Question about Dell Latitude D600 Notebook
D6000 DELL LAPTOP
PRIMARY HARD DISK DRIVE 0 NOT FOUND
NO BOOT DEVICE AVAILABLE
Two messages received when switching on.
Can you HELP????????????
  • keitck3 Oct 03, 2008
    sorry where can i locate hard drive
  • ramdular May 11, 2010
    y hgkgk kjhio
  • 63 Answers
Do you have any flash drives or external drives connected? If so unplug them and try to reboot. If not check to see if the hard drive is firmly in place sometimes they can come un hooked and that error will appear.
Posted on Oct 03, 2008
  • Exidous
    Exidous Oct 03, 2008
    Look under the bottom of the case it should look simmular to this
    Remove the screws there will only be one or two. then carefully push on the bottom of the hard drive to make sure its firmly in place.
My dell leptop refus starting i got message : Primary hard disk drive not found , CDBOOT ; Memory overflow error
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 16, 2012 | Dell Latitude C800 Notebook
My dell 5150 dimension will not boot up and says no boot device available. I have gone into system setup and tried a few things and at one point got a message that said drive 0 not found and now it is back...
Go back to setup and check your boot sequence. It may not be looking for your hard disk. Do you know what Hard disk you have? It may not be wired in there properly if it's in the boot sequence. Set DVD/CD to 1st boot device and put in your installation disk. Do you boot now? Do you have data on your hard disk you need? If not, Re-format the drive.
Nov 07, 2009 | Dell OptiPlex GX280 PC Desktop
Dell Inspiron 8500 started boot error message ?primary hard disk drive 0 failure, no boot device available?strike F1 to retry reboot, F2 for setup. Ran express diagnostics and it shows two errors: Error...
Call Dell if under warranty. Start shopping for a replacement hdd if outside of warranty. You'll need
your OS disks that came with computer (hopefully). If you don't have OS/recovery disks, you can get
them from Dell or even using somebody elses (match version with sticker on your laptop).
Check the hdd connection underneath laptop - make sure cable is not loose, etc.
Probably safe to say your data is gone unless you're willing to spend $$.
Jul 12, 2009 | Dell Inspiron 8500, Latitude D800...
Dell inspiron 5150 primary hard drive disk 0 not found
You may find that either the cable is not connected properly or is faulty, or the worse case the mother board has problems (driver, chips, breakages)
May even be a power supply problem, as the power supply has many output points and different voltages that the HDD power out may have blown. If it has then the rest of the system will appear to be ok.
So first off, check the cables connections on the motherboard, and look for any breaks in the cables, and if you have a power meter of some sort check the power connection, or plug in another power connector, the ones with the same end are generally the same power outputs. The ribbon cable for the HDD should have 2 sockets for HDDs and you must connect your HDD to the end one.
May 14, 2009 | Dell (U0614) for Inspiron 5150 60 GB Hard...
Dell 8250 Hard drive 0 not found after move from US to UK
IT sounds like the hard drive went bad, especially with the clicking noise. If you want to keep the system, you will need to buy a new drive (relatively cheap) from tigerdirect or newegg and istall it. NOt sure if dell still send out recovery cds with their systems but if you have one just insert the cd after you install the new drive and follow the prompts. If you do not have one contact dell support and they should beable to send you one
Jan 21, 2009 | Computers & Internet
No boot device available
Make sure all the connections to the Hard Drive are tight and secure. Then see if it will boot. If not then try loading a windows cd and see if it detects the Hard drive. If it does not the hard drive is no good if it does try running the automated system recovery you may have a corrupt MBR file.
Dec 22, 2008 | Dell Dimension 4400 PC Desktop
Primary hard disk drive 0 not found
Hi Kenneth,
If you just bought the laptop, then it is still covered by a warranty. Then all you have to do is contact the seller or directly to dell. This is the fastest and most appropriate way, and usually you will get one-to-one replacement (they will replace your laptop with new one). But, please make sure by contacting Dell.
Regards,
dC
Dec 12, 2008 | Dell Latitude D600 Notebook
Dell latitude c640. comes up with error immediately after ram check displays... "primary hard disk drive 0 not found no boot device available - no bootable devices--strike F1 to retry boot, F2...
Seems to be a problem while detecting the hard disk. Please contact customer service if the laptop is in warranty.
Let me know what happens.
Apr 30, 2008 | Computers & Internet
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Laptop won't boot..
try new hard drive 1st ok
Jan 30, 2008 | Dell Inspiron 8500 Notebook
Dell Latitude D600 Notebook Logo
633 people viewed this question
Alun Cox
