Jumbled numbers and text
When i am typing on my laptop some of the letters appear as numbers
  • buthy Oct 04, 2008
    Absolutely brilliant, after many frustrating days my problem was fixed in 2 minutes. I cannot thank you enough. It may have only been a small problem to some but it was one I couldn't fix.
    Scholar:
  • 155 Answers
Look for the numlock light somewhere near the keyboard. It's the light with a drawing of a lock with a 9.
If it's lit up. turn it off by pressing the numlock key.
Turning it back on will activate the number keypad (consists of 9-11 keys in the middle of the keyboard). So instead of getting letters, numbers appear.
Hope this is your case. Kindly rate me if the issue got fixed.
Posted on Oct 04, 2008
  • Rachelle Aviles
    Rachelle Aviles Oct 04, 2008
    No problemo. It's really a tricky one. Good thing it's not something else. Thanks for the vote.
Tip
How to use Blackberry as a modem to acces internet?
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
on Dec 05, 2009 | Cell Phones
While typing some of my letters randomly appear in other parts of my text
I think there is a problem with your mousepad. It has become too sensitive even if you are not touching it. You will need it checked by a tech.
Dec 20, 2012 | Toshiba Computers & Internet
I have a Lenova laptop with WIndows 7 in it. I face an issue while typing using the keppad of the laptop. All the letters gets jumbled while typing and also sometimes the numbers I type dont appear...
1. you have a possible loose or bad keyboard and it needs replacement.
you will have to have a laptop tech look at it and replace the the key board.
Jul 14, 2011 | Computers & Internet
Spilled some soup in my spacebar then i took it out after i put it back all letters are jumbled. i got acer aspire 1 notebook. help pls!
The keyboard is faulty and has electrical faults that is causing the jumbled letters.
To test the laptop is functioning correctly connect an USB keyboard to your laptop and check to see if the USB keyboard types correctly. If not then the laptop has a serious fault and possibly needs a new motherboard.
If the USB keyboard works OK the you need to replace the laptop's faulty keyboard.
You may be able to get a replacement keyboard from this WEB site.
http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Apr 25, 2011 | Computers & Internet
Repeating letter on viewed webpages and while typing
install powerful antivirus, if not work change the keyboard
Nov 26, 2009 | HP Pavillion ZV6000 Notebook
Acer Aspire One and MS Office 2007 Powerpoint issue
this sounds like a version number problem otherwords check the type face you're using and make sure that one is installed on the other one, MS will sometimes use a compatible font if the font is not found and yes it looks jumbled
Jun 14, 2009 | Acer AOA150-1690 Aspire Notebook
The letter w is appearing after every letter I type
I am assuming you are using XP and not Vista, follow these instructions to check the keyboard
Go to Start/Control Panel/Regional and Language Options/languages/settings
Look at the top drop down choices and make sure the keyboard input text is in the language for your country
Vista is a similar operation. Just follow your nose
Dec 10, 2008 | Computers & Internet
To form a jumbled words
Using VB as an example
Dim intLength as Integer
Dim y as Integer
Dim arrOut( ) as String
Dim TempLetter as String
intLength=len(text1.text)
ReDim arrOut(intLength)
Randomize
dim boolDone as boolean ' flag to track unfilled positions
Write a loop that gets each letter from text1, then choose a random number from 1 to intLength
Get the existing letter, then put it into a different position in the arrOut, based on the random number. If something is in that position, try again:
for y=1 to intLength
tempLetter = mid(text1.text,y,1)
boolDone=false
do while boolDone=false
r =CInt(Int((y * Rnd()) + 1)) 'Get random # from 1 to length
if arrOut(r) ="" then 'see if spot has been used
arrOut(r) = tempLetter
boolDone = true
end if
loop
next 'get next letter in text1
text2.text=join(arrOut,"") ' concatenate arrOut, no delimiter.
Hope that helps.
Jul 16, 2008 | Computers & Internet
Computers & Internet Logo
454 people viewed this question
David Payne
David Payne
