Yamaha RX-V596 Receiver Logo
Dean Lindstrom Posted on Feb 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have had my Rx-V596 receiver for years and just last week I started hearing a constant humming thru the speakers regardless of what input source is selected. I have checked all the cables and can not get rid of this annoying hum. Any ideas for what could be causing this and how do I fix it?
Terry Weaver
Level 3:
Master:
  • Master 412 Answers
  • Posted on Feb 03, 2018
Terry Weaver
Master
Level 3:
Master:
Answers
412
Questions
Helped
120094
Points
1235
Most likely suspect is a breakdown of a capacitor, probably in the power supply -- one of the few modern electronic components that go bad over time. You'll probably need a Yamaha service center to get it fixed -- they'll give you an estimate before starting, but it may be a better investment to upgrade to a new receiver. It takes a skilled tech to fix this at the component level -- doubtful that replacement boards are available.
5 Related Answers
Tarique Islam
  • 4 Answers
  • Posted on Sep 01, 2007
SOURCE: Yamaha RX-V596 Receive turns off after pressing Power
Sometimes the receivers turn off if the speakers are shorted in order to protect the AMP circuit. So try this - 1. Disconnect all cables (speakers), inputs from Tape Deck, VCR and other input devices), sub-woofers, rear speakers all. Except the AC power cord. Then turn it ON and see if it stays on. If it still has the same problem, then most probably your power circuit inside the receiver has a problem - like a shorted Capacitor or diode etc. Based on how technical you can be and what resources and time you want to spend, this is repairable. But based on the price of a receivers these days, it is not worth. Good Luck!
Anonymous
  • 1512 Answers
  • Posted on Feb 16, 2008
SOURCE: Memory guard on
Hi Rocco
I too have searched the user manual on this unit, and have not found any reference to "memory guard". Can you give me more information about the feature you are trying to operate and I will try to assist you further
Here is a link to a PDF version of the manual for free. Just enter an email address and there you go.
regards
Graeme
Anonymous
  • 8546 Answers
  • Posted on Feb 19, 2010
SOURCE: Is the Yamaha RX-V596 capable of using HDMI in
Nope. Use S-Video or composite video In and digital audio in from the Cable Box, S- or composite-video out to the TV/Monitor.
OR (what I do) skip the receiver as a video middleman and take the HDMI video right to the TV; and run the Cable Box digital audio to the Receiver.
Grubhead
Grubhead
  • 5755 Answers
  • Posted on Mar 01, 2010
SOURCE: how do i hook up an ipod to the rx v596
If you get a dock and a 3.5mm plug to two RCA phono plugs lead, it will then connect to any spare aux imput socket. At the same time the dock will keep the battery in the i-pod charged. Or you can just plug the same lead into the headphone output of the i-pod, but the battery will run down.
Anonymous
  • 1285 Answers
  • Posted on Jun 20, 2010
SOURCE: Hi, I have a Yamaha RX-V596 that all of a sudden
reconnect all wires (make sure are placed in correctly) and make your connection with wires kind of tight (no druppy wires if extra coil it up) between devices....your receiver should have small wire hanging this is the antenna and the other wire should be grounded...and should take care of the humm....
feel free to rate the help
Major hummimng noise when sub is connected to receiver.
Is the hum in the receiver-attached speakers or the sub?
Self-powered sub?
How is the sub attached - RCA or speaker-level?
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
If it hums with the sub attached, unplug the sub's power cord. Differences in AC ground potentials will generate hum across linked devices.
Hi, I have a Yamaha RX-V596 that all of a sudden developed a hum throughout ALL speakers, it is coming from the receiver. Any idea how to fix it? Thanks, Adam
2answers
Can an ipod or mp3 player be hooked to a Yamaha RX-V596, using an auxliary cord
Typically you can find an adapter / cord that contains a 3.5mm headphone plug on one end and a pair of RCA plugs on the other. These RCA plugs should be able to be plugged into any available input on a receiver that isn't a PHONO input. These cables can typically be found online at various different places. Not to promote one site over another, but I have had good luck finding random cables like these at Cableswholesale.com and allelectronics.com. Hope this solves your problem.
Thanks,
Ben
1helpful
Yamaha RX-V596 main rigth channel problem
The right or left (side) output channel has blown out. If it uses discrete transistors you'll have to replace two of them (one PNP and one NPN) along with several resistors that are part of the circuit (I'm guessing the static occurs on any input source).
Now , if the static happens only on certain input, then the problem should not be in your amp.
2answers
Hooked up to sony bravia 52" tv and can barely hear sound
You'll want to turn of the TV speakers in the Remote Menu and try turning up the volume level of the TV, which usually controls the level of the RCA outputs, as well
Rx v2095 receiver - No sound from either front main speaker
I have had similar problems on a Denon. I suspect your DSP needs repaired and/or replaced. Need to contact authorized Yamaha repair shop or a competent local repair facility. I have a Yamaha RX-V2092 which is similarly designed. I have had it for 10 years. Hope this helps.
Hooking up this receiver
I don't see why not. I have a 46" Sony Bravia HDTV that I have hooked up to my RX-V596.
Just use either the RCA out on your TV to the "TV " RCA audio in on the receiver, or if your TV has Optical or Coaxial Audio Out use those...
RX-V596 center and rear channels do not have any sound
Nevermind... My center channel output was set to "NONE" I've had this receiver for a few years now, probably set it that way back when I got it. Oh well, Helps to re-read the user manual...
The info is in the "SET MENU" section of the manual, Pages 35-38. Should solve the issue for "almccrum" above as well.
If you don't have your manual it can be downloaded here:
www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V596.pdf
3helpful
Input selector on my Yamaha RX-V596 stuck
Hi Dush
Sounds like the processor has locked up in the unit. Try powering it right down from the wall socket for a day to reset, and then retry operation. If that does not work, leave it disconnected for about 10 days to erase backup memory completely and then try again. Good luck. Don't forget to give me a "FixYa" rating if this works. If it doesn't, get back to me in here and we can talk more about it.
regards
Graeme
1helpful
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
