Question about Hotpoint WD62 Front Load Washer / Dryer
Noisy spin on hotpoint wd62
I cleared the pump it was full of fluff and coins but i also found a metal bit that look like it has broken of the machine. It now sounds as if I am washing bricks when it goes into a spin any suggestions please
Comon fault on hotpoints is drum bearings put ya hand in the drum and give it a quick flick if it soundslike it rumbles buy a new washer.since merloni bought hotpoint you prob have to buy a whole drum not just bearings
Posted on Oct 03, 2008
Noise from machine
1.check if the bra wire is poking out of one of the drums.Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
2.clear the water pump from obstractions like coins or small objects there might be some coins stuck in it that are causing discomfort.
if all the above fails try to run the motor alone without the belt if you still hear the noise its the motor that has a problem
Oct 27, 2012 | Hotpoint Aquarius WD640 Front Load...
Loud noise when spin drying, rumbling sound, sounds like concorde taking off! Hotpoint Aquarius 1200 washer dryer WD62
Remove rear panel of washer, and remove drive belt.
Spin the drum by hand, and if it feels rough, or is noisy, then the main drum bearings have failed, quite a big job to do.
Please rate my solution.
Thanks.
Nov 07, 2009 | Washing Machines
Hotpoint wd62
Try taking the top off, power off obviously!! and remove the draw unit, there is a pipe that runs from there to the drum.... I found a sock in mine that was the problem !!
Feb 03, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Where do I drain the tumble dry water on a hotpoint wd62 wash/dry
remove the top panel by unscrewing the 3 screws at the back of the washer dryer . remove the top and then remove the back metal panel. the screws are down the side and all around the back of the panel. once you have removed the panel check for the black rubber hose that connects to the drum. remove the clip holding the rubber hose by prising it with a small screwdriver. be careful as the water will flow out quite quickly. Check the hose pipe for any blockages and clear as required.
Jan 04, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Clearing the pump for coins ect.
Hi this is an easy one but please rate me as.
Cool What you got to do with this machine is basically remove the back panel to get to the filter at the bottom of the drum.
What you will need is a pozi screwdrive and a pair of pliers for this job, and in most cases the filter is blocked.
So pull the machine out from and disconect the electric, look at the back of the machine and you will see a whole load of screws which to be exact there are about 9 small ones and 6 others which are slightly larger near the bottom area of the panel.
remove the panel by unduing the screws. once removed at the bottom of the drum you will see the filter which is connected by either a steel clips which you just squeeze and pull down the filter. inside is a plastic white thing and just pull it out with the junk in it and empty and clean.
replace filter and back ,, hey presto
hope this helps im sure it will
Washdoctor
Oct 02, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint wd62
The most likely culprit here is a the pump, which may either be blocked, or broken.
You should be able to get access to the inside of the pump through a small hatch on the front panel of the machine at floor level. Beware - as you open this, really quite a lot of water is going to come out, so you'll need tomething to catch it, and you may need to shut the cover a few times if your container fills up before the machine is empty.
Once you've got into this space, remove all the loose coins which have accumulated there. If you think you found enough to block the pump and stop it working, put things back together and see if the machine is fixed.
If not, turn off the cold water supply, and run the machine in tumble-dry mode for a few seconds at a time while watching the pump impeller (looks like little fan) in the back of this cavity.
If it doesn't start whizzing round of it's own accord every time, then you need a new pump motor. These are cheap, readily available on the net, and straightforward to fit.
If the pump appears to start and run OK, then check for kinks and blockages in the hose that goes from the drum down to the pump, and in the drain hose that goes from the pump out the back of the machine. Finally, make sure that where the drain hose plugs into the standpipe (of whatever fitting is used in your part of the world to connect to the domestic drains), air can get in freely.
A.
May 18, 2008 | Hotpoint WD62 Front Load Washer / Dryer
WD62 is not spinning even after chaning new carbon brushes
when u changed the carbon brushes did u move the little metal pin to free the carbon off it must be able to come out then in with ease if not do this if u did then if the carbon brushes have got too low then it will have more then likely damage your motor m8
Feb 09, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD61
1, your pump may be blocked by fluff coins and other debris.
2. more likely bushes worn on the main motor not giving enough umphhh (loverly word) to go through a complete spin....Bushes easily replacable. Job start to finish with parts on hand a machine mechanic 10-15mins top Diy er like me an hour allways have trouble finding the right spanner... Good luck.
Jan 06, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
no the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
Aug 14, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 Front Load Washer / Dryer Logo
206 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
