Question about Mitsubishi VS-45603 45" Rear Projection Television
Brightness "Flicker" Hey Big Irish Thanks for your advise before. I replaced the ICs and it works great. I even made a few mods to improve it. I stuck some IC sockets in so that if the ICs go out again, all I have to do is pull out the old and stick in the new. I also drilled out the head sink and threaded holes to mount the ICs better and get better heat transfer. Before it was some crappy thing that just pushed on the front of them. Any way, now I've noticed that the brightness will come in and out once in a while. Its a minor problem compared to the convergence but it is rather annoying. What could this problem be?
  • Andrew Hawkins
    Andrew Hawkins Oct 06, 2008
    Does the fluid have a color because I've looked a little and it's not something that happens all the time that would indicate damage. Having a blob of "coolent" on a board seems like something that would be somewhat perminent. I do have "IRIS", I think that was the name of the setting, turned on. It initially turned the screen dark. Does this have anything to do with it? what is this setting? thanks
  • 927 Answers
Good Day;
More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
Good Luck, big IRISH.
Posted on Oct 05, 2008
Convergence is bad on left side...good on right.....where convergence is good the picture is great
Re-solder convergence output ICs pins and nearby big resistors that might solve your tv picture problem and if that does not help then replace both convergence output ICs to fix the problem.
Convergence output ICs would be available in local repair parts shop or google it.
Feb 25, 2011 | Sony KP-65WV700 65" Rear Projection HDTV
My sony kp-57ws510 tv is blurry all og the sudden- looks like a 3d movie withouit the glasses.. Please advise
This symptoms comes when convergence out ICs becomes defective and needs to be replaced.
Please check 2 big black ICs on D board of TV that are mounted on aluminum heat sink, replace them and problem will solve.
Call local TV tech for IC replacement if you are not comfortable with TV repair.
Oct 13, 2009 | Televison & Video
Picture getting dark on my 70" mitsubishi projection
Good Day;
It sounds like your lamp is getting weak, replace lamp. Good Luck, big IRISH.
Oct 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Good Day, Hazardsneon;
No, one portion of an IC could fail, but don't replace the one that failed, replace both. Good Luck, big IRISH.
Sep 07, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Good Day, egear00;
This chart shows were voltages are on the ballast. If you the voltages then suspect the ballast, if no voltage suspect the the power source.
Aug 17, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Sony kp53v80 Red convergence stuck vertically
Did you replace the convergence ICs? The 4.7 ohm 1/2wwatt resistors and the pico fuses? Let me know and I will assist you, as often sonys will blow the 3.5 pico and a few of the 4.7 ohm 1/2watt resistors when the Ics fail.
Jul 28, 2008 | Televison & Video
Good Day, Butchilee,
Sounds like you have patience, hope your TV has some trace left. Hit recommends that you replace the originals with
STK-392-150's and the resistors. Replace said items with care then back down on the screen/ focus controls and gradually bring the screens up until you have pic, adjust focus. Go into customer menu and adjust color down, set brightness to 50%, contrast to 100%. Then go back and adjust the screens for proper, black/white, tracking. AND It's best to double check the soldering connections.
Good Luck, Big Irish.
Jul 04, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Bright Screen/ Color Flicker. /Burn in?
Good Day, radiovisuals;
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove the top shield and replace the 10uf, 16v capacitors using Part Number 24619040. It’s recommended that all of the capacitors identified be replaced (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care should be taken to avoid damaging the PCB while replacing these capacitors.) CAPS: cx178, cx221, cx230, cx241, cx250, cx261, cx270, cx541, cx670 & c514, c5030.
Jun 19, 2008 | Toshiba 42H81 42" Rear Projection...
Red will not line up
Good Day y'all;
First of all if the lights are on, that's good, the red light,LED's, indicates that there is power to the power regulator IC. The green lights, LED's, indicate that the DC voltages are present for those particular circuits. ALL GOOD! If off bad!
If after replacing the IC's with the 150's and still have color shift and all resistors are within 2% tolerance and adjustments were made properly. The digital convergence board may be defective.
If the picture is bleeding that normally is a gassy CRT, picture tube, and the bleeding changes with the brightness levels. You may try to rejuv but that may short life the tube.
Good Luck, get back if you want more details, Big Irish.
Apr 21, 2008 | Hitachi 43FWX20B 43" Rear Projection...
Lexmark X1150 printer-fax
Try turning the unit off to reset it and see if this corrects issue.
Dec 13, 2007 | Lexmark X4270 All-In-One InkJet Printer
Televison & Video Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
