Question about Canon NP 6551 Black and White Copier
Error Code: E631 & E632 on Canon NP6551
The problem is on the colater, when unplug the collater no error show, when plug it back the error up.
please help!
    President:
  • Canon Master
  • 990 Answers
Make sure the error code you gave to us is E631 & E632 notE531 & E532, you number not on our menu, if my number is correct that's mean stapler motor defect, replace it!
Posted on Dec 12, 2008
Canon pixma printer mx377 show error code 5040 what does it means
Description
A printer error has occurred.
Resolution
  1. Turn off the machine and unplug the power cord from the power supply.
  2. Plug the machine back in and turn the power on.
    NOTE- If you disconnect the power plug, all the faxes stored in the machine's memory are deleted.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility
Feb 25, 2016 | Canon Office Equipment & Supplies
What does error code 6910 mean on canon printer mg5440
Description
Resolution
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Apr 16, 2015 | Canon Office Equipment & Supplies
Canon mx374 error 5040 please advise ?
This might be a system board that has failed:
Here is the link to the error code:
http://www.canon-europe.com/support/consumer_products/products/fax__multifunctionals/inkjet/pixma_mx_series/pixma_mx374.aspx?type=errorcode&errordetailid=tcm:13-1333319
Description
Resolution
If the error message is still showing, then it is necessary to deliver or send the printer to an authorized repair center.
If the printer is still under warranty, (generally one year from purchase) and supporting documentation is provided, then a free of charge warranty repair will be carried out.
Dec 28, 2012 | Canon Office Equipment & Supplies
My copier was working just perfect.(canon ir 1270f)...and had a paper jam..removed and now its shows error code toner/drum crg..what could possibly the problem...please help me out with this
hello
remove the paper jam and close the front cover and unplug the power from the outlet and same at the back of the printer, wait for 5 minutes and plug it again. this will helps to clear the error code of the printer.
thank you
Mar 08, 2011 | Canon imageRUNNER 1370F All-In-One Laser...
I have a canon copier with colater the colater when you start the machine goes down and just clicks and never comes back up again. The screen gives me error code E000540-0001
E540
Main Cause: The tray home position sensor (PI8) is faulty. The tray lifter motor clock
sensor 1/2 (PI9/PI19) is faulty. The tray upper limit detecting switch (MS5)
is faulty. The tray lifter motor (M5) is faulty. The finisher controller PCB is
faulty.
0001 The ascent does not end in 15 secs when the tray lift motor is
driven; or, the tray home position cannot be detected when the tray
lift motor has been driven for 15 secs.
Feb 10, 2011 | Canon imageRUNNER 6020 Copier
We have a Canon imageClass D860. It came up with the error code E000. We have unplugged several times and left unplugged. When we plug back in, the error message is still there. Have any answers?...
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300/1310,1330,1370,1630,1670, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681/D880
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press Unplug printer and repower it.
Oct 11, 2010 | Canon ImageClass D880 Copier
The screen just shows error E000
E000 code Fuser Error
What model of Canon copier is it?
May 15, 2009 | Canon Office Equipment & Supplies
Error code E522. How to fix this?
You have an issue with your staple finisher, probably need to inspect the stapler unit itself to make sure nothing is jammed in it and it moves freely. If you can't clear the error then most likely the unit is defective.
Hope this helps,
TankMurdock
Apr 24, 2009 | Canon NP 6551 Black and White Copier
E000 sYSTEM eRROR
Solution: Unplug unit for 3-5 minutes, then plug the unit back in
Unplug unit for 3-5 minutes, then plug the unit back in.
OR
I hope it helps!!!
Dec 12, 2008 | Canon ImageClass MF5770 Laser Copier...
Please help
E401 RDF Pickup motor or pickup sensor problem, try to clean the sensor and reset the error code in *4* ERROR clear.
Jul 08, 2008 | Canon NP 6551 Black and White Copier
Canon NP 6551 Black and White Copier Logo
491 people viewed this question
old marine
old marine
