Question about Frigidaire PLES389D Electric Kitchen Range
Frigidaire PLES389ECI Hello, We just bought a range/ glass cooktop and when we turned it on, the digitial readouts above the cooktop controls reads - -. The digital "clock" display has a locked icon displayed, and we cannot figure out how to unlock the cooktop, and how to get it to work. It is level. How can we fix it?
5 Suggested Answers
  • 833 Answers
SOURCE: My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
Posted on Dec 13, 2007
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
philbran
  • 242 Answers
SOURCE: Where is the fuse panel
I can help , The fuse panel/control board is located behind the digital display in the front of the unit. Some drop in ranges are tricky getting into so be carefull when removing the face , there are screws under the display when opening the oven door look up and there may be a few more on the top side corners reveled when you pull the unit out 12" or so. there is a small glass fuse in the board some of these are not removable so if there is no digital display on your oven and your sure you have 240V to control board you will need to replace the entire control board. Hope this gets you there. Good luck let me know if you have anymore problems.
Phil
Posted on Dec 31, 2008
frankegd
  • 5 Answers
SOURCE: Our cooktop will not turn on!!
Got the same problem.
Here's a work around: Turn breaker off, second person needs to hold the CANCLE/LOCK button (keep holding it!)
Turn breaker back on and keep holding the button, lock feature may turn on, red lock light stays on, KEEP HOLDING THE BUTTON. At the end you will get a F11 (shorted keypad) warning. It may take up to 20 seconds or more but in my case the red lock light goes off, the dashes disappear and everything is back to normal.
Now here are the bad news. This does not fix the problem (I think it's the EOC). Every time the power goes off the red lock light and dashes will come back. It also may require to people to fix this/work around... but, hey, it doesn't cost anything either...
Posted on Dec 10, 2009
I have frigidaire electric range FES367DQA. I cracked the cooktop and would like to replace it. I found that there is no glass cooktop for my range but there is for FES367DBA and DCA. The difference i
Thank you for your post, isaak goldman!
I understand that you are seeking instructions in order to replace the cooktop on your Frigidaire range. However, this is not a simple DIY job. I would recommend having a professional technician come out to ensure that the range is properly disassembled and the cooktop installed correctly to prevent any future issues. Hope this information is helpful. -Matt
Jan 31, 2015 | Frigidaire Kitchen Ranges
How do you remove the control panel on a slide in glass top frigidaire stove model CFES367DC2
Hey Tamara webber, thanks for your inquiry!
I see that you would like to remove the control panel on your Frigidaire range, CFES367DC2. . Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree and please do not hesitate to reconnect. -Matt
Jan 31, 2015 | Frigidaire Cooktops
Fix the eyes on the glass top
Hello jackie wakefield, thank you for your post! Based off the information you have provided you would like to fix the burners located under your Frigidaire range glass top. In order to replace the burner you would need to remove the cooktop. Regrettably this is not a simple DIY job. I would recommend having professional technician come out to your home for proper disassembly of the cooktop and replacement of any electrical components. Hopefully this information is helpful. -Matt
Jan 01, 2015 | Frigidaire Kitchen Ranges
The indicator light for the stovetop remains on despite all the knobs for each element in the off position. One of the elements is still getting power and heating slightly despite all controls in the
Hello friend, thanks for your post!
I see that the indicator for your cooktop continues to remain on for your Frigidaire range. It sounds like it could be a potential issue with your switches or control panel. I would recommend a reset on your range which you can do by flipping the household circuit breaker off for ten minutes. I hope this is helpful. -Matt
Oct 11, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
316065306how many watts to run this range
Hello friend, thank you for your post!
I understand that you are searching for the wattage on your Frigidaire range. In order to provide you more information I would need to have your model number. You can locate your serial tag (which lists your model number) on the outside of your cooktop base possibly on the edge or bottom under the unit. Once I have that information I can further assist you. I look forward to your response. -Matt
Aug 19, 2014 | Frigidaire 30 in. Electric Ceramic-Glass...
How do you remove a 318223634 glass top frididaire
Good Afternoon Leslie, this is Z. Thank you for your post!
I see you are looking for information on how to remove the glass-top of your Frigidaire Cook-top (318223634). It appears above-listed model number is invalid; however, this is not a typical DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website. Best regards.
May 03, 2014 | Frigidaire Stove/Oven/Range Black Glass...
How to replace glass cooktop on oven
Hello k10251985 - Usually this type of data is not release to a consumer and it is very rare to find enough information to do it yourself. In most cases this material can be found on the internet; however it is not provided directly from the manufacturer. Typically this is something that you want a certified professional to install/remove for you due to safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem. Consider contacting your manufacturer for more details on who in your area may guide you through this process.
Feb 16, 2013 | Frigidaire FEF336BC Electric Kitchen Range
Kenmoe Electric Cooktop and started beeping and fan is running
A F1 code is a bad ERC electronic range control.(clock).
The ERC must be replaced.
Mar 18, 2010 | Kenmore Kitchen Ranges
Glass top stove
I would use this it is made for glass cooktops
frigidaire_2031_10206643
You can get it at Sears.com
Dec 18, 2008 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire ES400 oven controls
Contacts are fused.  Get a new one, cut the power and replace it.
Nov 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire PLES389D Electric Kitchen Range Logo
181 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
