My Canon XL-1 has an error code and eats the tape. Before it started eating the tape it wouldn't go into record?
  • galtman Oct 04, 2008
    I believe my error is a tape loading problem. First the a slanted line flashes over a small rectangle, it also flashes wether there is a tape in the camera or not. There is no language of the error, but I believe it to be an alignment problem or head error? Thanks
  • 13,433 Answers
Can you tell us the error code?
Thanks,
Ekse
Posted on Oct 03, 2008
    Genius:
  • 3,422 Answers
Can you please let me know what is the exact error code?
I will then give you some troubleshooting steps which can fix the issue.
I will be waiting for your reply.
  • Priya darshan Oct 04, 2008
    Hi again,
    The problem that you are facing is a common complaint on this model camcorder. The “tape
    error” is the camcorders way of saying something is wrong and it needs
    to be sent in for repair.
    You can try these home remedies first just try switching to another tape and see if you still get that error.If you don't get the same error then the problem was with your tape and is now solved.
    And if you get the same error then you will have to get it repaired.
    You can also look for a small tiny hole on your camcorder it is know as s reset button.Insert a pin in that,press and hold it for 1 min.This see sometimes solves the problem but not always if it is a major one.This reset hole is only on some models.If all fails then you will have to get it repared.
    It is not a defect with the camcorder, it is
    simply the most common complaint when the mechanical assembly is not
    running smoothly and perfectly. There are parts of the mechanical
    assembly that over a period of time wear and also possible defective
    parts that can cause this problem. The average repair cost for this
    repair is usually between $250 and $450 parts and labor. This also
    includes cleaning and servicing.
    If this is under warranty the please send it in for repair as it can save lots of bucks.And if it is not under warranty then you can get it repaired from the below link.Just click on it.
    www.VideoOneRepair.Com
    You will have to pay the price that i have mentioned to get it repaired from the above website.They will also give a 6 months warranty.
    If you need anymore help let me know.
    Thank you for using fixya
I have a Lanier P-127, it has just started to "eat" the tapes. I can listen, but if I eject the tape is caught up inside. Any suggestions?
There is an intermediate rubber roller that keeps the unit from "eating" tapes. When this roller gets dirty or shiny then it slips and the unit will eat tapes. It needs to be cleaned with a q-tip and some alcohol. It runs between the flywheel shaft and the take-up spindle. You should be able to clean it if you take off the bottom cover.
Mar 25, 2011 | Lanier 260T Desktop Cassette Voice...
Eating tape when I try and record or rewind tape
its sounds like the tape deck needs to be cleaned
Apr 13, 2010 | Canon GL2 Mini DV Digital Camcorder
VCR is eating tapes
There are different reasons that a VCR could start eating tapes. It could that it just needs a good cleaning or it could have a mechanical problem you will really need to have it checked out by a service center to determine why. If you have small children I would check it for signs of “peanut butter sandwiches. J
Nov 29, 2009 | Philips Magnavox DVD/VCR Dual Player
GL2 is eating or damaging tapes.
Thgis is a fault in the tape transport mechanism.
It should go for service To open this and try a DIY may well result in it never going back togethyer again properly.
Thanks for using FIXYA
Sep 23, 2009 | Canon GL2 Mini DV Digital Camcorder
Canon NTSC ZR25 MC Digital video camcorder eating tape how can I fix it
Canon NTSC ZR25 MC Digital video camcorder is eating the tape. I've loaded a new tape and get an "eject tape" message each time. Does anyone know how to fix this issue?
Jun 24, 2009 | Canon ES75 Camcorder
My vcr/dvd recorder eats the tapes.
clean pinch rollers and head. check if there is any dirt on capstan post
Apr 30, 2009 | Philips Magnavox DVD/VCR Dual Player
Microcassette recorder is eating my tapes
Try cleaning the heads with a head cleaner and making sure none of the parts have become loose due to extensive use.
Jan 07, 2009 | Sanyo Audio Players & Recorders
Vhs player eating tape
Hunnn....Eats the tapes, with salt & paper?..just a joke!
The tape runs on a guide ( sort of a tiny ledge )when it is fully engaged. The tape cartgage is loaded ' sucked ' in with gears that drop the cartage on top of other switches to give direction, so that "fingers" pull the tape towards the reading\recording heads. When the tape IS aligned properly, BUT is locked in the proper position the tape will NOT touch the upper or lower "ledge" that keeps it accross the heads.When the tape is NOT aligned the upper or lower tape WILL touch causeing damage. OPEN THE CARTGAGE ,Look to see if the upper & lower of the tape is damaged. Now when you say "eats the vhs tape" Does the tape comes out WRINKLE, CRINKLED,CRAMPED UP??? Then that could be ANY wheel with a black rubber rim. going bad. replace if you can. but they are VERY HARD TO FIND if u don't know what u are doing.
May 29, 2008 | Televison & Video
Tape eating
unit need to be cleaned or have parts replaced if they got bad enough.
only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
Feb 04, 2008 | JVC COMPACT VHS-C CAMCORDER
Eating the tape
It sounds as if the takeup spool isn't doing it's job. It could be caused by a slipping belt or slipping clutch assembly. Unless you know your way around the unit (internally) I'd advise a repair shop have a look at it. BMW
Jun 07, 2006 | Sony Handycam CCD-TRV37 Camcorder
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
