Question about Dell 5100cn Laser Printer
Feed problems dell 5100cn
I am having misfeed problems with a dell 5100cn. I have cleaned all the rollers and changed the rollers in the tray .
Still when the feed starts i have a growling , like the pressure is too tight.
In their infinate wisdom the manufacture's decided to make it a rubics cube to get the panels off this printer so i cant get a good look at whats happening. I have looked for a manual but havent been able to find one. could someone tell me how to get these panels off without damaging them!
it was so easy when the japaneese did it all!! at least then it was only 100 screws to remove!
thanks guy i appreciate the help
Pitney
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
Did you replace the two paper feed rollers? The paper feed rollers are located on the inside front of the paper tray cavity. you can see them by removing the paper tray, then peering inside the cavity.
As far as the actual question on how to remove the side covers on this unit, you must first remove the top cover frame.
Top Cover Frame removal
  • remove all toner cartridges
  • press the front latch, and then rotate open the inner duplex assembly.
  • rotate open the imaging drum cover.
  • remove the two screws securing the top cover frame to the chassis. ( be very careful not to drop any screws, as they will fall deep inside the frame. I suggest using a magnetic tip screwdriver.
  • press in the 2 tabs securing the back of the top cover frame. ( use a small flathead screwdriver to insert through the two slots located behind where the black toner normally sits.
  • rotate the imaging drum cover open slightly, and then pull the top cover frame up and back to remove it from the chassis.
Right side cover removal
  • remove the screw securing the right side cover to the chassis. ( this is located at the right rear, inside the side cover near the black toner. again use care not to drop the screw.)
  • press the tab securing the front of the right side cover, and then rotate the cover away from the chassis.
  • remove the cover.
Left side cover removal
  • remove the screw securing the left side cover to the chassis. ( this is located at the left rear, inside the side cover near the black toner. again use care not to drop the screw.)
  • press the tab securing the front of the cover to the chassis
  • lift the cover upward slightly, and then away from the chassis to remove it.
Good luck.
PS. please take a moment to rate the solution.
Thanks
Posted on Oct 03, 2008
  • Cory Friedman
    Cory Friedman Oct 10, 2008
    I hope the information was useful.
    Please take a moment to RATE the solution. If you found it satisfactory, please consider a "fixya" rating.
    Thanks
What would cause tray 1 to misfeed every 12 to 15 sheets? The misfed sheet ends up laying on the edge of the paper tray advanced about 3/8" from the paper stack?
check your paper thickness setting in your drivers
2. clean separation pad at the bottom of the paper tray
3. clean rollers located after the pick up area(registration rollers)
4. check actuators for the sensors to see if they are sticking
Jul 29, 2014 | OKI C9500dxn Led Printer
Misfeed
Pull out the first tray and the second tray.The sensors located on the paper feed roller assy.
Jan 16, 2013 | Konica Minolta Minolta Di351 DiAlta...
My pictures are coming out with pink or purple streaks. Every time I print a picture, the streaks are in different places, all going from bottom left to top right . I have changed the ink roll and the...
Try cleaning the paint roller.
6 Care and maintenance
Cleaning the paper feed roller To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the paper feed roller clean. Inspect the roller weekly for debris particles, and clean if necessary.
IMPORTANT: Unplug the power before cleaning the paper feed roller.
spacer.gif spacer.gif spacer.gif spacer.gif 1.Unplug the AC power cord from the power outlet.
2.Remove the paper tray from the photo printer, and leave the paper tray door open.
3.Lightly moisten a lint-free cloth with water.
IMPORTANT: Do not use cotton or cotton swabs to clean the paper feed roller.
autourg00462006id1604162.jpg 4.Use the moistened cloth to gently wipe clean the surface of the paper feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
5.Allow the paper feed roller to fully dry before reconnecting the power.
Click below for the complete manual:
Kodak EasyShare Photo Printer 500 Manual
Hope this helps.
Zeppelinx12
Mar 11, 2011 | Kodak EasyShare Photo Printer 500
Misfeed from the rear tray. The rear tray feed is not working. When it tries to feed it bends the right corner of the paper and then I get a misfeed message. I can't use the printer to print 4x6 photos...
there could be a teenie piece of paper stuck in the feed path causing this to happen, you have to visually inspect and ensure it is clear. Use plain paper to test.
rollers may also contribute to problems with feeding paper its good you tried that too.
lastly maybe the photo paper is too thick for that printer?
Apr 11, 2017 | Canon PIXMA MX700 All-In-One InkJet...
Regarding my Panafax UF-8000: Why does evrey page misfeed? I started with 24lb white paper and switched to 20lb, but still it is misfeeding.
clean the rubber feed roller/rollers that actually feed the paper from the paper tray.. clean soft lint free cloth dampened with water
Mar 31, 2010 | Panasonic PanaFax UF-8000 Laser Fax
I have an Easy Share printer dock series 3 that has paper loaded
To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the feed roller clean. IMPORTANT: Unplug the power before cleaning the feed rollers.
  1. Unplug the AC power cord from the power outlet.
  2. Remove the paper tray from the printer, and leave the paper tray door open. IMPORTANT: Do not use cotton or cotton swabs to clean the feed roller.
  3. Lightly moisten a lint-free cloth with water.
  4. Use the moistened cloth to gently wipe clean the surface of the feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
  5. Let the feed roller dry fully before plugging the AC power cord back into the power outlet.
  6. Insert the paper tray into the printer, then press the Print button to resume printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Misfeed on lanier 7320
I like your pictures.... Have you tried to clean the feed roller with a slittly damp rag with Simple Green or WD-40? You can try that and wipe the extra off. They both clean the rubber roller's. If that works good, that means the feed rollers are worn and need replacing. But you may also need the paper pick-up feed clutch. You said you can still run paper throw the by-pass. Good Luck
Dec 11, 2008 | Office Equipment & Supplies
5100cn paper not stacking correctly in output tray
Hi MCRES,
I am attaching a photo for reference of the outer duplexer assembly of the 5100 printer.
This the area just to the right of the yellow arrow is what moves the paper from the exit of the fuser to the top output bin. ( it also brings the paper back in when duplexing ).
Those are the rollers that I believe you are questioning, however, this unit is an assembly, and those rollers are not replaceable.
I can tell you however, that I have never had a situation that required those rollers to be changed.
What I would suggest is that you clean the rollers with a lint free cloth and rubbing alcohol.
Also check the printer while printing and try to observe that it is not actually the front edge of the paper coming out getting hung up on something ( even a small bur on the plastic ) that may be preventing it from exiting all the way.
Oct 27, 2008 | Dell 5100cn Laser Printer
Dell 5100cn paper not stacking in the top output tray
Hi mcres,
I believe that I addressed this issue on the repeat post you made on 10/27/2008.
the following is the answer I posted there
Oct 23, 2008 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Logo
330 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
