Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Stubborn Gas Blower
Good fire, plenty gas, new plug and it still wont start. I used starting fluid at the carbure
tor and in the cylinder. I checked for sheared pin and still no result. I do suspect the ignition module but since there is strong fire at the plug I am not sure.
  • 2 more comments
  • lbjallthe wa Oct 07, 2008
    Hairyloon, what should the compression measure on this two stroke engine?
    lbjalleth wa
  • tsweat Nov 29, 2008
    Two year old Poulan PRO 200 LE. Wouldn't start, I changed the spark plug, it has gas but still won't start.
  • dauber985 Dec 04, 2008
    I have owned TWO of these PBV200LE's and they BOTH just flat died and refused to start. You could pull until skin rubbed off inside index finger and no pop. Both did it all of a sudden and both had no spark from the spark plug when tested. Fuel fine as plug would get wet if choked too much. Clean plug and test by holding it against the frame and pulling the cord... no spark. Tried NEW spark plug and no go. Fresh fuel/oil. Always stored inside. Used for cleaning up after edging. Moderate use. Compression feels good. First one died in less than 2 seasons. Bought another one and it died in about the same time. Both ran perfect until death.
  • paddlefoot20 Apr 22, 2009
    I BOUGHT THIS "POULAN PRO" LAST NOV. (5 MOUNTHS AGO), USED IT "TWICE" FOR A TOTAL OF "THREE" HOURS!!!!!!! TODAY I TRIED TO START "MY NEW BLOWER" TILL MY ARM WAS READY TO FALL OFF.......... IT'S GOT FRESH GAS, A GAS CAP FROM BY NEABORS BLOWER (THAT RUNS) AND A NEW PLUG... WHY DON'T THIS THING START??????? THANK YOU, DON
Hey buddy chk that the cylinder head is loose or the gasket is blown,, thats what i found on mine after buying a new blower,, returned it no problem tho ,, you will have to manufacture a tool to tighten one of the bolts and also use locktite on the bolts so they wont backout after running ,, be sure to clean the holes and the bolts before applying locktite,, hope this helps ,,
bobby allison germantown tn
Posted on Aug 29, 2009
My pbv200le leaf blower only runs when you keep choke lever about half way on all the time. when the engine warms it will die when you push the choke completely off
Posted on Dec 21, 2008
  • 45 Answers
Check the compression.
Will it fire at all when you put petrol down the throat of the carb? (just a wee drop).
If you've a good spark it is not likely to be ignition, my first guess is the piston rings.
Posted on Oct 06, 2008
  • 1 more comment
  • Hairyloon Oct 07, 2008
    Also check the crankcase seals. Two stroke engines rely on the pressure from here to work.
  • Hairyloon Oct 08, 2008
    Hey mate, how good do you think I am? You've not even told me the model of blower. ;)
    But I'm afraid I don't know the answer to that even if you did.
    You should feel the compression when you pull the starter cord, does it feel healthy?
    Check also if you're getting any suction on the carburettor when you pull it over.
    Try starting the engine a few times, then remove the spark plug & see if it is wet with petrol.
    If it is, then you know the fuel is getting through.
Cr 250 r honda dirt bike wont start
What did the spark plug look like when you first took it out? Was it black/wet/sooty or was it a light tan/gray color. If it was black/sooty, then I would guess you need a coil. I know you said it had a good blue spark when you checked it, but if you poured a little bit of gas in the cylinder and it still wouldn't fire that would be my first place to check. If it ran briefly after you poured a bit of gas in the cylinder and then died, then it's a fuel supply issue. Remove the line that goes from the gas tank to the carb and make sure you have gas at the carb. If you have gas, then I would remove the carburator and take it apart making sure all the jets and passageways are clear. Use carb cleaner and an air attachment and if you still can't get it out, use a small wire to clear things up.
Reassemble and it should run, otherwise report back and we can go to the next step.
Jul 11, 2013 | Honda Motorcycles
Can't get it started after new spark plug (gets spark), new gas, good compression tried starting fluid. Whats the problem?
