Question about Dishwashers
Dishwasher will not drain water. Put Drain-O in did not work,ran short cycle water on floor. HELP
  • mrmistert Feb 19, 2009
    The water builds up in the bottom of my dishwasher also.
My Whirlpool Diswasher did not drain water. The same water has been recycling from washing thru rinsing and sitting there after done.
Model: S62NXPLP-7624
Posted on Nov 11, 2008
There is still water on the dishes and in the dishwasher after the heated drying cycle. Not a lot but enough to wet the kitchen floor. What can we do?
check the kitchen drain is clear - looks like the drain cycle is not working efficiently.
Also make sure the filters at the base of dishwasher are clear.
Try a short cycle (like rinse only) and see if water drains at the end. If problem is occuring only during the normal wash cycle, then drying fan may be the problem.
Jan 08, 2011 | Whirlpool DU1055XTS Built-in Dishwasher
My dishwasher won't drain after its cycle - I suctioned it out and cleaned around the drain. I ran a light wash cycle and the same thing happened.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 30, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Dishwasher not draining
Thanks for writing to Fixya.com.
To fix a dishwasher that will not drain, remove any clogs that are blocking the drain line by pouring a paste of baking soda, vinegar and water down the drain, and then pouring boiling water to clear the clog. Repeat the process several times to remove a severely clogged dishwasher drain. Thanks for contacting Fixya and please accept the solution if it has helped you.
May 15, 2010 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Apr 23, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Water in bottom of dishwasher, can't get it to drain
pull your water drain line out and place in a bucket on the floor. then try to drain it again. alot of time the hose get an air gap or blocked with gunk.
Feb 16, 2009 | General Electric Adora GHDA670N Built-in...
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
Dishwashers Logo
277 people viewed this question
Top Dishwashers Experts
