Question about Lowrance iWAY 250C GPS Receiver
Touch screen failure
My 250c got misted with water, not soaked but enough to evidently cause damage. I opened it and found no evidence of moisture, but left it open over a light bulb to thoroughly drive out condensation. Unfortunately it boots up to the warning screen and that's it. The touch screen won't let you x it out. Is there any hope? I liked this unit, would be a shame to pitch it.
Sometimes it pays to procrastinate. My 250c gps was left in a drawer for a year and a half as I hesitated to pitch it. I turned it on recently and everything works good as new. The battery was still fully charged! It must have dried out over time.
Posted on Mar 15, 2010
Won't cut off unless i unplug numbers change by themselves and keeps beeping i have unpluged and reset
If moisture/water gets to the control board it will/may cause it to act this way. Or the control board may have a short. It may also have a bug, mouse, or gecko laying on the controls. Something causing it to "misfire" or short. If a visual inspection does not show evidence then its probably control board failure.
May 27, 2015 | Frigidaire FRA186MT2 Window Air...
Error Code E65 on Frigidaire Front Loader Model #LTF2940ESO
Thermostat issue - need a professional to complete the following:
For electric model, check inlet thermal limiter for continuity. If thermal limiter is open, check for evidence of high temperature event and any resulting damage. If no further damage is evident, replace thermal limiter. If no problems are found with the thermal limiter, check exhaust vent system for air blockages. If no problems with vent restrictions, check/replace high limit thermostat, and retest.
Aug 15, 2012 | Frigidaire Washing Machines
Lady in wallmart said it is not the battery.I turn it on ,it immediately powers off,after doing this 3or 4 times it will stay on long enough to take 1 picture.I got the camera Dec.25 ,2010. Thank you for...
Your camera has a fault which you cannot fix yourself, but fortunately your camera is still covered by Nikon's warranty. Contact Nikon's authorised service centre in whichever country you live to arrange a free warranty repair.
Note that the repair will be charged for if the fault is determined by Nikon to be due to misuse or carelessness. In practice that usually means if they find evidence of the damage being caused by water or due to a fall you'll be charged. They will also charge if there is any evidence of unauthorised repair attempts.
Jul 16, 2011 | Nikon COOLPIX S6000 Digital Camera
I have a six month old Bosch dish washer and 8/10 times the powder is not disolving?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Evidently the detergent cup is opening? Here are some of the possible causes; 1. Low on water (fill the machine, let it start and see if the unit has enough water). Sometimes the screen on the fill valve get partially clogged and slows the flow and when the timer engages and therefore enough water was not installed. 2. Defective fill valve (partially sticking valve sometimes will not let a unit get the proper amount of water before the unit starts and therefore the powder in not dissolved). (3)Any detergent will generally dissolve when contacted with water, unless is has had previous contact with water or is old....
Aug 05, 2010 | Dishwashers
Water runs out quick but no leaks on my radiator..anyone knows what the prob is
open your oil fill cap if you see white milky stuff you found your leak
Oct 24, 2009 | 1993 Mazda Protege
I dropped my LG Shine in water recently. I
The battery must have caught moisture. Thus it can't take sufficient charge. Try replacing the battery.
Aug 14, 2009 | LG Shine CU720 Cellular Phone
Air conditioner wont turn on
There are several possible causes of your A/C's failure to turn on, the most common of which are covered in the following handy diagnostic article that comes from yourhandymanzone.com:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Turn_On_At_All.htm
Click on the link, review the article, and, step by step, eliminate the probable causes found therein until one becomes the evident cause of your A/C's failure.
Brad
Jul 21, 2009 | Heating & Cooling
How do u know when there is water in the phone?
There should be a physical evidence !
you can see some kind of oxide or something nearby that image .
Best way always let somebody to check for you who has enough skil to open and operate the phone such as repairman.
Best Regards
Jun 23, 2009 | LG CU515 Cellular Phone
Motor
the evidence presented indicates that the head gasket probably was blown or head/cylinder interface was not flat enough to hold compression and a gasket failure caused the cooling system to drain down into the crankcase.
Nov 10, 2008 | 2007 HM CR 125R
Motor
Nov 10, 2008 | 2005 Hartford HD-150S
Lowrance iWAY  250C GPS Receiver Logo
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
