Changed Ports and keyboard still won't function. It started out with the middle row of keys not working, now the entire keyboard will not function. I've had the board for about 6 months. Bought it from Staples
  • Dianne Arthur
    Dianne Arthur Oct 04, 2008
    Thank you for your response
  • 4,472 Answers
Then most likely the keyboard is still under warranty, and you will want to go through the manufacturer to have it repaired/replaced. I assume you tried a different keyboard and that one works fine on the computer? Was any moisture introduced to the keyboard. This is usually the case of this happening. If you need any other assistance let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
Posted on Oct 03, 2008
  • Lee A.
    Lee A. Oct 04, 2008
    Your very welcome have a great day and good luck.
    Thanks,
    Lee
    Genius:
  • 3,422 Answers
HI,
The problem is with the cable of your keyboard.
You will have to get this keyboard replaced.
I hope this is under warranty
  • Priya darshan Oct 03, 2008
    I suggest you to once try connecting this keyboard to a different PC and then let me know if its works or not.
    If the keyboard still doesn't work then there are no home remedies to fix this issue as the fault is with the cable of your keyboard which cannot be repaired.You will have to buy or replace your keyboard with a new one.
Why doesnt the third row of keys on my keyboard do not workk
The keyboard itself is defective. The keys are "strung" together in groupings. The T just happens to be on another string then the top row.. To verify you can easly hook up an external keyboard and verify that it works. Once verified it all works then the problem itself will be in the keyboard. Replace the keyboard. You can easly find them online and are not that expensive or hard to replace.
May 15, 2014 | HEWLETT-PACKARD ProBook 6460B
Keyboard won't type
go to keyboard setting in device manager. check all keys if work properly. u might have your keyboard set to a different format
Oct 22, 2017 | Logitech G15 Gaming Keyboard
I have a studio 1749 my problem started after i removed the keyboard to clean it because of the dusty enviroment i work in. After putting the board back in i noticed the entire 2 bottom rows of keys didnt...
it's more likely you haven't put the ribbon cable back properly. try removing the keyboard again and reinsert the ribbon cable carefully - remeber there is a bable grip that needs to opened to remove the cable and closed again after insertion to maintain contact
Apr 11, 2011 | Dell Studio 17 (1749) Laptop black -...
Keyboard double letters showing
there is short in the data cable
may be some liquids spill inside it
you have to clean it and if this fail may the keyboard controller on the mother board is corrupted then you have to use external K.B or change the Mother Board
shadi
dont forget to rate my solution
Jan 24, 2010 | Dell 0Y3740 Keyboard
I have a sony vaio lalptop and some letters are not working at all: 9,o,l,,,. (I am on another laptop). Help
Hi treborswindl
Look on the keyboard to see whether any of the function keys on the top row are on. If so, you have to turn it off.
How do you do it?
Locate the [FN] key at the bottom (this is the function key between the [CTRL] and [WIN] keys.
Hold down the [FN] key and the numbered function key which is on ( for example F11 ) the top row which is lit.
Goto Microsoft word or Notepad and try out your keys.
Hope this will work for you.
Good luck
luciana44
Dec 02, 2009 | Sony VAIO VGP-WKB1 Keyboard
Keyboard keys refuse to work
Generally when a row goes out the keyboard is shot and needs replaced. How did you rule out hardware issue?
Jul 24, 2008 | HP Pavilion N5150 Notebook
Microsoft Wireless Multimedia Keyboard 1.1 not working
Could be spyware or a virus. Try this.........If this does not help let me know.
Turn the system restore off. System restore keeps everything in restore. Meaning......... If you have spyware or a virus, it will stay in your system. Run Spybot S&D (This program is free and is better than using msconfig as long as you go through the settings and change everything to the highest settings.) Then do the same with Adaware 2008 (sounds stupid to use 2 things for spyware, but one catches what the other one does not.). I have links on my website (tandnfamilyelectronics-online.com). These links go directly to the download so you will not get the run around. You would do good to try a program called Window Washer. This is a great program that completely cleans anything in your computer that you do not need. It will not clean out anything that you have to have. I have used this for years to clean out my customers computers and have cleaned as much as 3 gigs of trash out. If you contact me I will give you some tools that I have for free that will do a great job on your computer. I have them ready to download and I will give you the link. (dean@tandnfamilyelectronics-online.com)
Window Washer free Download.
May 29, 2008 | Computers & Internet
Notebook Keyboard, some Keys doesn't Work. Replace the entire Keyboard??
Remove the keyboard and check if the cable is plugged into the laptop correctly which is usually not the case. Usually the keys may have been damaged and you may have to buy a keyboard replacement.
Aug 25, 2007 | Fujitsu Siemens CELSIUS Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
