Question about Craftsman 25cc Gas Line Trimmer
Craftman weedacker I own a sears weedwacker, model 358.791030, and the pull cord broke. I need to know how to remove the assembly-clutch cover.
  • Thomas J. Hebert Oct 04, 2008
    how do I keep the clutch from turning when I try to unscrew the torsk nut.
    yes
    Genius:
  • 3,422 Answers
HI,
You need a long narrow 20T tork wrench to remove the clutch bell.Most stores that sell tools should have them. You stick the wrench down the opening of the clutch bell (where the shaft normally goes), hold the flywheel so it doesn't turn (a screwdriver will work) and then unscrew the screw that holds the clutch bell on.
Posted on Oct 04, 2008
    Scholar:
  • 148 Answers
  • Hole in the end of the clutch housing where the cable slides in has a # 20 torx screw in there.
  • Pull the spark plug, stuff some rewind starter rope in the plug hole, use a water pump pliers and turn off the clutch plate(s). NOTE: curved shaft trimmer will be a standard right-hand thread, straight shaft will be a left-hand thread.
Change pull cord
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. 11
Jan 27, 2012 | Homelite Mighty Lite Lawn Trimmer
How do I remove the hassel free head of my craftsman trimmer model 358.791170
I can get you part way there. Remove the spark plug and shove some clean rope in the cylinder to prevent the engine rotating. Take the front housing off to access the clutch assembly, pull off the black plastic cover from the shaft end, and use a torx wrench to loosen the screw in the end of the shaft. After it's loose, the clutch drum will come right off. Unfortunately, I am stuck now trying to get the rest of the clutch assembly off without damaging it.
Sep 17, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
Hey there i have a paulan 446t pro extende chainsaw with a broke pull rope, i tore it apart to the point where i cant slide the outer cover off because of what i think is the clutch. which is just on the...
You should not have to remove the entire case to work on the starter mechanism. The starter assembly should come off by removing 3 or 4 screws from the left case. The cord is wound on a spool which has a coil spring inside which must be rewound CCW about 2 turns, then wedged to prevent the spool from unwinding again. Pick the remnant cord from the spool, then thread a new cord (about 3 ft.) into the hole/slot where the old cord was attached. Melt the cord end somewhat, then tie an overhand knot in the end. Wind the cord around the spool CCW until most of the cord is used, then thread the end through the exit port and pull about 8 inches outside. Clamp the cord with locking pliers or tie an overhand knot to prevent the cord from being drawn back inside. Thread the cord through the handle, melt that end, and tie an overhand knot. Pull the knot into the handle, and untie the knot used to hold the cord out. Release the wedge on the spool, and try to pull the cord as if starting--it should pull out without binding and return fully. Hope this helps!
Oct 20, 2010 | Garden
My craftsman pull cord broke on my weedwacker
Remove the tube that holds the flex drive from the end of the crankshaft. Lossen and remove the front cover. Remove the throttle cable from the carb. Remove the kill switch wire from the coil module. Remove clutch housing. Remove clutch, Remove flywheel. The recoil unit mates with the bottom of the flywheel and all the aforementioned parts are on the front side of the engine's crankshaft. Once you get the recoil unit off, you remove the old cord and turn the unit several times to "preload" tension on it. Insert the new cord into the guide holes and tie knots to lock it in place. The pull handle must be attatched too or when you let the recoil draw in the new rope, it will keep going and all tension will be lost. Reassemble all the above and good luck
Aug 31, 2010 | Craftsman Garden
My Brushwacker has a broken pull start rope (model 358.795800). I figure that it shouldn't be too hard to repair it, but I would like to find a manual for repair.
Good luck on finding a manual. You can get the exploded parts drawing off of the sears parts website! I have a 32cc model 358.791580 and the pull rope broke. The pull rope assembly is located inside of the motor housing. I am having trouble removing the clutch assembly since there is no key way or screw holding it to the shaft. Does anyone know if it is threaded on?
Feb 20, 2010 | Craftsman Garden
I have a Craftman' electric Weedwacker that quit.
there is a breaker built into the switch had a few of these over the years were the switch just melted you mine as well take the handle appart and check the switch just be sure to unplug it as you already know lol replacement switchs available at searsparts.com
Aug 25, 2009 | Garden
I need part for a Craftsman Weedwacker
You can either go to sears, or craftsman website or even easier if you can get one off of ebay
Aug 18, 2009 | Garden
Craftman 1/2 hp chain drive , stuck in down motion
The thing to do is remove the cover and watch the limit switch assembly. You should be able to see how it is supposed to work and determine what is wrong. A small gear on the end of the shaft turns the limit switch assembly to make contact and turn off the motor in each direction. Something may be broken or out of place. There is also a possibility your logic board is bad especially if you have had electrical storms recently.
Jul 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 25cc Gas Line Trimmer Logo
393 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
