Thanks for choosing FixYa and welcome. If it was the fuse, the entire radio wouldn't work. You either have a bad volume switch or there is no power to the switch. Check the wiring for the volume switch. Perhaps, test the wires with a schematic if you don't know which one it is. If it has power, the issue is inside the radio.
You would have to test the fuel pressure on this vehicle by connecting to the line coming from the fuel filter to the fuel rail, there is no actual fuel test port on this vehicle. if you do decide to test the pressure... here is what your pressure readings should be>>
Fuel Line Pressure
46-51 psi (320-350 kPa) This actually sounds like a Fuel Pressure Regulator issue. I would recommend replacing the regulator and see how the vehicle responds after that..
If the calculator is several years old it may be showing its age. There is a connection point between the keyboard and the display that over time loses its efficiency. Try this: press a number key and at the same time apply pressure with your thumb or index finger to the region of the calculator just below the display. If you press hard, the number may just show up in the display. This is a test for the tightness (or electrical efficiency) of the keyboard-to-display connections. Another way to make this test is to twist the calculator while you depress a number key. Sometimes the effect is such that the keys on one side or the other work, or don't work, and the keys in the middle don't work or work okay. By twisting (don't break it!) the calculator body while you press the keys will show the weakness of the connector between the display and the keyboard. This can be repaired by a good electronic technician if you explain to him what I just told you.
That is a software problem. take the phone to a reputable engineer to reinstall the software of the phone. thats the only solution and it happens mostly to nokia phones.
E225 is the error code relating to a CIS unit malfunction.
First reconnect the flat cable to the CIS unit. If a problem still exists do the following steps in the service mode
press "Additional function"," # "( to enter the service mode)
Use the arrow keys to scroll to HARDWARE TEST, press OK
Use arrow keys to scroll and select CIS TEST, press OK
Now as shown in display press 1,2,3,4 and check if the CIS is glowing in White, Red,Green &Blue.
If CIS is not responding, it's time to replace the CIS unit.
If the CIS is responding properly do the following procedure.
Now dismantle the scanner section and apply a suitable lubricant(
Silicon oil can also be applied) to the portion of the flat cable which
touches the bottom plate and also to the portion of the bottom plate
over which the flat cable is sliding.
If still issue not solved it's time to replace the CIS unit
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
I guess it was working all along, but simply would not respond to the test sound from my Onyko. But when I put in a DVD it is definitely putting out sound. So I don't know why it will not respond to the test sound because all the other speakers respond to the test sound. ???
Thanks.
