Question about Motorola Mobility A780 Cellular Phone
Motorola A780 Master Reset option wont let me click..Help..Thanks
I can find my master reset on my mobile, but somehow it wont let me click on it. and also all my icons have turned into exclamation marks.is there any solution for this other than sending it to the repair service? thank you for your time and help in advance.
  • Anonymous Apr 03, 2009
    I have the exact same problem as described above on my A780...please someone come up with a solution for this since I both the phone in the US and now I'm in Europe (the US warranty would not be of help here)
ARE YOU TRYING THIS WITHOUT SIM?
Posted on Jul 05, 2009
I HAVE A BOOST MOTOROA BT50 CELL PHONE AND I NEED TO FIND OUT HOW TO MASTER RESET IT CAN ANY ONE HELP?
Doing a master reset on ANY phone is a last resort in fixing any problems with your phone. Unless you have a memory card to store all your info on, u may lose everything on your phone, including contacts, pics, and bookmarks. Before you consider doing a master reset, contact the Boost Mobile service provider. Boost Mobile uses the Sprint network, so maybe contacting them is a good place to start. And if they suggest doing a master reset, they will tell you how to perform this action. Before you do, write down all the personal info you have saved on your phone!
Jul 09, 2011 | Motorola Mobility Boost Mobile...
How can reset my motrola razer v3x without secret code plese help me
Hello, You can perform a master reset to dissolve any glitches, bugs or other complications you experience with a Motorola Razr V3x. According to the device's user guide, a master reset will reset all options in the phone, with the exception of the "unlock code, security code and lifetime timer." Back up any data, pictures, or contacts you wish to keep before performing a master reset on the Motorola Razr V3x
1 Navigate to the "Settings" menu using the directional arrows. Click the "Setting" option with the "Center" key on the phone. 2 Press the "Center" key to choose "Initial Setup" from the Settings menu. 3 Press the "Center" key on the keypad to select the "Master Reset" option from the Initial Setup page. Thank you for using Fixya
Dec 28, 2010 | Motorola Mobility RAZR V3x Cellular Phone
How to remove message saying "emergency calls
If "Airplane Mode" is activated, this could happen, otherwise there's no other settings to deactivate or activate the offline mode with this Model. The "Airplane Mode" is under Settings, make sure it's Off.
You can also check the Network Setup under "Settings" and make sure "Automatic" is selected.
I would also recommend you to try with another sim card. If the same problem persists with another sim card, try resetting the phone "Master Reset". There are two options to reset your phone, 1. Master Reset and 2. Master Clear. Master Reset will reset every the phone settings to factory default while Master Clear will reset the phone as well as clear all the data from the phone and will restore everything as it was when you bought (as a new handset).
To do Master Reset, open "Settings" then "Initial Setup" and "Master Reset", you'll be asked to enter the security code, type in 1234 and proceed, if 1234 doesn't work, then use 000000 (6 zeros).
Note: if you have changed the code, you should use that.
Even resetting doesn't help, then there must be Network Problem with your phone, perhaps, the Network IC. In rare cases, Antenna causes this issue. Or sometimes it's related Software. All these are to be checked/done at Motorola Service Center or at local Mobile Repair Shops.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Dec 08, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Need a master reset for motorola rokr e8...forgot my security code...please help me..thanks IMEI 352490 / 02 / 023562 / 5
To Unlock the Mobile from the Password or the Security Lock use the Master Reset Code,You can Check Master Reset Code for Your Model Mobile at
http://www.mobileunlocksolutions.com/unlocking-services/rs1wp6/
Nov 17, 2010 | Motorola Mobility ROKR E8 Cellular Phone
I forgot my unlock code, and i would like to know if i can just master reset the phone?
yes you can do a master reset to restore it to factory but i would try a soft reset first. it will also do what you looking to do but it wont erase your data . i have included a full list of codes . try the master unlock code first.
Code Action
*7 Use to lock/unlock the mobile keys
19980722 Work as "Master key" to unlock the Motorola sets
*#06# To display the IMEI Number of the mobile
*#403# Press keys to get information about mobile manufacturing
*#301# Use to test the functions of the keys
*#303# Use to reset default language to English
*#300# Use to display the mobile software2.gif/hardware version
*#311 Use to reset the default code of mobile
*#402# Use to regulate the mobile display strength/intensity
*#304# Press keys to OFF the engineering mode
*#304*19980722# Press keys to ON the engineering mode
*#0000# Use to reset Motorola mobile default language
1234 Default Motorola mobile code
32*279*1*0*8 Use to verify the mobile model
#PROGRAM# Use to change the default banner of mobile
##33284 Use to run mobile in Debug mode
#02#* Use to display the mobile software version
*#42253646633#
Use to enable COM port
*#987*99#
Use to restore the Motorola factory settings
#32# Reset the mobile timers
###119#1# Use to make active the EFR mode for mobile
###119#0# Use to make deactivate the EFR mode for mobile
Nov 13, 2009 | Motorola Mobility i425 iDEN Cellular Phone
How do i reset my razor?
Hai,
You can reset your phone, erase all data and content, by performing a master reset. Here's a link to the instructions:-
1.Go to the "settings" option from your Mobile menu.
2.From there select "Initial Setup"
3.And extreme below you will find out Master Reset and Master Clear.
4.Click on what's appropriate.
5.DONE!
Hope this Helped
Aug 26, 2009 | Motorola Mobility RAZR V3i Cellular Phone
How to i master clear a verizon razor V3m phone?
what you should do is take the phone to a mobile store then and have them reset it for you
Dec 31, 2008 | Motorola Mobility RAZR V3
MASTER RESET
The Motorola W385 does NOT have a "Hard Reset" option.
Aug 17, 2008 | Motorola Mobility RAZR V3
Cell Phone
There is a master reset but that is on the phone and if you can't get the phone to do anything this seems pretty useless! However the master reset can be found by going to the settings menu, initial setup and if you scroll down the master reset option can be found there.
Jan 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility A780 Cellular Phone Logo
241 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
