Tv is too dark to see
This is a very common problem within your projection TV set there is a small red, green, and blue picture tube. On top of the tube there is a lens that focuses the video on the screen. Between the lens and the top of the tube there is a hollow chamber filled with a clear liquid. This fluid is specifically designed to keep the tube from overheating. After about 4-5 years the fluid will start to become cloudy and will will get worse over time. Tvrepairkits.com is a good place to get a repair kit to fix this condition yourself.
SOURCE: Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
SOURCE: LG Projection TV has dark picture
Normally the main cause of any DLP having a dark picture is the lamp. I would replace it and it should look like a new set again.
SOURCE: dull dark picture on kdf-e50a12u rear projection
Depending how long you have owned it and if a Lamp was ever replaced, it probably needs to be replaced. You can check with SONY at
1800-222-SONY and see if they could sell and send you one.
Hope this helps,
Skyassoc
SOURCE: Mitsubishi TS-5053 rear projection TV-Sound but no picture
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Testimonial: "Thank you for your help. This is a really great service. Doug Little Elm, TX"
I have color and contrast to highest settings but picture is still to dark to see
