Question about Belkin TuneBase
Static...annoying static... I just purchased this transmitter...I have it plugged into the lighter, it works, but there is static, doesn't matter what radio frequency that I tune into. The radio and the transmitter are dialed into the same frequency...the music comes through loud and clear when my hand is touching the goose neck, as soon as my hand is away, the static is back. I am frustrated, I used to have a $10 transmitter that only had 4 setting 88.1 - 88.7 and it worked great...I spend $100, and it has static galore...am I doing something wrong, is there an external antennae I don't know about...I read the instructions a few times and I can't figure it out...HELP ME OBI WAN, YOU'RE MY ONLY HOPE...
  • 4 more comments
  • jpieson Dec 25, 2008
    Same thing. Exactly.
  • Anonymous Mar 13, 2009
    Same here
  • Pristine84 Mar 21, 2009
    i just purchased my tunebase fm for ipod and as soon as i release my hand from the device it has so much static and i can't enjoy my music.
  • Anonymous Apr 05, 2009
    I wish I wasn't just saying "same here", but, ah...same here.
  • Anonymous May 11, 2009
    same here. funny thing is my sirius satellite sounds so much better on same frequency. unplugged everything (sat, bluetooth cell, cell charger, removed car antenna) and STILL horrible static. HELP?
  • Anonymous May 20, 2009
    I have the same problem...so annoying when you pay so much for something to work.
  • Belkin Master
  • 4,526 Answers
I use a cheap Mp3 player and transmitter combined and it works very well. Why a more expensive product should be so disappointing it is difficult to guess.
The obvious answer is the the unit is faulty if it doesn't perform as the instruction manual and advertising suggests and probably should be returned to the retailer for a refund.
It is possible the display is telling lies and the actual transmitter frequency shifts when no one is holding the gooseneck. It might be necessary to tune the radio slightly off-frequency for clear reception.
It could be second channel interference and so tuning to the other end of the radio scale might be useful. Mine is tuned to 108 Mhz because the band there is completely clear.
It could be the signal to noise ratio is elevated due to inefficient grounding of the power socket or it is possibly picking up electrical interference from some device in the car's electronics.
The fact that you have already used a transmitter successfully in your car and others are complaining of the same problem, it would indicate China has exported a bad batch with the same or similar faults - maybe the gooseneck should be grounded and isn't...
I suggest you visit the retailer and express your displeasure and show him a copy of your complaint and the other comments.
Posted on Apr 01, 2017
2 Suggested Answers
SOURCE: Belkin TuneCast FM transmitter for samsung t9
I just bought this transmitter and i plugged it into the car and my samsung mp3 player and it will charge the player but you cant hear any music even when i tune it to a vacant radio station.
Posted on Aug 20, 2008
Have a set of speakers home 120W/channel that very often let heard through them very annoying static. Have use others amplifiers: hasn't done one single change. Static seem to come from tweeters.
Static electricity could be causing the static . It's possible the way they were soldered together That's what I was told so I got sick of the static and gave my old ones away and got another set of speakers. They work fine. Was also told it could be the plug ins for my amp as well not being tight enough.
Jun 23, 2017 | home Audio Players & Recorders
Work fine for about 5 minutes than change to static
There's an auto-shutoff feature which kicks in when the audio input to the transmitter is too low. That's usually indicated by the green light on the transmitter turning off. Just increase the volume on the device connected to the transmitter, and you should see the green light come back on. As long as that's on, it'll stay transmitting and shouldn't just cut out to static.
Jun 25, 2014 | Sennheiser RS 120 Consumer Headphones
Crackling static in sound
reduce the volume of the microphone
Mar 25, 2014 | HP ProBook 5310m (FM997UT) PC Notebook
We have recently purchased a new home and the UBHK-25J21SFA air handler makes a whistling little tune and then the heat comes on. Never fails to work but noise is annoying.
