Question about Hitachi 60SBX78B 60" Rear Projection Television
Hitachi Projection Color TV 60SBX78B
The set was playing and I heard a pop and it went blank. When I replug to unit into the electic I can see light inside for about 2 or 3 seconds and then it goes dark. If I plug it in and immeidately push the power button the red light comes on for 1 or 2 seconds and then goes off. Can you help? I am an novice and don't really do electric repairs.
My email address is esq61@comcast.net
  • Pat Gleckler Feb 01, 2009
    I have the same problem with my Hitachi 50VS69A. As I was watching there was a loud pop and it shut off. When I turn it on all three lights blink and there is a buzzing sound that comes and goes. After a few minutes, it shuts down. Any suggestions would be greatly appreciated. I'm hoping it's not a big repair that costs more than a new TV. This one is only 2 years old.
  • Hitachi Master
  • 3,459 Answers
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Posted on Nov 02, 2008
My Hitachi 60sbx78b popped and then shut off. It will not power back on, I plug it up and it sounds like it is getting power, the green led lights come on for a few seconds and then they go off and the...
On this model there is a common failure with some capacitors and fuses. Its a simple fix if you know which parts to use/avoid and how to do the repair. You can get complete instrucitons and parts for your model from www.TvRepairKits.com . Their kits include step by step color instruction guide as well as the correct parts to fix this issue.
Oct 17, 2010 | Hitachi 60SBX78B 60" Rear Projection...
I have a Hitachi 60sbx78b rear projection tv when I moved the set about 60 feet to a new room.when i turned it back on I now need 3d glasses to watch it the colors are all out of aline and the green line...
Check your owner's manual and see if there are instructions for setting the convergence. This lines up the different color guns so that you don't need your 3D glasses. If setting the convergence doesn't work, you may need new IC chips. Good luck!
Mar 01, 2010 | Hitachi 60SBX78B 60" Rear Projection...
While watching the tv, there were successive random popping and clicking noises followed by a louder noise and the tv subsequently went blank with no audio or video. I have pulled off the back cover and...
On this Hitachi model there is a common failure with some capacitors and fuses. Its a simple fix if you know which parts to use/avoid and how to do the repair. You can get complete instrucitons and parts for your model from www.TvRepairKits.com . Their kits include step by step photo instructions as well as the correct parts to fix this issue.
Tv blew up
Power board probally have burn capacitors.Take the tv aparts,check for puff up or burst open capacitors.Know how to solders? Replaced these capacitors well get ur power back.Or replaced the whole power board buy it at Shopjimmy.com,Ebay.com.
Jan 24, 2010 | Hitachi 60SBX78B 60" Rear Projection...
Cannot turn on TVour TV model is 60SBX78B, Hitachi project TV
If your remotes are out of the room and you try to turn and it still wont come as it should ,then You have a problem with the power switch or the supply, your unit needs to go to the shop . Sorry. DFD
Apr 11, 2009 | Televison & Video
Heard a pop and screen went blank - won't come back on.
Your Lcd Projector Lamp/DLP Television Lamp went out
its about $165-$200 to replace if not under warranty
Nov 28, 2008 | Hitachi Televison & Video
Tv dead
hello. the loud pop you heard was .maybe a fuse.? u need to uplug .!!! the set !!!. and take off the back and see if fuse is bown.? ok let me know.!! ok
Jun 02, 2008 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 60SX8B9K
Classis convergence failure - goto www.TvRepairKits.com to get a kit to fix this yourself
May 24, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Televison & Video Logo
236 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
