Question about Quasar VHQ400 VHS VCR
VCR won't record
First of all, my vcr is model VH434. Your form below would not accept that but it is likely important to solving this problem.
We recently converted to digital cable. The tech guy hooked everything up, running the cable through the digital box to the vcr, then to the tv. We can view the tv through the vcr, but have been unable to record anything. The recorded section of the tape is blank, a black screen with an oscillating white band when fast forwarded. I was able to play back a tape recorded before our conversion, so the vcr playback function is still working.
I have checked the setup menu, re-run the channel search operation, set the vcr/tv button and tv/catv toggle both ways, and left power going to the digital box after turning the vcr and tv off. Any other suggestions? The model I own is not among those specifically listed on your site.
Thanks--
  • patandmaryjo Oct 04, 2008
    Thank you both for your ideas. It took us awhile to try all the suggestions, but nothing helped. Is it possible that my vcr cannot read a digital signal? It is about 14 years old...
  • patandmaryjo Oct 05, 2008
    Again, thanks for the follow-up suggestions. It appears we are connected properly. I cleaned the heads as suggested, and set up a record sequence. Again, only the black screen...
    We will probably call the technician who set us up on Monday to see if he has some ideas. It may be something as simple as selecting a certain button on the special remote that came with the digital converter box.
    Scholar:
  • 188 Answers
Check to make sure the cables on the VCR are hooked up correctly. If the in and out are reversed, this might cause your problem. Hopefully it's as simple as that. if not leave a comment and I'll get back to you.
Posted on Oct 03, 2008
  • rich medrano
    rich medrano Oct 04, 2008
    Correct your VCR won't accept digital signals.
    Digital cable means that the signals into the cable box are digital. Not the output. The output should be analog. Your TV wouldn't show pictures if the signal wasn't analog.
    So with all your time and trouble shooting it appears the VCR heads are very dirty and maybe wearing out.
    Problem Solver:
  • 16 Answers
Hi Pat and Mary Jo,
It sounds like your VCR might be trying to record your line input instead of the TV channels and would explain a completely black recording.
The line input is where would connect a camcorder or another VCR, where you would play on one machine and record on your VCR.
Some models have a slide switch on the front that selects the input. Others let you select it from a menu option. Still others automatically select it when the appropriate cables are inserted into the line in connectors.
Let me know if that was it or not. Thanks,
-Vince
  • Vince Patron Oct 04, 2008
    Oops, I missed the part about the digital cable. Your VCR will not record digital signals *directly* but it can record it depending on your converter box.
    You said the digital cable was connected to a cable box, through your VCR, and then to your TV. Are you watching your digital cable by having your TV on channel 3 or channel 4? If yes, then your box is converting the digital signal to a standard TV channel. If this is the case, you should be able to record by setting your VCR to channel 3 or 4, whatever your TV is set to.
    Additionally, if your digital cable box has a video and audio out jacks, then you should be able to connect your VCR to that and record that way.
    Let me know if that helps. Thanks,
    -Vince
How to record vcr to dvd
I have next model up I believe, but I found a manual for yours at: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf
This refers to Line-in recording , but is 98pages so may be entire manual. Check compatible DVD disc types (-R, -RW or +R, +RW). Also if commercial VCR may have some form of Digital Rights Management fouling your attempts. Older VHS prior to DRM, but later ones may have incorporated this. If home record from blank, won't be an issue. Good luck.
Jan 26, 2013 | Magnavox ZV427MG9 DVD Recorder VCR
VCR won't record, just ejects tape
You have not mentioned the make and model number of the vcr. Any way the problem is due to end sensor or related circuit. End sensors are photo diods which you can check the shorting with a multy meter.
Jan 13, 2013 | Emerson Televison & Video
I have a Toshiba DVD/VCR combo and I want to know if i can record a VHS onto a blank DVD disc ?
It all depends on the model of DVD/VCR Combo and what VHS you want to copy.
Pre Recorded VHS are copyright protected so the system won't let you copy them.
May 29, 2011 | Toshiba Televison & Video
How do i record from a vcr tape to a dvd on a sansui dual deck vcr dvd recorder?
If it is a combination VCR/DVD player,they usually can't do it.If you get a separate VCR player from a friend or neighbor,you can connect the VCR output to a cable box input,cable box output into DVD input,or if the DVD recorder has a digital tuner you can plug the VCR output player straight into the input of the DVD recorder.DVD recorders REQUIRE some form of digital input.That is why you need to route a VCR player through a cable box or the DVD recorder needs a digital tuner.If you are not sure if your recorder has a digital tuner,call sansui,they will know.I tried to find Sansui home and I found everything BUT DVD/VCR.If you have a manual it will be in there,or it may have a phone number on a label(back or bottom probably)of the unit.Good luck!Greg If you want to send me your model number,I will research it further too.It is up to you.
Aug 06, 2010 | Televison & Video
DON'T HAVE MANUAL WITH INSTRUCTIONS TO HOOK UP MY GO VIDEO DVD
If you follow this link, you will be able to read the manual in PDF form. this if for the DVD Recorder+VCR 3840.
http://dl.owneriq.net/a/add7dac4-c0aa-4bda-bf84-e9b0903a9fd6.pdf
Nov 21, 2008 | GoVideo Go Video VR3840 DVD Recorder/VCR
VCR won't record at programmed time
Check the clock to make sure the AM and PM setting is correct.
Oct 08, 2008 | Sansui Televison & Video
Sanyo VCR - further info required
Hi, as stated on other post, VCR cannot be programmed storing sat channels in memory, you can get only a unique sat input channel on VCR.
You can only record from the channel that is currently been received on Sat, you can even use VCR timer, but you cannot store Sat channels into VCR.
all you do is connecting the sat box output to VCR, and VCR will see the SAT box as input, or line 1, or AV1, or external, or something similar, depending on the model.
You cannot program VCR on sat channel, you will need to leave sat box on the channel you want to record, it will be the same on a DVD RW.
Regards
Sep 09, 2008 | Televison & Video
VCR won't accept new recording tape
I asked earlyer but i can't find my questin that was submitted earler today i gave you my email address with no results. I want to know where the nearest tv vcr reparemand is to Spencer okla my email is davidcurle@sbcglobal.net and my phone No.is 580-782-2888 My mother is moving to Spincer Okla. and needs her vcr forward and reverse fixed,in her emerson tv/vcr combo
Apr 02, 2008 | Emerson EWC1902 19 in. TV/VCR Combo
Quasar VHQ400 VHS VCR Logo
1,596 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