Make sure the air is balanced... air handlers are rated @ a certain design static pressure. The static rating is on the air handler tag. Have someone measure that static. Too often hvac installers don't know much about airflow & they will undersize ductwork. Then again it could just be a dirty coil.
Nov 27, 2013 | Heating & Cooling
Is there any way to stop the auto turn off feature?
Not unless the transmitter has audio going in at all times. It's a pain. I just try to remember to switch them to off when I will have no sound for a minute or two. It's annoying, but better than that loud static.
Dec 29, 2010 | Sennheiser RS 120 Consumer Headphones
Static during calls
My 8320 had the same problem as daisy's. In addition to that..my camera's colors were wacked. Like negative images or something...Anyways..I noticed when my phone was plugged in, the problems disappeared. So i purchased a new (non-OEM..paid like 15$) battery online and the problems disappeared. Has been fine for about two months since doing this.
Jan 21, 2009 | RIM BlackBerry Curve 8310 Smartphone
Static
A simple monopole antenna tuned to the FM band should be almost 3 feet long. Notice that your Belkin box doesn't have that. When you touch the gooseneck, you couple some of the signal out your arm, and you become the antenna. Sort of.
Also, your car radio antenna is in a terrible position to receive it. It may even be on the roof of your car, which is great for receiving vertically polarized FM stations from far away but bad for receiving signals from inside the car, through sheet metal.
The other problem is that there are legal limits to what these gadgets can transmit. I had one that really stunk, and when I took it apart it had a spot labeled "ANT" on the circuit board, and with a 32 inch piece of wire attached, the power radiated was 20 dB higher ... that's 100 times as much. I picked it up almost 100 feet away. Your old one probably put out too much power.
Now if you wound a couple foot long piece of wire around your Belkin and fooled around with it a bit, you'd probably notice that the signal comes in nice and clear, because it takes the place of your arm grabbing the gooseneck. You could clip the other end somewhere where it wouldn't rattle around. But, you know, that could be ******* and folks in cars around you might hear it.
Apr 01, 2017 | Belkin TuneBase
I have placed mp3 files on a usb stick, to play in car, pluged into a cigarette lighter socket fm transmitter. the problem is it plays but has a lot of static or vibration to it. i have checked the...
Check to make sure the fm transmitter is digitally locked on the correct station on the radio and that the end that fits into the cigarette lighter is tight. The end twists on, so make sure it is tight.
the fuse is under that cap.
My transmitter has 7 channels to choose from. beginning with 87.7,87.9,88.1,88.3,88.5,88.7,88.9
Apr 04, 2008 | Audio Players & Recorders
Static comes from speakers
I think it's a grounding problem. Actually, it's a necessity for all audio-video equipments to get grounded properly. If you don't have a ground connection in your AC plug, your receiver will collect more and more static electricity. As a matter of fact, it decreases the sound quality that you can get from your equipment. I think that the effect of your reaction (slapping the receiver) isn't coincidental. When you touch any metal surface on your receiver (even while slapping) you condact the static electricity to the ground. I've had a same sort of problem with my receiver. Especially when I connected my laptop computer to the receiver, I heard an annoying distorted sound from the speakers. I found out that it was ground loop, which occurs when the negative (common) signal of the source coincides with the one of the receiver's. As a solution, I grounded my amp, changed all wires with new and shielded ones, and purchased an AC filter. Then, I got rid of the noise. I have to say that the AC filter (Belkin Pure AV Surge Protector, it also includes an AC signal filter)benefited me the most.
May 03, 2007 | Aiwa AV-D67 Receiver
How do i get rid of this annoying static?
Static is caused by one a weak signal and two a defective circuit board in the phone.
Apr 08, 2017 | Sony Ericsson Z520a Headset Headset
Belkin TuneBase Logo
80 people viewed this question
Top Belkin Audio Players & Recorders Experts
ocgordy
Level 1 Expert
woodzowl307
Vernon Taylor
Are you a Belkin Audio Player and Recorder Expert? Answer questions, earn points and help others
