I need torques specs for the head bolts on a 99 f350 super duty 5.4l
Check this information for 1999 FORD TRUCK F350 SUPER DUTY P/U 4WD 5.4L EFI 8CYL and keep in mind that cylinder head bolts must be replaced with new ones. They are torque-to-yield designed and cannot be reused.
Tighten the cylinder head bolts in the sequence shown in three steps, as follows:
Image Zoom Link : large/0900c152801e5215.gif
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.
Thank you for using Fixya, and have a nice day
SOURCE: Engine Bolt Torques- 2005 Chevy Impala/3400 Engine
Head Bolts
Step one 37 ft lbs then tignten 120 degrees more
Rocker arms
Step one 11 ft lbs then tighten 90 degresss more
Upper intake
89 inch lbs
Lower intake
132 inch lbs
SOURCE: 87 samurai bolt torque specs for engine
The haynes book is not recommended since there are numerous mistakes and they still will not update. One of the biggest is the firing order.
The factory service manual is the only way to go.
Head bolts - 46 - 50.5 lbs (there is an order sequence for the bolts)
Intake & exhuast manifolds- 13.5 - 20 lbs
Flywheel - 41.5 - 47 lbs
Clutch cover - 13.5 - 20 lbs
SOURCE: torque specs for toyota tercel
Hello vienotkelly: The correct Main bolt torque is 42 foot pounds. The connecting rods torque to 29 foot pounds. The torque sequence for the head bolts and the correct way to tighten the bolts are attached to this reply. Thak You for using FixYa. Roger
SOURCE: Front Hub Bearing Torque specs to complete replacement
THE LUG NUT TORQUE SPEC - 140FT/LBS\
CALIPER MOUNT - 80FT/LBS
CALIPER BRACKET 129FT/LBS
AXLE NUT 177FT/LBS
SOURCE: head bolt torque specs for 2000 dodge neon 2.0 SOHC
I have the specs and diagrams. If you want me to send them to you, give me your email address. [email protected]
