Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE2, not starting
Door locked, I manually unlocked it, but any other ideas of how to reset it or such?
I can go through the setting process, but when I push start it just beeps at me and does nothing.
Any ideas what's going on.
Also, I have not been using HE soap...Could this have caused the problem, and if so, how can I fix it?
  • truebug Oct 06, 2008
    still does not work. I tried that before, then tried it again when you suggested it, but still does not work. I found a booklet to test for the different lights to light up and tell me what is wrong with it. It says that the door is locked...well, that is not the case, because I manually unlocked it. But when the problem first occured, the door did lock, but it was suppose to, because I was wanting it to start.
    Any other suggestions? thank you.
    P.S. the washer is only 2 years old.
  • 750 Answers
Hello true bug
Welcome
You said, Door locked, you manually unlocked it, but any other ideas of how to reset it or such?
you can go through the setting process, but when you push start it just beeps at me and does nothing.
Yes,
As with an error code the way to reset th system is!,
First unplug the washer and wait a 5 minutes then restart it like rebooting your computer when its acting strange!
If you can not reach the plug use the breaker!
This should problem and solve your problem.
The soap did not cause this. It was probably a fluke!
Next use only HE detergent and do not put more than the machines guide says,.
To much detergent will eventually destroy the seal and bearing.
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
Please remember to give me a rating!!!!!!!!!!!!!!!!!!!I think it will be solved!
Posted on Oct 05, 2008
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
After washing a load there remained 1 min and the door would not unlock. I manually unlock the door, load was spun out, but could not get another load started.
you couldnt wait 1 minute??,now you need to check alignment of the door lock and switch,make sure that the lock works and all the door switches are aligned
May 18, 2015 | Kenmore HE2 Plus Front Load Washer
Open locked door
To open the door when locked. Start new wash cycle and the door will lock - unlock then lock again. when it unlocks open the door quick.
Feb 15, 2015 | Kenmore HE2 Plus Front Load Washer
Have an HE2 washer. close door, select any cycle, press start, locks up then unlocks and shuts off???
unplug--see if it resets--if not--the control box is bad--about 300 for the part
Jan 11, 2015 | Kenmore HE2 Washing Machines
The machine is locked and can't open with clothes washed inside,. Add garment light is on and the time is flashing'
Whirlpool-made Front Loading such as the Kenmore Elite washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer and drain the water from the tub before accessing it. The link below contains the detailed instructions on manual unlocking of the door.
Manual Unlocking of Whirlpool Duet and Kenmore Elite Front Load Washing Machines
Aug 26, 2011 | Kenmore HE2 Plus Front Load Washer
I notice F22 error message on washer. Door seems to be jammed and will not unlock
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Mar 12, 2011 | Kenmore HE2 Plus Front Load Washer
My washer say f28 it is a kenmore HE2 plus
"F28" means your washer is locked and not unlocking. To unlock your washer take the bottom access panel off by removing the 3 bottom screws.Reach up near the latching assembly & attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
Thank you!!
Jul 18, 2010 | Kenmore HE2 Plus Front Load Washer
The door won't open. There are no error messages.
open the bottom panel by unscrewing 3 screws. reach up towards the door lock and pull a level to manually unlock the door.
Aug 17, 2009 | Kenmore HE2 Plus Front Load Washer
Front door is locked and I can't get it open
Hello shoya_garris,
There is a manual release tab you can use to open the door. Make sure you unplug it first. Remove the bottom front service panel. Carefully reach up and pull the manual release tab on the bottom of the door lock assembly until you hear it click. Wear some gloves there can be sharp edges on the inside of the machine panels. Hope this helps.
Thanks,
edgin96
May 12, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
65 people viewed this question
Sal De
fordexpert
Robert Rankin
