Vhs/dvd combo unit, durabrand adb2737bd will not allow me to copy my own vhs movie tapes to dvd as my tapes are starting to degrade. do you know how to hack round this problem
5 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Posted on Dec 04, 2007
SOURCE: VHS has audio but no video
we cannot get the vcr portion to work only the dvd player4.gif works what are we doing wrong?
Have the same problem? Click Here
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru
Rating: 88%, 431 votes
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (channel 3), standard video1.gif (yellow) RCA jack and S-VIDEO jack. If you are using the Component jacks, the DVD side will work but the VCR will not. This is because the quality of video recorded on VHS tapes is so much lower than component quality video.
Thank you for rating this solution.
Posted on Jan 01, 2008
  • 226 Answers
SOURCE: Magnavox H2160MW9 VHS tape "recording not allowed" to hard drive
RIAA has prodded the electronics manufacturers into putting copy protection into their recorders. You are allowed one copy, I believe, and you will be able to make it to a DVD-R in VR mode. VR mode protects (how? dunno) the recording from being copied a second time. DVD-RAM and DVD-R (maybe -RW) in VR mode should allow you to make your copy.
RIAA - Recording Industry Association of America
tom
Posted on Feb 01, 2009
  • 3 Answers
SOURCE: VHS won't play, sounds like tape will load then power shuts off.
This is similar or identical to another post, but here is an answer...
Hi, I have a solution you can try.
I had exaclty the same problem. When I tried to play a tape it would load (However, I recall I had to push hard to get the tape to be accepted, which is part of the problem) but would shut off after about 12 seconds, then when I powered back up the tape would eject. Finally I took the unit completely apart and attempted to use it with the covers off. Lo and behold, I found I could play a DVD on the unit without the unit powering off, but only if the room lights were on! If I tried to play a tape it would shut down the unit. So that led me to diagnosing the infrared loading and reel sensor circuits.
Background on that is there is an infrared LED that shines up through a plastic light pipe lens. The light from that LED (you can't see it) should shine on two photodiodes that are on either side of the tap mechanism, plus down through a gear with holes in it on to the reel sensor. When there is no tape inserted the two photodiodes will be illuminated and have about 0.2 volts across them. When a tape is installed the light will be blocked and the voltage goes up to above 2.5 volts across the diodes. You have to check this with the room lights dim as the diodes will respond to that light. When you block the light on either side of the plastic light pipe with your finger (with the unit disassembled) you should see the load motor engage, and it will back off when you take your finder away. For some reason in my unit the light from the LED was insufficient to turn on one of the diodes, and also to pulse the reel sensor when the gear turned. That could be due to component aging, or even if the light pipe started to cloud due to age, I don't know. However I was able to get the thing working...
In short I got the unit working by adding 3 resistors.
To do this you'll have to remove all the covers and remove the main PCB from the bottom chassis, unplug the power supply from the PCB, and the two ribbons going to the DVD unit. But you won't have to take off the VCR assembly, which is a pain. You just need some basic soldering skills, and remember where all those screws go...
First, I adjusted the voltage across the right-hand side load sensor diode to get the diode to switch on and off. I recall that I added 1meg across the diode. So the voltage then went from about 0.5v up to 2.8v from light to dark condition.
Second, I increased the current to the IR LED. I added a 330ohm resistor across the feeder to the LED. I recall that was R511 and was originally 220ohms. That was not quite sufficient to get the reel sensor working reliably. I didn't want to stress the LED by putting too much more current through it so looked for another idea.
Third I added 56k across the reel sensor diode to bring the voltage across it down so it would switch on and off as the reel sensor gear turned.
I now have a tape playing continuously in the unit and it seems ok for the time being. Hope that might work for you too.
Craig Townsend
Posted on May 26, 2009
How to record dvd from vhs
There are some units that can do this, but if you are trying to copy commercially recorded VHS movies to DVD you will have issues. The VHS tapes have copy protection on them and all manufactured hardware to record these have been required by law to support the protection. Thus, you will get poor copy reproduction when copying. If they are home-movie style VHS tapes, no such issues exist. You can either get a unit that has both devices integrated and has copy capability, or you can you a VHS player and send the outputs to a DVD recorder.
