Question about Mintek DVD-1710 Portable DVD Player
Open code I need unlock code for mintel portable dvd player model 1710. I want it region free
  • Anonymous Apr 11, 2009
    Unlock code for Mintek DVD-1710 portable DVD player
SOURCE: Unlock region code
I found this info on the site and it works!!!!
1. Switch on the DVD player.
2. Open the disc tray, and leave it open.
3. On your remote key in the following number: 81328
4. Then press the ENTER key a number of times till region 9 comes up.
5. Press the MENU button on your remote.
6. Finally close the tray.
Posted on Mar 30, 2008
jaffa012001
  • 376 Answers
SOURCE: Hi i need to find
1. Open the DVD cover
2. Press setup
3. Type 9 6 5 3
4. Press the Arrow Key up or down and select 0 for region free
5. Hit OK
Posted on Aug 29, 2008
SOURCE: Philips Portable DVD Player PET 730/98 Unlock Code Needed!
Philips PET730/05
Using remote control
Setup
Down arrow
Down arrow
Right arrow
212225 (you won't see anything!)
Left arrow
Down arrow
should now show region code box
Enter 0
Setup to save
Posted on Apr 09, 2009
SOURCE: JVC dvd player model XV-N650 unlocking codes
From another site...
Region code hack posted by mairel, December 18 2007:
A greeting to all, good after point to look for and to break the head, I could convert to multizona my DVD, I count them that I stay fillet. here they go them the procedures, I hope it serves them. 100% guaranteed.
1. Turn on
2. Open the tray
3. Press 0000 in RC
4. Change to any region you want 0 for region free
5. Press Pause
6. Turn off
7. Turn on again and enjoy
Posted on May 15, 2009
  • 814 Answers
SOURCE: portable dvd player that plays all regions
You can find them on the internet by using the search engine. Put in all region dvd players. You will find many place and types to buy. This is one of the places.( http://www.regionfreedvd.net/) Just copy the address and put it in your address bar of your browser. I hope this information help you with your problem.
Posted on Jun 08, 2009
What is the unlock code/region hack for a Bush 12" portable DVD player? The model is CDVD12SWM.
Give this a run
Make Your DVD Player Region Free in Seconds
  1. Power on.
  2. Open tray.
  3. Push the info on remote once (with supplied remote). You will see numbers.
  4. Press 9 for multi-region. Keep trying until you see the number 9 appear in upper left corner.
  5. Power off.
  6. Power on.
Oct 01, 2015 | Bush Televison & Video
How to unblock the region code of the portable dvd player Toshiba SD P91SKR?
Hello there, to my knowledge there is no way to unlock the region on this particular model dvd player. Most portable dvd players cannot change the region code unfortunately. I have double checked and there are no unlock codes for this model.
Jul 14, 2009 | Televison & Video
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Phillips dvp1013
Hello Canada416,
Check the following link to the regional code data base for codes you can enter through the handset to unlock region codes. Let me know if this helps you or you need further assistance.
Jun 30, 2008 | Philips DCP855/37 Portable DVD Player
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
I have a Toshiba SD-P91S portable DVD player and want region free codes
I Have a Toshiba SD-p91S portable DVD player and I want region Free
Apr 20, 2008 | Televison & Video
Unlock region codes for portable dvd player - panasonic DVD LS80
Panasonic models can't be hacked to change to region free. You need to get a hardware fix. Best to google aussie sites to find someone
Apr 12, 2008 | Panasonic DVD-LS80
Unlock region codes
Hi All,
I am looking for the region unlock code for a Sony portable
DVD player.Model number DVP-FX720
Jan 12, 2008 | Insignia NS-PDVD8 Portable DVD Player
PERMANENT UNLOCK REGION CODE FOR philips DVD PET714
I boght PET714 DVD portable DVD player.
but I couldn't watch Japanese DVD.
I'd like to unlock code.
Please tell me how to get unlock!!
Jan 12, 2008 | Televison & Video
Mintek DVD-1710 Portable DVD Player Logo
26 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
