Question about Lexmark C752 Printer
Prints roller smear marks
How can I clean the ink rollers? When I print I get black ink smear mark along the right side of the paper.
    An expert whose answer gotĀ voted for 100 times.
  • 188 Answers
Laser printers do not use Ink. The problem is most likely a defect on the drum, which in this model printer, is part of the toner cartridge. Replace the black toner cartridge with a known good one and test.
Posted on Oct 04, 2008
Ricoh aficio 2075
R u using original toner? if no, replace ori. if yes, r the hot roller in the fuser hot enough? is there any gap between hot roller and pressure roller? toner smear can only be caused by non ori toner or faulty fuser unit. Faulty developer can cause sandy print out
Mar 22, 2014 | Ricoh Office Equipment & Supplies
Black ink leaked on inside of printer.
try to replace the defective cartridge by a new one and see printing test result
Nov 18, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
Replaced the black Cartridge, however, printing is smearing
The fuser must be dirty. Change the fuser. It is also possible that the rollers along the paper path is dirty, so clean or replace the rollers.
Apr 03, 2009 | Konica Minolta magicolor 2400 Laser...
Black roller marks on right side of paper
Sounds like you have a bad fuser assembly if the drum unit didn't solve the probelm.
Mar 16, 2009 | Brother HL-5240 Laser Printer
Royal Cash Register
Hi. There are several reasons for this.
The most common one is not replacing the ink roller on time. If the old roller had felt falling off of it, then it will block up the drum.
The second is re-inking the roller. If you do this, you end up with a sticky mess and a lot of smudging.
Other than that, pieces of paper stuck in the paper path are common.
You should inspect the drum again. This is the little group of rubber numbers that spin around and hit the paper while printing. You will usually find sticky muck on the numbers, and you may have to clean them several times. You need to turn the drum as you clean it. Try to use the gears at the side if they are visible. A dry Q-tip is best, as alcohol may damage the thin rubber. Try cleaning the drum again, and look for any improvement. If itgets better on some numbers, then you are probably on the right track. Also, if you could send me a picture of the bad print, that may help also.
Good luck.
Aug 09, 2008 | Casio Parts Cash Register PC Desktop
Black smear of ink at end of lines
Please load the printer with at least 10 sheets of plain paper then press the start button. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains, streaks or smudges are still present, the printer may need service.
May 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Dirty print
Try to print in high quality paper a thick paper
Apr 22, 2008 | HP LaserJet 1150 Printer
Dirty print
Hi , clean the absorbent below ,open or any hole can the injection can reach to the use ink basin located in the floor of printer.suck all ink with injection and fill in a clean container.
clean the rubber roller and carriage with the obsorbent cotton or clothe.
Oct 15, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Lexmark C752 Printer Logo
848 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
