Question about Kenmore 63012 Electric Dryer
Squeaking kenmore dryer
We have a 110 66512694 kenmore dryer.
I used it lastnight and it sounded normal. today however, I turned it on and it is making terrible squeaking noise, and it smels hot. is it a bealt or bearings? im not using it because i do not want it to get worse and be harder to fix. I would like my husband and I to beable to fix it on our own. we bought it used and dont know when it was oiled last, or servied.
any advice?
  • 943 Answers
Hi .thanks for the question. the noise is from the drum rollers . you can buy a drum roller kit for kenmore dryer . to repair. lift out lint screen remove 2 screws . with a flat screw driver pry the top up between the top and front at each corner. lift top 2 screws on the inside of front panel remove pull front off . remove drum . replace parts in drum repair kit . thanks the appliance doc
Posted on Oct 03, 2008
My kenmore 84052 is making a squeaking noise
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Aug 14, 2014 | Kenmore 84052 Dryer
GE dryer Mod # DWXR463EG1WW is squealing. Does anyone know what is wrong with it and how I can fix it?
Sounds like a rear bearing . remove the 2 screws from the top when you open the door . this way you can take the top off . When you take the top off remove the screws on the inner left and right on the front panel. disconnect the belt from the pulley and motor and pull the drum out . then you will see the rear bearing . cheap fix but can be a pain. good luck
Feb 16, 2013 | Dryers
Kenmore clothes dryer squeaks loud to get going
Sounds like a bearing or the drive belt. Try turning the empty drum by hand. If it sounds normal you probably just need to replace the belt. If it make strange sounds when you turn it by hand then its probably the bearing.
The belt isn't a big deal but a bearing probably is.
Dryer runs and heats but has squeaking noise. Drum seems to labor mid cycle and then shuts off. If I turn cycle to off and wait unit will resed and begin cycle again with normal heat. Squeaks in on off...
Hello & Welcome to FixYa
The squeaking sound comes when the belt is either broken or worn out and needs replacement or the idler pulley is bad. If you want to do this yourself then you can check this video on YouTube:
Please get back to me if you have any other questions.
Kevin
Jan 30, 2011 | Kenmore 73932 Gas Dryer
The drum of the dryer will not turn and there was a squeaking before this happened that sounded like a belt, what does it sound like to you
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 04, 2010 | Kenmore Dryers
Dryer makes loud squeaking sound when spining
how old? Dryers squeak for one of 3 reasons..bad belt, bad motor or drum rubbing against dryer framework.
run it empty...intermittent squeaks usually are the drum...something's bent
continuous- is there any burning smell? If so, most likely the motor, if not, possibly the belt.
Open the top (most have screws or can just be pried open) and watch it run...identify the source of the sound if possible
try spraying the belt and motor with a little wd-40 and let it dry for a day, then try again.
If that doesn't help, repairman or new/used dryer...probably better off to find a decent one off of craigslist b4 paying to repair an already faulty machine
Feb 22, 2010 | Kenmore 62802 Electric Dryer
Squeaks & takes longer to dry
The squeaks are normally a sign of dry drum roller bearings. You either need to lube the shaft and bearing of the roller or replace the roller completely.
The drying problem sounds like you have a least one bad thermostat, need to check and replace the faulty thermostat
Sep 22, 2009 | Kenmore Dryers
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
Kenmore Dryer Model 970-C82062-10
The bearing or spindle the drum rotates on is probably bad or worn out. You can get to the back and turn it by hand and feel it when you turn it. You can tell if it is metal rubbing. If so, you can replace it.
Jan 25, 2009 | Kenmore Dryers
Kenmore 63012 Electric Dryer Logo
542 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
