Perfect CD/DVD Label Maker
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