Jul 09, 2016 | Televison & Video
I've got some rare 80s movies on VHS that are not available on DVD. I want to transfer these movies to DVD, but my VCR/DVD combo unit will not allow me to burn a copy-protected VHS movie. Is there any way...
as i recall VHS cassettes have a hole on front (where is the label with name of movie ) which disables re-recording over original movie. if that isn`t the problem,you can try with connecting your VCR to PC inputing audio and video cable to PC. requirements for this recording from VCR to PC is that PC has graphic card with audio-video input.
Feb 26, 2011 | Audio Players & Recorders
I want to put my VHS movies onto DVD's.
It will copy VHS to DVD. Provided that it is a home movie and not a copywritten movie from the store.
Jan 11, 2010 | Samsung DVD-V4600 DVD Player/VCR
RCA 8295n dvd-vcr combo starts recording from VHS tape to disk and then stops.
Is the VHS tape a store bought movie or show?
MacroVision and other copy protection systems are put into store bought tapes and discs of movies and shows, and are read by your recording equipment. Once it reads this, it stops recording.
Does the screen turn red before it stops? This is one of the indications that MacroVision is stopping you.
Aug 28, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
HOW DO I RECORD A DVD TO A VHS ON A VHS DVD COMBO BY PHILIPS
Cannot do this on a combo unit. There is a chip that senses copy protection and prevents recording a copy-protected DVD to a VHS and vice-versa. Solution: Use an outboard DVD player or an outboard VHS VCR and try the recording with the video routed through a "stabilizer" box. The stabilizer (about $30 or less on Ebay) defeats the copy protection on MOST DVDs, but not all. It works with Netflix DVDs. Route the audio as usual. Audio is not protected.
Dec 15, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I want to convert a DVD to a VCR tape.
Do you want copy dvd movie on VHS tape?
Use DVD/ VHS Combo Player like shown in below picture...
Oct 27, 2008 | Televison & Video
I have been told that you make a vcr - dvd machine that will convert vhs videos to dvd , if this is true pls advise model number and approximate price
There are DVD/VHS combo units that allow you to record VHS tapes onto DVDs. The price of these units range from about $150 up to $300+ depending on the quality of the brand you want. I have seen them on sale for less than $150, but you would need to look around for the sales. There is a problem with these units, however. Most newer VHS movies (and DVDs) are encoded for copyright protection and cannot be copied - unless you want to purchase a Descrambler. A Descrambler allows you to bypass the copyright codes and are to be used soley for the purpose of copying purchased movies. There are strict copyright laws as you have seen during the intro of VHS/DVD movies. If you intend to use the unit for copying things like TV shows, movies on cable, or home movies, then this would be a worthwhile purchase. I have just a standard Toshiba DVD burner and believe me, it gets a lot of use, mostly for TV shows on prime time TV. I work second shift and would miss out if I didn't have it. I can guarantee that you will get your moneys worth out of it. You can find them pretty much anywhere that sells electronics. As far as the Descrambler, I'm not sure they are carried in your local department store. The only ones that I have seen have been in magazine advertisements and once on The Home Shopping Network (HSN) and the price on there was around $100 - this was about 2 years ago. I hope that I answered your questions. Please take a few seconds to rate how helpful this post was for you. Thanks and good luck. billyho1977@FixYa
Sep 19, 2008 | Televison & Video
Record from VHS to DVD
i should imagine so if they are not copy protected films i.e shop ones .if they are tv films on tapes etc then it would be possible to do so.
via insert the vhs tape and insert the blank dvd in to its tray
play the vhs tape and press rec to record on to dvd .
although the manual might give a better guide to doing this .
Online User Manual and Guide for Samsung DVD-V4600 DVD Player / VCR Combo by FixYa, Page #1
riz.
Mar 26, 2008 | Samsung DVD-V4600 DVD Player/VCR
Durabrand DV 1002
on your remote there should be a display button push it and it should tell you how long into the movie you are
Feb 11, 2008 | Durabrand DVD-1002 DVD Player
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
