Question about Nokia N95 Cellular Phone
Scroll function My N95 (not 8GB version) will scroll up and laterally but not down. Turning phone off then on again has no effect. What next
  • Nokia Master
  • 1,800 Answers
U need a replacment of the underbutton copper its in under the keypad becarefull
of taking the phone apart
Posted on Oct 04, 2008
About a month ago my archos began freezing and then stopped turning on all together. I took all the necessary steps to recover my device as stated on the archos website,even updating the firmware, and my...
Under Settings, scroll down and confirm whether 'Developer options' is active?
Where you can't find this present, you have to configure/activate this option yourself.
Steps/tips
1. Go to the settings menu, and scroll down to "About phone." Tap it.
2. Scroll down to the bottom again, where you see "Build number."
3. Tap the 'Build number' six-seven (6-7) times.
After the third tap, you'll see a playful dialog that says you're four taps away from being a developer.
Keep on tapping, and VOILA, you've got the developer settings back.
Exit about phone, select developer options, scroll to USB debugging and check box to activate.
Try your USB data cable connection again.
Best of luck.
Oct 10, 2017 | Archos 28 Internet Tablet
I upgraded my motorola defy to android 2.2.2 now camera wont take picture. Camcorder works fine. Us it fixable?
The Camera is an application itself and stores user data. It is typical when upgrading Android Operating System that some application previously installed experience conflicts with the new system usually because of user data.
This can be fixed by resetting or clearing that application's user data; in effect "factory resetting" the application only- not the phone.
1. Navigate to your phone's "Settings" via menu button.
2. Scroll down to "Applications" and select it.
3. Next, select "Manage applications."
4. Now, select the "All" tab
5. Scroll to find "Camera" and select it.
6. You may now select "Clear data" to reset your Camera application to it's original state.
Now start taking pictures again.
Jul 07, 2011 | Motorola Mobility Defy Cell Phone
How do i turn my keypad sound off on my corby pro without turning off my ringer
Go to settings-> phone profiles and tap on the [>>] icon next to the profile for which you want to make keypad silent (for eg:- normal). from the drop down menu at top right, select phone sounds. Scroll down till you see 'phone sound volume'. Reduce it to zero. Done!!
Apr 17, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
MY XEROX 7500DN when start up gives a error -warming up and hangs up...
Your fuser lamp has probably blown. Only solution is to replace fuser. After replacing fuser, you will need to go into diags and reset tech rep faults.
Press and hold back button and info button whilst turning on printer. This will put you into diags. Scroll down to NVRAM access and select. From there select reset tech rep faults. Not sure which set of faults so reset all three by highlighting and pressing ok button. You will return to the previous screen, so select reset tech rep again, scroll down to next set of codes, press ok again and so on. Once all three have been reset, press back button to go back to NVRAM access, scroll down to exit and press ok. Machine will now reboot.
Dec 03, 2010 | Xerox Phaser 7750DN Laser Printer
Lost my internet, wont load so need settings please
  • Navigate to your cellular provider's website or call its customer service line. Access the "Support" section of the website or ask for the technical support division. Find the "Access Point," "MMS" and "Wap Gateway" settings and write them down.Power on the HTC phone and then press the soft key on the left side to bring up the main menu screen. Scroll down through the menu and highlight the "Settings" option. Press the square button at the center of the phone to access the settings menu.Choose the "Connections" option from the settings menu. Scroll down through the new list that will appear and choose "GPRS." Highlight the "New" option and press the center button. Choose "Connects To Internet."Scroll down to the "Internet" heading and choose "Change." Key in the Access Point that you wrote down earlier. Scroll down and press "Done.Navigate back through the menu to the "GRPS" option. Press "New" again, and this time, choose "Connects To Wap." Choose the "MMS" option. Key in the MMS settings you wrote down earlier.Return to the main menu screen and then select "Messaging." Highlight "MMS" and press the right soft key to bring up a second menu. Choose "Settings," and then choose "MMSC Settings."Press "Edit" and enter in the "MMS" settings again. Scroll down to "WAP Gateway" and enter in the information you wrote down earlier.Power cycle the phone by turning it off and then back on to complete setting up the WAP settings.
  • Oct 01, 2010 | HTC Cell Phones
    How do you change the arabic language to english on a nokia phone
    This will work for all 2630's from whatever language it is currently set at to your desired language. Press the center square button to get the menu. Scroll down until you see the small wrench - menu #4. Press the square (Select) button again. Scroll down to #9 - the icon will look like a small phone with a wrench - press select. Press select again - menu #1. Press select again - menu #1. You should be able to see English as an option. Scroll down and select again and you should be good to go. The Nokia menu sequence is: Menu, 4, 9, 1, 1. Unfortunately, this phone does not do jumps - so you must scroll down manually.
    Jul 10, 2010 | Nokia Lands Phones
    I keep getting internet script error messages even after ive installed an updated version of adobe flash
    use the later version of yahoo messenger then 7 and before the latest one
    Dec 10, 2009 | Yahoo Messenger
    My screen scrolling only works intermittently. It lets me scroll in all directions, but sometimes it will think that my scroll is actually a tap, etc. Sometimes it will scroll fast, then 1 second later it...
    i think ur ph memory really full
    do u install too many applications and games ???
    if it is delete and uninstall some application and then try again
    it ok for me
    Oct 28, 2009 | Apple iPhone Smartphone
    How to configur tally tcp/ip address
    take printer offline
    press mode button
    scroll up or down until you see TCP/IP displayed, then press the # 1 button
    TCP/IP address is displayed, then press # 2 button
    IP address class A is displayed, then press # 3 button
    scroll up or down until you see 192 press enter for *
    next press # 2 button again scroll until IP address class B is displayed, then press # 3 button again
    scroll up or down until you see 168 press enter for *
    next press # 2 button again scroll until IP address class C is displayed, then press # 3 button again
    scroll up or down until you see 145 press enter for *
    next press # 2 button again scroll until IP address class node is displayed, then press # 3 button again
    scroll up or down until you see 69 press enter for *
    You need to repeat this procedure for the Subnet mask and Gateway...
    I'm sure you have fixed your problem by now, considering your request was Mar 19, 2009
    Have any questions
    Call x311
    Mar 19, 2009 | Tally Line Matrix T6100 Printer
    Nokia N95 Cellular Phone Logo
    24 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