Quick way to check condition of the engine is to remove the muffler. Also make sure that the spark arrest screen is clean. With muffler off, examine the condition of the piston and cylinder. If the piston looks burned and cylinder is scratched, saw will be hard to start. The cylinder and piston should look very smooth. Secondary test to verify condition of engine is to spray plenty of wd40 in cylinder and around piston, then pull the starter slowly. If you see lots of bubbles as you pull, indicates compression is leaking and will be hard to start. If cylinder/piston are in good condition, use new spark plug and retest.
Oct 18, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
1989 chevy truck, 5.7...will not start....no fire at spark plugs, Bat. voltage at ignition coil and to ignition module, tested ignition coil (OK), new distributor and rotor, no change. Used starting fluid...
Hi, I believe there is a computer problem. If possible check codes for no start condition. if you know the no.#1 cylinder at TDC (Top Dead Center) on engine then you will know no#1 distributor is. Good luck.
Jun 14, 2011 | 1989 Chevrolet C1500
I have an echo pb400e backpack blower. it wont start. getting fire but wont crank.
is your spark plug getting wet from fuel? try take air snorkel off carb and give it a shot of carb cleaner if it fires you have a fuel problem if it doesent fire , and plug is wet pull plug and rollover and get excess fuel out of cylinder, and try carb cleaner again, if no luck check compression, then if good go to flywheel and see if loose
Apr 12, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
I can't get the blower to start. I have replaced the spark plug and there is no fire from the plug. I have checked the fuel and fuel lines and filter. No fire, no start. I even replaced the kill switch.
I have read many problems with this unit but I have never heard anyone mention the
diaphram on the side of the carburator. I can't get my leafblower started and I could
see that no gas was getting to the cylinder. I'm about to go to a repair/parts store to
buy a new diaphram for the carburator that I expect will not cost more than $5.00.
It's located on the left side of the carburator secured by a small metal plate with 4
screws. I know enough now to avoid ever buying a troy bilt product ever again.
Brian
Mar 04, 2011 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Chainsaw will not start.new sparkplug fires outside the cylinder so i know there is fire. I poured A small amount of gas mixture into cylinder and tryed to start, no sign of life
Hello myt.... Make sure the spark plug is good and also that the fuel filter is not clogged. Then remove the air cleaner, recruit a helper and have a can of starter fluid handy. Have the helper spray some startere fluid into the air intake, start it up, and continue to spray starter fluid into the air intake so it runs for a minute or two. That should clear the problem.
If not, your carburator is really dirty and needs to be taken apart and cleaned. Joe
Thanks for choosing Fixya!
Feb 24, 2011 | Husqvarna Garden
Just bought a 1984 mustang its not run for years and wont start it turns over getting gas to the carb and has fire not sure about wiring
Any time a car sits for a long period of time you should completely drain the gas tank. The gas is more then likely stale. Try pouring a little new gas into the carb or use starting fluid. If it starts you have found your problem and will more then likely have to drain and clean the tank and replace the fuel filter.
If it does not start with the new gas, it is either a compression or timing issue. If you have spark at the plugs, and GOOD fuel in the carb and it still wont start I would check the timing. If the timing is on, check compression. If the engine sat to long with no oil in the cylinders they can build up condensation and rust. Then when you try to start it with the rust in the cylinders it can destroy the rings and cause compression loss.
Apr 08, 2010 | 1984 Ford Mustang
I can't get it to start -put in a new plug and brand new gas - Mery Mac 5 hp blower
being a splitter its probably been sitting a while so the carburator is probably gummed up to see if its the carburator take off the air filter a spray some starter fluid with choke off it should fire right up then will die but it will tell if its the carburator thenwe will go from there
Itsman
Nov 02, 2009 | RTO Merry Mac Highway-Towable...
Ryobi 33cc wont start
Assuming you still have evidence of fuel in the cylinder after carb work; and still have visible spark across the plug, I would install a new spark plug. It is fairly common for a spark plug to cease working under pressure in a cylinder while appearing ok outside of the engine.
Sep 23, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
955 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
