Question about Nokia 3587i
3587i antenna broken
I need to install my new antenna on my 3587i Nokia how do I disassemble it?
  • Nokia Master
  • 1,800 Answers
First remove the housing
then use the 6 nokia screwdriver to remove the six screws then remove the lcd/keypad board then the mothgerboard
the antena located on the phone chasis its a plastic piece with copper circuits remove it and perform the replcmant
best regards
hope u rate this post
ask me to help u further
Posted on Oct 03, 2008
How do you replace radio antanna
What kind of car is it? If it is a fixed antenna you just unscrew the old one and screw on the new one. If it is an automatic antenna, you can buy either the motor or the mast. Assuming you just need to replace the mast, it comes with the plastic piece with the teeth on it. You need to remove the old broken plastic piece from the antenna motor. You might need to disassemble the antenna motor from the car to get enough of the plastic to grab onto with pliers. While you are pulling on it have someone turn on the radio to activate the antenna up motion and pull the old plastic piece completely out. With the old plastic runner out, the motor installed on the car, and the radio on, run the new plastic runner first through the doughnut screw that holds the mast to the car. Then cram the new plastic runner as far as you can into the hole that leads to the antenna motor. Then hold the very end of the mast (the tip), align the base to the opening as best you can and have someone turn off the radio to activate the down antenna motion. It goes quick so don't have your fingers where they can get pinched as the motor sucks in the plastic and the mast down into the hole. With the mast retracted, tighten the doughnut screw to that the mast won't flop out when you turn the radio back on.
Mar 12, 2015 | Cars & Trucks
N73 ime no3564202327657 i want keygen plz
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 07, 2012 | Nokia E60 E61 E62 E70 N70 N71 N73 N80 N92...
Broken antenna on grundig mini 300 radio
Replacement is possible, the back of the radio needs to come off and there is a screw at the bottom of the antenna. Remove this and the old one will slide out and simple to install new one. Call Eton for replacement, can be foung with a google search....
Feb 14, 2010 | Grundig Mini 300 AM/FM/SW Radio
How to replace arial in 95 camry
This is normally due to a broken antenna mast inside the motor, the mast /cable assembly should be replaced, the antenna motor has to be removed from the car and disassembled to remove the broken piece of the old cable, once that is accomplished the antenna motor is reinstalled and the new cable assembly is fed into the motor by turning the radio on until the motor stops and then turning the radio off while feeding the new mast in.
Sep 04, 2009 | 1995 Toyota Camry
Nokia 3587i screen not displaying info
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
This is your solution! Please vote!
Feb 23, 2009 | Nokia 3587i
Changing broken antenna on 2004 ford ranger
ok some of there are screw in antennas and some you need to replace intire wire and all if this is screw off un bolt and install new if not remove your cd player find antenna wire tape a long wire of any kind strong of course go out side and pull wire out then take new antenna wire tape to wire and reverse the pulling to repalce wire to proper location
Dec 09, 2008 | 2004 Ford Ranger
Need a nokia 3587 users guide
Try here
Hope this helps.
Nov 19, 2008 | Nokia 3587i
Need detailed instructions on how to use all the features on LG285 phone
How do I disable the handsfree headset for my Nokia 3587I
Oct 15, 2008 | LG Cell Phones
Surius Can not find antenna
A couple of possibilities all based on the assumption that the unit actually turns on.
1. Broken or disconnected antenna wire.
2. Broken antenna (The antenna is powered from the unit)
3. Broken unit.
Dec 27, 2007 | Sirius Satellite Radio Receiver
Nokia 3587i Logo
50 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
