Question about Apple iPod MA446LL/A MP3 Player
Ipod 30gb black
My ipod is plugged into my computers usb connection and my ipod keeps flashing " Do not disconnect." I tried to power it up but nothing happens. The screen remains the same with the Do not disconnect". Was flashing at first now it is just stays still. Help please.
I have a 30gb silver. I pluged into Mac and it did not show up in Itunes. I pod said do not disconnect and it had a little lock on the screen in upper left hand corner. Tried everything including shutting down Mac and disconnecting. IPOD still on and Do not Disconnect still shows up when not connected to computer.
Any suggestions
  • 21 Answers
Hold down the middle and menu buttons at the same time for about 10 seconds. this will restart the ipod.
hope this helps and good lcuk!
Jaxon
Posted on Nov 23, 2008
My ipod dosen't work on my compute
disconnect the ipod from your computer, restart the computer and connect the apple usb cable to ANOTHER usb port on your computer and it should work.
Sep 30, 2009 | Apple iPod MA446LL/A MP3 Player
30GB iPod video, connected it to a USB charger, now it's screwed.
Few months ago i have same problem with my apple ipod classic 30GB.
My USB cable is short so computer show that, USB device canot be recognized. I haver replaced my cable. Problem will be in USB slot of ipod.
Replace cable. Problem will be solve.
Sep 23, 2009 | Apple iPod MA446LL/A MP3 Player
I have a ipod 30gb the sound is not good and i
You may need to apply the 5Rs. See here.
Try another cable if you can, to check the charge. Or try charging it with an ac adapter charger, if the computer isn't working well.
In fact, try plugging it into the back usb port of a desktop instead of the front, unless you're using a laptop. Some usb connections are powered off the motherboard, and don't have as good a power source as others.
See also here and here.
Make sure you sync all the songs to your computer first, so you don't lose them....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 03, 2009 | Apple iPod MA446LL/A MP3 Player
I cant put songs on my 30gb ipod
try plugging it out and resseting it by pressing menu and the middle button for 10 seconds or something like that the plug it back in to see if itunes detects it
Jun 30, 2009 | Apple iPod MA446LL/A MP3 Player
Have problems with 30gb ipod. it has a DO NOT Dissconnet message but its not connected to the computer. i try to connecting it but it also does not recognize it.
wait until the battery is weak and then connect your 30GB Ipod to your computer, on your computer, first open your itunes program and plug in back your IPOD...
Jun 19, 2009 | Apple iPod MA446LL/A MP3 Player
My 30gb ipod is locked
restore your ipod, it will solve the problem.
Here is the REAL solution. Ending ipodservice.exe will NOT WORK.
1) Plug your ipod into the computer using firewire or USB.
2) Open MY COMPUTER
3) Wait until the ipod shows up as a drive letter
4) Right click on the ipod drive letter and do a ' quick format ' (Now the ipod is just a plain windows hard drive)
5) When it is complete, run the ipod updater and do a Restore. This puts the ipod software back onto it
6) Remove the ipod from the usb or firewire port, plug it into the wall power supply and allow it to finish the update
If I've helped one person, then I'm happy.
Jun 09, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod 30gb black
hold the menu and center button for 25 seconds.
That will reboot it without damaging your data.
Jun 26, 2008 | Apple iPod MA446LL/A MP3 Player
My ipod will not charge on the docking station
my ipod wont charge. it shows the charging icon, but when i take it off the charger it dies like it didnt charge at all
May 05, 2008 | Audio Players & Recorders
Ipod won't charge
It means the hard drive is crashing. If it's clicking it means there is a problem with the hard drive. Try restoring your ipod or reformatting it.
Reset To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. 5rs_reset_clickwheel.png
    Tip:
    • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
    • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
OR TRY THIS
iPod's battery doesn't charge Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port iPods that connect to USB ports require a high-power USB port. Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or FireWire port on the computer.
FireWire port on a Windows PC The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip: Some Macintosh computers can charge iPod even though they're asleep. If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
You are using Windows 2000 If you use your iPod with a computer using Windows 2000, see document 304801 "iPod: Proper charging procedures for Windows 2000" for steps on how to keep iPod charging.
