Question about Xantrex Technology Xantrex XPower Mobile Power Source/100 Watt Inverter #813-0281
Sun 1200 inverter ,can it be mounted verticaly?
Can this be mounted on a wall or does it have to be flat?
  • 714 Answers
Yes it can be mounted on the wall.
Posted on Jan 29, 2010
Samsung inverter wall mount unit after switching it on for few minutes, dies off and the 2nd and 3rd led indicators keep blinking constantly. Tried switching off the main breaker but no help.
2 and third indicatore is for what?
If its for overload than call ur technician
And if its for charging issue check ur battery or inverter charging panel
Sep 05, 2016 | Samsung Televison & Video
Why is our inverter very noisy?
have it inspected by a service person for correct operation
check that rubber insulators were installed under the mounts of the machine
check that the installation is in line with the manufacturers recommendations so to prevent vibrations in walls and surrounds
Nov 04, 2017 | Inverter Heating & Cooling
Bande verticali colorate
Check its back-light inverter board and back-light CCFL lamps. In most cases, lamps found faulty. Check and replace the faulty ones. If you wish to get more details, check this site.
Feb 11, 2013 | LG 26LG30 26 in. LCD TV
My Inspiron 1200 turns on but I have a black screen - no video. It began fading - now nothing. Is there anything I can replace?
Hi:
One thing to try is to connect your Inspiron up to an external monitor. You can plug in any kind of monitor, but you might have to toggle to the external mode:
Hold down your function key, then hit the LCD/CRT key. If you have a good display on an external monitor, then you are going to need either a LCD inverter or new LCD. They are not too hard to swap out, the inverter costs about $15,it is mounted in the lid, below the LCD, and the replacement LCD about $80.
Dec 01, 2009 | Dell Inspiron 1200 Notebook
Screen goes blank after 2 minutes
Your best bet is to take the back off and look if there are and bulged capacitors on the power supply first, also look for cold solder joints on the 24 volt rail that goes to the HV inverter board. If both seem to be ok then you could have a inverter transformer going bad on the inverter board. Let me know how you do>
May 31, 2009 | Olevia LT27HVX 27 in. LCD Television
I have sound but no picture on my 32 inch LCDHD TV/DVD. Picture flashes for a second an then the screen goes blank. Thanks Bill
This problem is caused by one of thee problems.
1) The inverter board(s) is bad.
2) Power to the inverter board(s) is off.
3) The CCFT(cold cathode fluoresent light) is bad.
Since the picture flashes for a second you may also check for loose connections for the above items.
Here is a simple test you may also try. With the TV on take a bright flashlight and press it against the screen. Look for an image around the edge of the flashlight. This will verify that an image is being sent to the screen.
Mar 12, 2009 | Televison & Video
Lg lcd tv screen goes black but the sound still works 52lg70 screen goes blank, sound still works. i can change settings but cannot see the menu so the tv is still working there is just no picture.
This sounds like a mainboard problem. Unless you do not see a back light flash when you turn on the TV, which may mean it is an inverter board problem, this is most likely fixable by replacing the mainboard.
Jan 20, 2009 | LG 52LG70 52 in. LCD HDTV
LCD TV screen goes blank with sound still on
Have the inverter board checked for cold solder joints, this television is notorious for bad connections on the small transformers on the inverter, buy the way the inverter is the board that lights the lamps.
Thanks please leave comment
Aug 18, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Konka KLC-1508U
Após ligar o lcd o inverter fica inoperante, como resolver isso ?????
May 15, 2008 | Televison & Video
TV SCREEN GOES BLANK
Yes your inverter is bad, I have the same problem my set is about 1 and 1/4 years old. Because Olevia makes a terrible product there inverters are attached directly on to the panel, which means they will only sell the inverter along with the panel i.e $700+ to replace + $100 dollars labor if u don't know how to fix it ur self. I am currently searching to find the manufacture that makes the inverters because olevia will not disclose that information. I believe it is darfon, if so the inverter should cost about $150-200 depending. If you dont believe you can fix it ur self ur best bet is try and sell the set for scrap take ur $100 or so dollar and buy a quality product! Oh and dont call there support they will tell 10 different things before u find out this long for seen truth!
May 04, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Xantrex Technology Xantrex XPower Mobile Power Source/100 Watt Inverter #813-0281 Logo
78 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Craig Butler
Craig Butler
Jimmer_9
Level 1 Expert
richie46
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
