Question about Amana RC17 Microwave Oven
Amana microwave RC17
On the display I have the message "CALL Serv." but the oven is working fine.How do I reset the message?
Thank you!
  • kevin185 Dec 11, 2008
    display reads "call serv" but microwave is now working fine. How do I clear display?
  • Amana Master
  • 9,098 Answers
There is a bulletin that shows how to reset this code on Amana commercial microwaves.
We have uploaded it to our site here to help you.
Posted on Oct 05, 2008
  • Jerrel Kenemore Jan 16, 2013
    I have the same issue. The microwave works and heats food but this message appears all the time. The microwave does not heat as well as it used to but it does work.
Amana RC22S2 Cooks but not as well as before. Continually shows Call SERV
It is sensing the unit is not heating properly and telling you to call for service. Resetting will only delay it from showing the error alert again. It has a current sensor on the unit to tell if it is running properly, if not, it gives the error to let you know it is time for repair.
Oct 12, 2017 | Microwave Ovens
For Model: URC517MP - Can you clarify Error Code C5
Hi ess0,
The Amana error code F5 means that you have a failed Electronic Range Control (ERC. The only way to resolve this problem is to have the Electronic Range Controller be replaced. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
May 31, 2011 | Amana RC17 Microwave Oven
I want d manual of Amana Commercial Microwave Oven Rc17 1700 watts
You can download the manual from the manufacturer's web site at
May 27, 2011 | Amana RC17 Microwave Oven
Wont do anything
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
May 09, 2011 | Amana RC17 Microwave Oven
Rc17 commercial microwave, display shows door even when door is closed.what can i do to resolve
Possible that the door lock switch is stuck and so is not releasing even after the door has opened. Look inside after disconnection of power to the microwave at the place where the door locks. Tap into the lock to release the switch . If the switch is jammed or damaged it must be taken out and replaced.
Mar 31, 2011 | Amana RC17 Microwave Oven
I need service manuals with parts list and trouble shooting guide
Try they have manuals, repair guides, and exploded views for many appliances. They also provide step by step instructions for making diagnoses and repairs. You'll need tha approximate year of manufacture, model #, and serial #.
Feb 23, 2011 | Amana RC17 Microwave Oven
Timer is reading "Hot". What would be the
I would say the temperature sensor is faulty, unless the machine is of course HOT.
Jan 07, 2011 | Amana RC17 Microwave Oven
Microondas amana error5
Hi edextre07,
This means that you have a control board failure. Error code F5 can only be fixed if the control board (ERC) is replaced. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Nov 07, 2010 | Amana RC17 Microwave Oven
Most likely the side keypad is bad.
Jan 20, 2010 | Amana RC17 Microwave Oven
Abnormal noise produce by Amana microwave RC17
Deart Customer
please undergo the following
Since 30 to 50 percent of the power into a microwave oven is dissipated as heat in the Magnetron, cooling is extremely important. Always inspect the cooling fan/motor for dust and dirt and lubricate if necessary. A couple of drops of electric motor oil or 3-in-One will go a long way. If there are any belts, inspect for deterioration and replace if necessary.
An oven that shuts off after a few minutes of operation could have a cooling problem, a defective overtemperature thermostat, a bad magnetron, or is being operated from very high AC line voltage increasing power to the oven. One interesting note: Since 30 to 50 percent of the power goes out the vents in the back as heat, a microwave oven is really only more efficient than conventional means such as a stovetop or gas or electric oven for heating small quantities of anything. With a normal oven or stovetop, wasted energy goes into heating the pot or oven, the air, and so on. However, this is relatively independent of the quantity of food and may be considered to be a fixed overhead. Therefore, there is a crossover point beyond which it is more efficient to use conventional heat than high tech microwaves
i think the information would help u if so rate me please,otherwise just give it as fixya,Thank u
Dec 17, 2008 | Amana RC17 Microwave Oven
Amana RC17 Microwave Oven Logo
508 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
