Question about Whirlpool ED2FHEXN Side by Side Refrigerator
No water to the Ice Maker
I have a 2-year old Whirlpool side by side ED5PHEXRS00. The Ice maker stopped making ice. I replaced the ice maker but it did not help. The issue seems to be there is no water coming into the ice maker. however, water does flow to the dispenser on door. I subscribed to FixYa support service this afternoon and thus far did not hear anything, what is the next steps?
  • boomer4940 Oct 09, 2008
    i changed the water filter but there is no water coming in to make the ice but the water dispenser works?
  • Anonymous Oct 22, 2008
    i HAVE THE SAME PROBLEM ON A 3 YEAR OLD WHIRLPOOL GOLD MODEL GD5RHAXNQOO. hOW DO YOU ACCESS THE FILL TUBE TO TAKE A HAIR DRYER TO IT?
  • 120 Answers
Sorry to hear that i hope i still can help check the fill tube that fills your ice maker see if it is frozen if it defroated with a hair dryer if there is no frost then you might have a bad water valve you see there are 2 selenoids on valve one for dispenser and the other one for the ice maker so if you don't get water it could be the valve look at the ice maker are the forks pointing up or down if they are down then you have a bad module on ice maker that is the front part of it. if they are pointing to 1oclock then check valve and tube
Posted on Oct 16, 2008
The whirlpool I have is a side by side if have a bottom drawer freezer. And my ice maker is in there .my light switch stop working so I replaced it so now the light comes on when the drawer is open...
If no ice check to see if there is water in the tray. If no water in ice maker tray issue is with the fill solenoid. If water in tray the heater is no good and the ice scooper cannot move the ice from the tray to the bin. If you want you can just replace the ice maker on ebay for cheap
eBayeBay
Sep 23, 2017 | Whirlpool Refrigerators
hi,
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Oct 03, 2008 | Whirlpool GS6NBEXR Side by Side...
We have a whirlpool gold conquest side by side refrigerator. Water dispenser works, ice does not. Stopped suddenly making any ice. How do we fix it? It's only 2 years old.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 21, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Oct 01, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Side by side Ice maker
check water valve for ice maker how old is the ice maker is more than 3 years then it might need replacement as well
Nov 03, 2008 | Refrigerators
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Feb 08, 2008 | Whirlpool ED5SHAXM Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
129 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
