Question about Maytag MAH8700A Front Load Washer
Neptune MAH5500 Front Load Maytag
There is a stong musty smell that even with running a cycle of clorox it continues to fill the room and into the hallway. We are a family of 4 adults and rarely does 2 days pass without using the washer. We did have a problem of the front gaskit molding and the service technician replaced that. We purchased the washer and dryer from Sears in January 2005. Please help Vickie LBOB92@aol.com
    Sergeant:
  • 409 Answers
Hi vicky,
i have come across this problem with other front loading machines. the problem lies with the machine depositing dirt and detergent into the door gasket.
make sure that you are using the He detergent intended for front loading machines.
if you are, you can purchase something called Affresh tablets. these will get rid of the deposits in the gasket. they are available at any appliance parts supplier.
thanks
Posted on Oct 03, 2008
Fills with water between washes
try extending your drain hose up alittle higher
Sep 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
I have a neptune front loader, after the wash cycle is complete the clothes smell like they have not even been wash with a **** moldy smell. I use Tide HE as directed but they still smell like i...
Hello, Thank You for using FixYa. I will be helping you today.Try 2 cups of white vinegar on a heavy duty cycle with hot water.Pour it in the detergent dispenser after it starts to fill. Also the affresh tablets work good i would use 3 tablets at one time if your unit is as bad as you say.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Maytag Neptune MAH5500B Front Load Washer
Musty smell
Try running a large load without clothes using the hot water cycle and add a cup of white distilled vinegar.
May 30, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My washing machine smells where is the filter does it have a filter all other machines do
Run a tub filled with a couple of quarts of white vinegar thru the cycles. It generally reduces smell of mildew and bacterial odor. Clorox works too. Run rags or other "throw-away" laundry during these cleaning methods.
Oct 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer, Model: MAH5500
The problem is with your door lock set.You may need to
replace it.If your lock is faulty the washer wont begin its
cycle.
Apr 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load washer - smell musty
the water in the unit is normal, to kill the smell when you are done doing wash for the day dampen a rag with bleach and whip down the door gasket. You can buy a cleaner called "afresh" it works as well. If your unit is a neptune check with maytag it might have a recall on the door gasket for growing mould
Nov 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer smells musty. what is
I owned a maytag neptune washer and had to run dishwashing liquid thru it occasionally to get the smell to go away. Finally we learned about a new gasket retrofit that they were doing which was covered by the maytag company we called and they installed it for free and the smell stopped. I had that washer for about 10 years and probably spent as much fixing it over the years as it cost. I now have a whirlpool duet front loader and love it. no smell and not problems. Try the electric dish washer soap.
Aug 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Mar 02, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH8700A Front Load Washer Logo
83 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
