How to empty and refill my hp1006 toner cartrage
It's easy.
Here's a link to the video showing what I use.
http://www.youtube.com/watch?v=xUWLZ3BoMCc
Posted on Jan 12, 2010
The toner light of HL 2140 will not go off. even if i turn the printer on/ off and wait for a few minutes. i've also move the green thing back and forth a hundred times and still the same. Please help!
You need to look at the toner cartrage if it was a new or compatible cartrage bought to replace the old one the problem would not exist unless the printer is broken.
Thier is a counting gear on the left side and on new or replacement cartarages it is in the 11 oclock postion when it is new. When the toner is all used it moves to the 3 oclock postion. What you need to do if you refilled the toner from a refill kit is to manually move the gear.
I believe thier is two ways to do this one buy a reset gear tool.
The other way that I do is to remove the three screws carefully that holds all the gears in place. Dont worry as it is just the cover and you can not really break the cartarage unless you strip the screws.
Once opened manually using your hand push firmly on the counting gear until you move it back to the 11 oclock postion. Then carefully reassemble the cover.
Once you place the cartrage back in the light will go off on its own and the toner counter will be reset.
3 don'ts
Do not try to only move the counter you may get a few pages but this is bad for the printer
Do not leave any toner in the cartrage when refilling as this contaminates the toner and really shortens the refill life, try to get all the toner out as possible before refill.
Do not keep reshaking the cartrage and place it back in the printer, everytime you insert the cartarage the it can snag or be inserted a tiny bit wrong and break the gears in the printer. Do so in emergencys only, the rest of the time just refill the toner. $10 with delivery on ebay
Sep 05, 2009 | Brother HL 2140 Laser Printer
Need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
Aug 08, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Empty Ink Cartrage message when cartrage still has a lot of ink.
I'm going to provide you a solution worth many dollars now you can use your left over half filled cartidges and in future also use the cartridges to the extreme.
1. Go to menu and select manual override for toner cartridges and then only replace toner when the print quality starts to suffer. This can save you thousands of dollars over the life of this fine printer.
2. download and read this
http://74.125.153.132/search?q=cache:9mwf_bY_x-AJ:www.refill4.com/refillinstructons/pdf_downloads/Full-RefillInstructions.pdf+brother+mfc+5840+override+cartridge+empty&cd=6&hl=en&ct=clnk&gl=in
Jul 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
Brother 2140 toner light keep flashing and i just replace it with new toner
You need to look at the toner cartrage if it was a new or compatible cartrage bought to replace the old one the problem would not exist unless the printer is broken.(Or if the replacement has a missing or broken or miss postioned counting gear.)
3 don'ts
Do not try to only move the counter without refill you may get a few pages but this is bad for the printer
Jul 09, 2009 | Brother HL 2140 Laser Printer
Samsung scx4200 toner problem
I refill the toner for samsung scx4200 .Now its show toner empty replace the toner on the printer lcd. How i can slove this problem.
Jul 09, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Color ink cartridge says empty i just filled it
When you put in a "new" cartrage the printer sens an electrical charge to the cartrage to set it up properly. So I would treat this as a new cartrage, rather than a refilled one. Go to the printer menu and re install the ink cartrage in question, it should recognise it and start the function as a new one, good luck
Mar 24, 2009 | Epson Stylus CX6000 All-In-One InkJet...
C3300n toner low
This mesage often appears because you refilled the toner. The chip in the toner is sayingthat it is empty, but I can assure you it is full because there is no sensor in the cartrage that keeps track of this. Use genuine toner next time, as refilled or remanufactured can break your printer over time.
Mar 19, 2009 | OKI C3400n Laser Printer
Lexmark Black cartridge 28
You cannot refill a 28 that has been through a refill program. Look at the box dose it say refill program cartrage ?? then you can't refill it, it will always say empty.
You can however refill a 28A.
May 13, 2008 | Lexmark X2500 All-In-One Printer
173 people viewed this question
jasbo
jasbo
