Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs but does not blow heat
Hi
My Microwave runs but does not blow heat. what is the cause of the problem
  • Anonymous Oct 06, 2008
    I have the same problem as of 10/4/08. All the reading I've been doing points to the magnetron unit being defective. The replacement costs $139.00. I'm reading that if the unit is less than 10 years old, it's covered
    under warranty. But only the part.... not labor. You can buy another unit under $300. I've also read that when the magnetron unit is replaced, it dies 6 months later anyway. I'm cutting my loses and buying a new but different unit.
  • 6,784 Answers
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))....
Posted on Aug 16, 2009
Microwave keeps blowing fuses after u push start and runs 2-3 seconds
short in the circuit or magnetron take it in for a proper diagnosis but generally it is more expensive to repair than replace
Jul 16, 2017 | Microwave Ovens
Microwave convection model 6md364 - When i switch the convection oven on it blows the power.
There is a short circuit happening on your microwave. It may cause by a shorted to ground heating element or a wire that is expose to each other probably cause it by the generated heat which the plastics wire become thin. It's dangerous to use so I advice you to call a service tech near your area.
I hope I give you a idea in your microwave problem.
Mar 21, 2011 | Whirlpool Microwave Ovens
Microwave oven will not heat? Could it be a fuse. The fan makes a louder noise than before it stopped heating. One side blows hot air the other side blows cold. Not sure what to do
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 15, 2010 | Hotpoint RVM1425 Microwave Oven
GE microwave JEB1860 runs like normal but no heating. 21 months old. What is causing the no heating.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 gfsghhgs
Aug 05, 2010 | General Electric JEB1860 1100 Watts...
My microwave turns on but doesnt produce heat
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Microwave Ovens
GE Spacemaker 1400 acts like everything works but does not heat.
Hello :
WARNING :
good luck
Apr 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker runs but wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jan 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave does not heat
un plug remove cover find red lead to magnetron with thick long plastic round blob this contains a long glass metal ended fuse that has probably blown due to running when empty long fuse is necessary to stop hi voltage flashing over airgap when fuse blows when fuse blown no output from magnetron as hi volts missing steve t
Dec 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave troubleshooting...
My GE spacesaver microwave all of a sudden stopped heating up things. The lights, fan, turntable, etc. work, but nothing is heating up. Any suggestions?
Oct 23, 2007 | Whirlpool GH8155XM Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
382 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
