Question about Hotpoint Washing Machines
HOTPOINT WD62 FILLS WITH WATER WHEN NOT BEING USED
    Problem Solver:
  • 16 Answers
All washing machines have a solenoid valve for turning on and shutting off the water coming in, one for the hot water and one for cold. It sounds like one of them has a slow leak.
Try shutting off the cold water supply to the machine for a day and see if the tub fills with water. Next try shutting off the hot water supply and leaving the cold supply on. This will tell you which valve is leaking.
This solenoid valve is something you can buy from an appliance parts company. In some cases, someone handy may even be able to disassemble it and replace a washer that is leaking.
Until it is repaired, you can get by with shutting off the water supply when you are not using the machine or shutting off the supply that is leaking. For example, if it's the hot water supply valve that is leaking, just shut off the hot and do only cold water washing.
-Vince
Posted on Oct 03, 2008
  • Ken Zenzel May 25, 2013
    Vince, I've done as you suggested. Your explanation fits the facts without taking the cabinet apart. No water on the floor, just cold water in the tub. Thank you.
2 Suggested Answers
SOURCE: Where do I drain the tumble dry water on a hotpoint wd62 wash/dry
remove the top panel by unscrewing the 3 screws at the back of the washer dryer . remove the top and then remove the back metal panel. the screws are down the side and all around the back of the panel. once you have removed the panel check for the black rubber hose that connects to the drum. remove the clip holding the rubber hose by prising it with a small screwdriver. be careful as the water will flow out quite quickly. Check the hose pipe for any blockages and clear as required.
Posted on Jan 28, 2009
Hi I have a hotpoint WD62 washer dryer. when I'm using the dryer the clothes still come out wet like the steam is not going out of the machine. Any tips on what to check for? Could something be...
I had the problem. I replaced the water inlet valve, and that fixed it. It seems no cold water was coming in on the drying cycle to condense the steam.
Sep 24, 2010 | Hotpoint WD62 Front Load Washer / Dryer
My aquairius hotpoint washer dryer wd62 keeps tripping electric why
Remove top cover, and unplug motor, try it, and if it does not trip, then motor is causing prob.
If it still trips, then heater is probably causing problem.
Please rate my advice.
Thanks.
Jun 01, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint wd62
Try taking the top off, power off obviously!! and remove the draw unit, there is a pipe that runs from there to the drum.... I found a sock in mine that was the problem !!
Feb 03, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Jan 04, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 Drum wont turn
tilt the machine backwards. with a multimeter, check continuity across the brushes - if open circuit then brushes need to be replaced
Oct 02, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Water is being used in the drying cycle
This is normal operation. Water is used by the condensor to liquidfy the steam from drying.
Mar 27, 2008 | Hotpoint WD62 Front Load Washer / Dryer
My Hotpoint Aqaurius WD62 is filling but wont drain or spin
try replacing the interlock first then check the the continuity in the interlock lead
Mar 06, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD62 W/D. Works OK empty but bangs when full
Sure easily. Plug off the wall, open up behind to check if any springs have come off, check the shockabsorber, bolts.
Feb 11, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint wd62 leaking from the drawer
Hi, check the electrict valve winding busted hot and cold.
Jan 27, 2008 | Hotpoint WD62 Front Load Washer / Dryer
WD62 drawer leak
remove drawer clean it make sure flap is free on drawer compartment
Nov 24, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Washing Machines Logo
168 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