There are too many devices in the FireWire chain Your computer can provide power to FireWire devices that don't have their own power sources, such as hard drives and cameras. If there are too many of these kinds of devices connected to your computer, iPod may not be recognized.
  1. Disconnect all devices from your computer's FireWire port(s).
  2. Connect iPod to the computer's FireWire port using the FireWire cable that came with iPod.
If this resolves the issue, consider purchasing a powered FireWire hub to connect your nonpowered devices to. These hubs are available from the Apple Store.
iPod is locked up If iPod is locked up it will not charge, reset iPod. When you reset iPod all your songs and files are saved, but some customized settings may be lost. Tip: iPod will not wake automatically if you connect to a 4-pin FireWire port. Press the Select button (center of wheel) to wake iPod.
Faulty cable If something is wrong with the FireWire or USB cable that came with iPod, it may not supply any power to charge the battery. Note: Only iPod models with a Click Wheel can get power from a high-powered USB port using the supplied cable (includes iPod mini, iPod (Click Wheel), iPod photo, iPod with color display, iPod nano, and Fifth Generation iPod).
  1. Make sure you are using the cable that came with iPod. Some third-party cables may not work properly with iPod.
  2. Make sure nothing is in or blocking your computer's FireWire or USB ports.
  3. Check the connections to make sure the cable is completely plugged in.
  4. Try another known-good FireWire or USB cable if available.
If this resolves the issue your FireWire or USB cable needs to be replaced. You can arrange for replacement at the iPod Service Website.
Faulty port on the computer If something is wrong with your computer's FireWire or USB port, it may not supply power to iPod. Note: Only iPod mini can get power from a high-powered USB port using the supplied cable.
  1. Check the connections.
  2. Try another known-good FireWire (or high-powered USB) port on a different computer if available.
  3. If you do not have access to another computer, use the Apple iPod Power Adapter.
  4. Plug in one end of the FireWire cable to the Apple iPod Power Adapter and the other end to your iPod.
  5. Plug the Apple iPod Power Adapter into a working electrical outlet.
  6. If you have an iPod (with Dock Connector) model, connect the FireWire end to the Apple iPod Power Adapter and the dock connector to iPod. Warning: Never plug the dock connector end of the FireWire cable into a computer's FireWire port.
If this resolves the issue, consult your service and support guide to see how you can have the computer's port repaired.
Faulty Apple iPod Power Adapter If something is wrong with the Apple iPod Power Adapter, it may not supply power to iPod.
  1. Try another known-good electrical outlet.
  2. Make sure all the connections are good. Try disconnecting and reconnecting all connections to make sure they are snug.
  3. Try another Apple iPod Power Adapter if one is available.
  4. Try connecting iPod to a computer's FireWire port using iPod's FireWire cable.
If this resolves the issue the Apple iPod Power Adapter needs to be repaired. You can arrange for repair at the iPod Service Website.
You might consider additional troubleshooting steps for the Apple iPod AC Adapter before having it replaced.
Faulty dock connector or FireWire port on iPod If something is wrong with iPod's FireWire or Dock Connector port, it may not supply power to iPod.
  1. Make sure nothing is in or blocking iPod's FireWire or Dock Connector port.
  2. Check the connection to make sure the FireWire or Dock Connector cable is completely plugged in.
If this did not resolve the issue iPod needs to be repaired. You can arrange for repair at the iPod Service Website.
Related Terms: charged, dead, die, dying, drained, draining, drain, drains, frozen, freeze, freezes, freezing
Keywords: ktech kipod kipodwin kipod1 kipod2 kipod3 kipod4 kipod5 kipodphoto kipodmini kipodmini2 kshuffle kipodnano kipodnano2 kshuffle2 Did this article help you?
It solved my issue...
Tell us what works for you.
It's good, but...
Report typos, inaccuracies, etc.
It wasn't helpful...
Tell us what would have helped.
Apr 21, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
114 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
